SeVVenth Samba Member
Joined: August 18, 2005 Posts: 678 Location: Winterset, Iowa
Posted: Thu Sep 22, 2005 1:31 pm Post subject: Case Mating Surfaces |
Just wondering, but what do you guys do for the mating surfaces? Make them clean as hell and slap it together, or do you put in some liquid gasket like stuff? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Thu Sep 22, 2005 2:38 pm Post subject: |
I use Permatex Aviation sealer on the case halves. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
vicsvw Samba Member
Posted: Thu Sep 22, 2005 9:11 pm Post subject: |
What about ultimate grey? |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Fri Sep 23, 2005 8:26 am Post subject: |
SeVVenth wrote: |
If that's silicone, no.
Use Permatex Aviation sealer like Dave suggested.
That is the only thing I've ever used. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
jamestwo Samba Member
Posted: Fri Sep 23, 2005 10:48 am Post subject: |
you have to have a non harding sealant. silicon will harden and may prevent the case from seating correctly. This in turn will affect bearing crush.
Best thing is to get both case halfs clean and use a thin coat of aviation sealer. although they do make a non harding silcon sealant that you can use. I used it before , but it's real greasy and I didn't like it. |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Fri Sep 23, 2005 1:55 pm Post subject: |
SeVVenth wrote: |
I think that's the Permatex name for the "Hondabond" stuff. I wouldn't suggest using that stuff because once its together it just flat doesn't want to come apart. I would be afraid of braking the case when trying to split the halves. |
RonR Samba Member
Joined: October 03, 2004 Posts: 169 Location: Hesperia,CA
Posted: Fri Sep 23, 2005 7:51 pm Post subject: case sealer |
Ya, stay away from that "Yamabond" stuff. You dam near have to machine it off. Aviation "Form-a-Gasket" is what I use on all my cases. Never leeks. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sat Sep 24, 2005 9:30 am Post subject: |
"Moust use Curl-2..."
SeVVenth, "vics" meant Curil-2. Might not find it in a better auto supply store if you don't have it spelled right.
Also consider "Hylomar", which I've used recently with success, but I've only built about ten engines; the other fellas probably tens of dozens and can therefore observe the results of their sealants quicker than I can with mine. |
