Horsepower out of a 1200?
Shrapnelized
Shrapnelized is offline
PostPosted: Sun Aug 28, 2005 6:48 pm    Post subject: Horsepower out of a 1200? Reply with quote
Own a 62 Bug with original 1200. Wondering how to get some more power out of it. I understand that you can install Big Bore 83mm pistons/cylinders instead of the stock 77mm. Should you then add a larger carb? Do they have a slightly larger cam? Can you remove the 90mm distributor and add a 009? Then I could add electronic ignition for better response. Don't want to spend the large amount for a Judson.
Steve22
Steve22 is offline
PostPosted: Sun Aug 28, 2005 7:48 pm    Post subject: Reply with quote
have you done a search yet? I started a thread last week dealing with this.
http://www.thesamba.com/vw/forum/viewtopic.php?t=130453
Glutamodo will wander by at some point and probably tell you the same thing...
'65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Aug 28, 2005 7:50 pm    Post subject: Reply with quote
Judson or Okrasa, but both are BIG bucks.
Even with a 50% increase in horse power, you're only talking about 60hp.
Glenn
Member #1009
#BlueSquare
az350x
az350x is offline
PostPosted: Sun Aug 28, 2005 8:07 pm    Post subject: Reply with quote
I just put a 009 in my '65 w/1200 last week, no problems. Don't know what I had to begin with though....
Shrapnelized
PostPosted: Sun Aug 28, 2005 9:21 pm    Post subject: Reply with quote
Thanks for the help!!
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Sun Aug 28, 2005 9:57 pm    Post subject: Reply with quote
Why?
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sun Aug 28, 2005 10:30 pm    Post subject: Reply with quote
some more 1200 threads:
http://www.thesamba.com/vw/forum/viewtopic.php?t=123839
http://www.thesamba.com/vw/forum/viewtopic.php?t=124701
And yeah, i echo that, "why?" comment. Unless the old distributor was junk, there won't be much or any difference when you go to an 009. on a 40HP motor it won't be as big of difference as on the later models, but the 009's often run worse than the stock distributors.
http://www.thesamba.com/vw/forum/viewtopic.php?t=128485
andy
