65Swngr Samba Member
Joined: February 15, 2005 Posts: 86 Location: Long Beach
Posted: Mon Sep 05, 2005 7:05 pm Post subject: pan switch for a 65 square |
just wondering what pan i can use to swap the pan off a 65 square? got an extra one off a 70's square but the original pan off the 65 is pretty bad so what year can i switch the pan with? up too a 66? or how late of a model? is there a difference with a later models? _________________ 56 Oval- sold
65 1500S squareback- sold
66 Squareback
87 cabrio- daily driver
new update
speedo works now started at 74851
now- 83116 |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Mon Sep 05, 2005 7:09 pm Post subject: |
a late square will be IRS rather than the swing arm rear suspension... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Sep 05, 2005 7:10 pm Post subject: |
The "pans" are the same all the way through.. It is the rear suspension that is different. Swing axle versus IRS. IRS started in 1968 on the automatics, and continued on all T-3's with the '69.
The only thing to watch with changing pans, is that the title in most states goes with the pan and not the body. The VIN number under the rear seat is the legal VIN as far as law enforcement and VW goes. The others are too easy to swap. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Mon Sep 05, 2005 7:18 pm Post subject: thanks |
not to sound dumb but whats IRS? so ur saying its all the same except the rear suspension? im thinking of finding another pan or just use the one i have for the 65... _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
Posted: Mon Sep 05, 2005 7:31 pm Post subject: |
Independent Rear Suspension. Has CV joints.
Your '65 would be swing axle, but the suspension portion is interchangable. You could reuse your old one. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Mon Sep 05, 2005 7:40 pm Post subject: |
cool thanks! i'll take a closer look at it! right now im getting the drum frunt bracks done.... hope to drive it again soon. _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Tue Sep 06, 2005 12:31 am Post subject: |
I surjest you keep and repair that 65 pan if you want to keep calling it a 65. |
Posted: Tue Sep 06, 2005 1:59 pm Post subject: |
just checking out my options before i do the job, and hopefully soon before my frunt suspension falls off _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
sofaking Samba Member
Joined: January 24, 2005 Posts: 151 Location: Orange County
Posted: Tue Sep 06, 2005 2:40 pm Post subject: |
Why would your front suspension be falling off? The bulk head is more a part of the tunnel than the pan half's. |
Posted: Tue Sep 06, 2005 3:25 pm Post subject: |
i was just exsadurating, next time i'll add a pic of it and u can tell me what u think..... _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
ChoptopT3 Samba Member
Posted: Tue Sep 06, 2005 3:56 pm Post subject: |
What part of the pan are you looking for?
Choptopt3 _________________ "Build it for you"
"Kody" is here born June 11, 2007
4.5 lbs 19.75"
68 Chopped Squareback
64 Ghia vert (wifes car)
2006 Mini Cooper S JCW, it has arrived!! |
BerT3 Samba Member
Joined: August 18, 2002 Posts: 1569 Location: Antwerp
Posted: Tue Sep 06, 2005 11:27 pm Post subject: |
Quote: |
The "pans" are the same all the way through.. It is the rear suspension that is different. |
Hello,
I did my share of pan swaps in the past.
There are some minor differences.
1: automatic pans don't have a clutch cable conduct - even no cut-out + cover for the shifter coupler at the nose of th gearbox.
2: IRS and Swing pans have different brake line routings at the back.
PITa to swap of create if you don't have both to see the difference. The T-piece copper splitter is in a different position too.
3: Don't forget about the seat conductors !
4: Small acces hole at the shifter base vs seperate piece - No problem though just harder to fit a new shifter tube bushing.
These are them all.
BerT3 |
Posted: Thu Sep 08, 2005 4:57 pm Post subject: |
thanks for the info! now the big question is fixt the old one or just replace it with the 70's pan i got! _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
GjMan Samba Member
Joined: June 05, 2004 Posts: 822 Location: Grand Junction, CO
Posted: Fri Sep 09, 2005 12:14 pm Post subject: |
Also, heater controls are different on early vs. late pans. Not important unless you need to maintain original appearance. |
Posted: Mon Sep 12, 2005 11:45 pm Post subject: i got it |
http://www.thesamba.com/vw/forum/album_page.php?pic_id=226930
here is one pic of the frunt pan... so should i still try to fix it or just swap it? _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
Posted: Sat Dec 24, 2005 4:26 pm Post subject: should it be done? |
i got picture of the 70's pan, just wondering if i should repalce the pan from my 65 square with this 70's one? if not can someone huck me up with a 65 square pan? _________________ 56 Oval- sold
66 Squareback
new update
now- 83116
rustyfastback Samba Member
Posted: Sat Dec 24, 2005 5:56 pm Post subject: |
That '70's pan you have in the gallery is really nice. The problem is it is from a '72 or '73 model that uses the later style seats, also a different location for the heater controls. I personally would fix the '65 pan with the pan haves from the other '72/'73 pan you have. You will have to weld your outer seat tracks on the pan. You will also have to remove the center (triangle shape) seat mount. I looked at the pic of your frame head, is it rusted through on the bottom? I think a good welder could fix this also. I still wish I had that choice pan sitting in my garage, as I need one for my '65 square. |
pitslayer Samba Member
Posted: Sat Dec 24, 2005 7:42 pm Post subject: |
if thats all there is then i would repair, it would be easier to cut out and weld a new plate into it than putting new pans in |
Posted: Sat Dec 24, 2005 11:15 pm Post subject: |
there is anew update, the forks on the frunt suspension or frunt head is roted all the way, i had a small incident with the square as a result bent the frunt right head a little. now the frunt right side drops a little more than the left side i can try fixing the pan need a new frunt fork head thing for the 65 pan... so what do you think? i'll get some new pics of the damage _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
Posted: Sun Dec 25, 2005 10:51 am Post subject: |
jack it up try get some good pics of everythings that damaged or gone, and take a pic of it when its on the floor aswell
im not sure what you mean by frOnt head thing, thow or frOnt right head either |
