bubba Samba Member
Posted: Wed Apr 13, 2016 7:46 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Eric&Barb wrote: |
Is it that your old tires are 26.53" tall? If so, what is the tire size on the sidewall? |
Sorry.. my bad.. the new tires height is going to be around 27.53" tall. _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
srfndoc Samba Member
Posted: Tue Jun 28, 2016 1:17 pm Post subject: |
The price on these have dropped, now $62.99 each. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Jun 28, 2016 4:23 pm Post subject: |
srfndoc wrote: |
The price on these have dropped, now $62.99 each. |
Interestingly, that site show the Copper Discoverer 195R15 still available for almost $200 each! I thought they were discontinued, and the last set I bought was half that price. _________________ nothing |
Don66bus Samba Member
Posted: Tue Jun 28, 2016 6:12 pm Post subject: Re: Cooper Discoverers |
I'm running Cooper Discoverer H/T 205/75R15 that I bought for about $140 (Canadian) in 2012. I have no complaints. |
Posted: Wed Jun 29, 2016 9:24 am Post subject: |
cdennisg wrote: |
srfndoc wrote: |
Interestingly, that site show the Copper Discoverer 195R15 still available for almost $200 each! I thought they were discontinued, and the last set I bought was half that price. |
Maybe old stock? How long ago were they discontinued? I saw the same thing happen with the Nexen SV820's. They were discontinued and then seemed to show up again at retailers. Either someone found an old stash of them or the factory did another run. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Fri Jul 01, 2016 4:21 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Since these dropped in price so much and I'm running around on tires dated 9 years old I figured it was time to upgrade. These ride SO much better than the 205/65/15 passenger tires I had on there previously.
Thunderer Ranger R101 - 195R15, Load Range D, 8 ply with a load rating of 2094 lbs:
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sat Jul 02, 2016 5:06 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
srfndoc wrote: |
Can you take a pic of the tread pattern? |
joefriday Samba Member
Joined: November 30, 2015 Posts: 179 Location: Richland WA
Posted: Sat Jul 02, 2016 10:35 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Nice bus and tires. Does the tire/wheel fit behind the seat? Also Eric, if you click on the link above there are pics. Although it does say pic may not be accurate so a pic from mafia would be cool. |
Posted: Sat Jul 02, 2016 10:42 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
buseric wrote: |
srfndoc wrote: |
Added the pic to my original post. I have a walk thru bus but these will not fit in the spare tire area as they are too wide. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Sat Jul 02, 2016 11:17 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Thanks for the info. I've been reading up for a while. Look good on your bus and seem like a good value so I pulled the trigger. Eating beans for another month! |
dualport Samba Member
Posted: Sun Sep 04, 2016 4:05 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Vredestein Comtrac 205/70R15 106, Load range D. Purchased off eBay from Tires Easy, shipped quickly.
The fronts are pushed out as I have a SACO front disc brake setup. I'm planning on putting in rear spacers as I now have at least a couple of inches of clearance back there and visually it looks a bit odd.
For comparison, I rolled up my old 14" rim with the original BFG Silvertown 4-ply.
_________________ Conrad @ Air Coolers VW Gang http://aircoolers.org
Air Coolers Google Map of clubs, services and shops: https://goo.gl/3KM4wm |
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
fabfriar Samba Member
Joined: December 17, 2008 Posts: 27 Location: Lompoc, CA
Posted: Fri Oct 28, 2016 8:36 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I ordered the Thunderer Ranger R101 195R15C from Tires-easy.com, was $338.84 delivered to my door, plus I had to pay $60 at my local tire shop to get them mounted and balanced. I tried to mount them by hand but it was a no-go. These tires replaced the lousy 165R15 tires that were on my single cab. The handling and ride are so much better with these new tires, and the speedo is now reading correctly. Highly recommended!
Posted: Fri Oct 28, 2016 10:10 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
fabfriar wrote: |
I have about 500 miles on the same tires now and they have been great. I'm running the backs at about 40lbs and the fronts at 35lbs since I'm running them on a Westy which tends to be a bit heavier than a standard bus. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
obus Samba Member
obus Samba Member
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jan 22, 2017 7:05 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Is the weight rating at least 1525 Lbs.? Is the speed higher than you could ever do in the bus?
https://duckduckgo.com/?q=achilles+195-70-r15&t=canonical&atb=v48-4&ia=web
Might be tight to get into the pre-early 1962 rear wheel wells though. _________________ In Stereo, Where Available! |
obus Samba Member
Posted: Sun Jan 22, 2017 7:35 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Those are a little on the smaller diameter size. Stock was about 27", so you will read a little high MPH.
205/75/15 would be much closer. _________________ In Stereo, Where Available! |
Posted: Sun Jan 22, 2017 10:35 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Why not just get a set of 195R15's and be done with it? Hankook, Yokohama, Thunderer Ranger, Nexen (maybe), lot's of them available in 15" size. _________________ nothing |
