Nicksan Samba Member
Posted: Sat Oct 01, 2005 5:11 pm Post subject: Opinions needed.....I know, another what should I do post :) |
Should I try to taper the holes in my stock Kinpin spindles with a file and drill bits so the ford tie rod ends will fit or should I just dish out the 70 bucks or however much it is for heim ends and the misalignment adapters, if I can find some that will fit the ford threads in my tie rods.
This was really poor planning on my part because I had to have disk brakes up front and the combo spindles use those darn balljoint backing plates
Thanks for the return pm shmo. |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Sat Oct 01, 2005 6:02 pm Post subject: |
If you have the same tie rods that I used as a model they will take 5/8" 18 thread if I remember correctly. That would mean 5/8" heims.
I sacrificed the disk brakes up front and went combo. I reasoned that most of the weight of my Baja is in the rear..so I went disk rear with drums up front. Someone could make a fortune making a disk brake set up that wasnt $700. As I would go that route if the cost wasnt so crazy.
I would drill and taper the holes out in your spindles and give the Ford ends a go if you have them. If you dont like something about the fit..switch to heims. I think you will still have to drill out the spindles to accomodate the hardware with 5/8" heims.
My memory isn't the greatest and I would have to look at what I have at the house..but this seems right to me. _________________ The honey-do list put my project on hold....... |
Posted: Sat Oct 01, 2005 6:37 pm Post subject: |
Yea your right. I remember the other thread now. I will still need to drill out the spindle for the 5/8th heim but the benefit would be that I would not need to taper the hole and the heim would be a better fit but of course I would need to sink even more money into my baja........errr......parking lot baja. lol. |
USMCord1 Razorback
Posted: Sat Oct 01, 2005 6:40 pm Post subject: |
It depends on which you have more of, time or money _________________ For a Good time |
SHMO Samba Member
Joined: July 29, 2004 Posts: 1647 Location: Lynden, Washington
Posted: Sat Oct 01, 2005 7:23 pm Post subject: |
And, you don't have to drill out the steering arm as large as you might think. There are high misaleignment adapters that can accept 1/2 stud to 5/8 heims. Furthermore, there are adapaters that can go directly from a tapered mount to a heim, basically that route is a direct bolt in. Something to think about.
SHMO _________________ SHMO's Baja |
Posted: Sat Oct 01, 2005 8:01 pm Post subject: |
I might take a trip to kartek tomorrow to see if they have what I need. |
