takotruckin SUPER Baja
Joined: August 14, 2005 Posts: 2378 Location: stuck in fresno, ca
Posted: Sat Aug 27, 2005 3:40 pm Post subject: Tako's SuperBaja |
Here is my thread about my baja. i finally decided to stop being lazy and make it a full description of my car. So here goes.
the car is a 71 superbeetle. the engine is a supercharged 3.8 V6 from a Ford Tbird. the engine is rated for 215hp stock, so im probably around 250 right now. the motor is mated to a stock 091 bus trans with a kennedy adapter and flywheel. The trans is in with the cheapo kit that puts the shift rod over the tunnel. the axles are swayaway. clutch is a kennedy stage 3, with a heavy duty disk. the radiator is mounted in the trunk, with the stock fan from the bird, its rated for like 3000cfm, moves plenty of air. radiator lines are run under the car, with 1x2 rectangular steel tubing. for rear suspension im running stock arms, boxed. shocks are bilstein 7100s with reservoirs. mounted to the cage. once the front end is done the rear will get a little more extreme. front suspension is stock super, lifted. it sucks. the car is actually hard to drive, not safe. so now im trying to find a l/p beam to put in it. i may end up going with longer arms when i convert, depends how much money i have saved up by then. the car is in the process of being fully caged, thats getting close to done.
Josiah Samba Member
Joined: April 04, 2004 Posts: 363 Location: riverside, ca
Posted: Sat Aug 27, 2005 3:48 pm Post subject: |
nice looks wild _________________ fear causes hesitation and hesitation will cause your worst fear to come true. |
Nicksan Samba Member
Posted: Sat Aug 27, 2005 6:31 pm Post subject: |
Cool, Looks good and looks like its easy to change the serpentine belt. |
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2985 Location: altus, oklahoma
Posted: Sat Aug 27, 2005 8:46 pm Post subject: |
fix the flat on the four wheeler. _________________ blank |
Colorado_Baja Samba Member
Joined: August 24, 2005 Posts: 54 Location: The Forest, CO
Posted: Sat Aug 27, 2005 9:04 pm Post subject: |
Very cool Any more build photos?
Greg |
Dannyrandomstate Samba Member
Joined: September 04, 2004 Posts: 228 Location: the country's Mecca to vintage Transporters
Posted: Sat Aug 27, 2005 10:28 pm Post subject: |
whats goin in the golf cart? _________________ An irish guy walks out of a bar...... yeah like that would happen!
55/56ish Ambulance |
Posted: Sun Aug 28, 2005 8:16 am Post subject: |
that four wheeler is part of the scenery, the real toys are behind that wall.. i was actually considereing some way ov mounting my 1600 in the golf cart.. i dont really have any build pics, never really considered it, just the semi-finished product. |
Posted: Sun Aug 28, 2005 8:19 am Post subject: |
Nicksan wrote: |
you should hear how mad the supercoupe guys get, they just about have to pull the motor to change spark plugs, i hardly have to bend over |
Chris181Westy Samba Member
Joined: August 05, 2003 Posts: 148 Location: Michigan, The Third Coast!
Posted: Sun Aug 28, 2005 9:46 am Post subject: |
One of the better watercooled conversions I have seen! But I do feel bad for your rear suspention! Having to carry that heavy v6 around. To each his own but I still can't really stomach a non VW engine in a VW. But that said it looks kinda cool and alot better than a 2.3 Pinto powerplant. _________________ "So we went for a spin in the country
To feel the wind in our hair
To feel the power of my engine
To feel the thrill of desire"
Roger Waters, The Pros and Cons of Hitchhiking |
Posted: Sun Nov 13, 2005 5:33 pm Post subject: |
just thought id post some pics of what ive done recently
boxed trailing arm, not painted yet, no lower shock mount yet
shock mounted, for everyone to see.
notice the tires wont rub the fenders anymore, thanks to 30mm torsions.
engine cage almost done
i just need to cut off the tubes that stick up, and put some kind of cool looking hoop there. and mount some tailights on it, so i can get these stock ones off before my fenders break..
quick pic of my seats
and i got them for $50!!! just made some brackets and welded them to the stock frames. now i just need to make the passenger one flip so ican get behind it without taking it all the way out.
so, thats about where it sits. now i have the blower and fuel injection torn off to find a fuel deliver problem. i have at least one injector that is sticking and flooding out the engine. (might be time for some big injectors ) |
el loco kingo Samba Member
Joined: October 02, 2005 Posts: 607 Location: temecula, california
KDF Baja Samba Member
Joined: October 25, 2003 Posts: 247 Location: Minnetrista, MN
Posted: Wed Nov 16, 2005 7:25 pm Post subject: |
thats a killer car, my buddys brother had a thunderturd pooperscoop (it was rusty, thats his nickname for it) but its a quick car, ill bet that thing rips. my other buddy had a 2.3 turbo t bird, that thing was QUICK. also, my friend has that same wheeler _________________ 72 baja up for sale/trade! moving to WI in march, bug must go!
89 suburban |
subybaja Samba Member
Joined: July 06, 2005 Posts: 1026 Location: Anchorage
Posted: Wed Nov 16, 2005 10:39 pm Post subject: |
Slick setup!
That's pretty much what I'm planning for my baja's radiator, only maybe hidden under a wing like the Manxter DS:
Do you need a hoop from that rear cage to support the radiator? |
bugs_r_cool Samba Member
Posted: Thu Nov 17, 2005 1:37 am Post subject: |
Did you have to cut the fire wall for it to fit and what did you do for a tranny |
4x4EATR Samba Member
Posted: Thu Nov 17, 2005 1:03 pm Post subject: |
.I would LOVE to do that, only one problem... me+power=well, not good. |
thevanillaninja Samba Member
Joined: October 10, 2004 Posts: 704 Location: Scott, IL
Posted: Thu Nov 17, 2005 1:19 pm Post subject: |
4x4EATR wrote: |
that's why you were asking about twin turbos? for fuel efficiency? _________________ 1967 Zenith Blue Type 1 "Elaine"
Bought in 2004
Stored for 4 1/2 years and soon to be resurrected..
'67 beetle |
Posted: Thu Nov 17, 2005 7:25 pm Post subject: |
subybaja wrote: |
Slick setup!
thats not a radiator. its an intercooler for the supercharger. if you look, the radiator lines run under the car. the rad is in the trunk.
i did have to cut the firewall, i only really needed an extra inch or two, but my new one is about 4-5 inches back for clean, covered mounting of sensors and stuff. |
Posted: Fri Nov 18, 2005 9:52 am Post subject: |
Of course it's for fuel efficiency! You mean a turbo's gonna make it go down?! |
Posted: Sat Dec 24, 2005 5:05 pm Post subject: |
today i finished the back half of my cage, except for seat belt mounts.
dont mind the mess, or uh, wiring. it still needs redone.
i also got my front hoops welded in. still need a brace under the dash and above the windsheild.
i also messed around in the mud a little.
i know i didnt do as near as much as jowlz, but i did get some stuff done. |
dr. awsome Samba Member
Posted: Sat Dec 24, 2005 8:18 pm Post subject: |
just a question. Are these top tubes in the pic but jointed?
If they are that's a pretty bad idea and should be re-thought. If you still want to keep it that way you should at lest sleeve them. _________________ is it time to get out of the dirt and switch to the street? |
