65Swngr Samba Member
Joined: February 15, 2005 Posts: 86 Location: Long Beach
Posted: Mon Jan 09, 2006 2:52 pm Post subject: |
there i did it!! I took the square to the michanic and they razed that shit up in the air like 6 feet, my good buddy who is a VW michanic and some other folks looked at it and said they never seen such a rotted pan before.. well anyhow they said there is no way possible to fix the pan, even the middle part of the pan u know the pipe thing has holes under it.. so i have no choice but to replace it with the 70's pan....
o yeah i was wondering if i can use my 5 lug suspension and put it on my 70's pan or do i have to replace it... _________________ 56 Oval- sold
65 1500S squareback- sold
66 Squareback
87 cabrio- daily driver
new update
speedo works now started at 74851
now- 83116 |
Posted: Tue Jan 10, 2006 1:58 am Post subject: |
well..... somebody tell me! _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
howiesfamily Samba Member
Joined: March 31, 2004 Posts: 858 Location: Panther City, Texas
Posted: Tue Jan 10, 2006 8:23 am Post subject: |
you can swap the suspension. I have a '69 pan under my '64 Notch, but it has the original 5-lug '64 suspension. The front beam and the complete rear suspension were swapped over. _________________ member of: Fort Worth Aircoolers Gang |
3squared Samba Member
Joined: August 27, 2004 Posts: 23 Location: las vegas, nevada
Posted: Tue Jan 10, 2006 6:10 pm Post subject: |
Howies right the complete rear subframe unbolts in one unit so the tranny aand all that fun stuff does not half to come out. There is a plate on the under side of the pan with four small bolts and one bigger one. there are also four more bolts to unbolt, two at the shock towers and by the spring plate area. The whole 65 rear end can be mounted to the 70's or later pan with out any trouble. Good luck have fun... Been there done that |
toddgsanford Samba Member
Posted: Tue Jan 10, 2006 9:25 pm Post subject: |
this may be a little late based on the original post but from experience The 65 and at least a 70 pan are slightly different in all the ways prev described but also the wheel wells in the front are slightly different meaning the heater channel will not 100 percent line up. I had to install heater channels on my 65 notch I used a 70 donor Fastback all I had to do to accomodate this difference is cut a wedge in the wheel well and pull it in than weld and patch the wedge. sounds confusing but I would be happy to share pics. also the mounting of the engine is entirely different and compared to the heater channels was a bit of a challenge my 2 cents says weld in the pan halves |
Posted: Tue Jan 10, 2006 10:00 pm Post subject: |
Well i know about the back part but thanks for the info..... what im worried about is the front beams, the part that holds the front suspension.. can i add my 5 lug suspension to the 70's pan? Becuse the original one is rotted all the way and i dont think it can hold for much longer
this part is what im concern about? i hope i can still use my 5 lug suspension and add it too this one.....
http://www.thesamba.com/vw/forum/album_page.php?pic_id=245195
about the pan half.... the original pan is completely gone even the center tubing has holes, I had my VW buddies see it and lifted the square on hydraulics about 6 feet up and its gone... there’s no choice but to replace it... it would be more work trying to fix it... anyhow I took pictures of it but having trouble loading it too my computer _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
Posted: Wed Jan 11, 2006 7:55 am Post subject: |
If the front beam on the 65 is good, you can unbolt it and it should bolt right up to the 70 pan. You can leave all of the steering components in place and just disconnect the column. Should be an easy swap if you have someone to help you lift it. I pulled one by myself and they are a pain to move around without help. _________________ member of: Fort Worth Aircoolers Gang |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Jan 11, 2006 9:02 am Post subject: |
And if the beam is no good, you still can swap all the brake parts from the backing plates out and fit it all. Just make sure you start looking for and buying brake parts now, because eventually you'll have to rebuild your brakes and the early Type 3 brakes are not cheap. I just redid mine and now I'm looking for parts again so I will have spares on hand for everything. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Posted: Wed Jan 11, 2006 9:07 pm Post subject: |
thanks!! i hope it goes smooth, what about the shifting stick thing on my 65 can i still put it in the 70's pan?
im just trying to get as much information as i can before i start but damn pics i cant load them up too my computer so u folks can see how bad it is
but i'll keep trying
besides that thanks alot for the info _________________ 56 Oval- sold
66 Squareback
new update
now- 83116 |
