halfgut Samba Member
Posted: Sun Oct 16, 2005 7:23 pm Post subject: windshield hinge question |
How do I remove the windshield from the car? On the outside of each hinge that holds the windshield to the car are two screws. The inside of the hinge appears to be welded. Is there a proceedure? I need to straighten the hinges and then reattach them. |
Pinky Samba Ass Bandit
Posted: Sun Oct 16, 2005 8:33 pm Post subject: |
There should be bolts holding the hinges to the hood. Undo these and you can seperate the windsheild frame from the hood. If it's welded... you've got some work to do... |
MedicTed Samba Member
Joined: August 12, 2005 Posts: 2110 Location: King of Prussia, PA
Posted: Sun Oct 16, 2005 9:22 pm Post subject: Re: windshield hinge question |
halfgut wrote: |
The spot that your looking at is where the hinge mounts to the upper windshield frame. It's very likely that those screws will strip if and when you try to remove them. _________________ Ted Wojton
70 VW Bus Westfalia camper
2003 GMC Sierra |
Posted: Sun Oct 16, 2005 9:35 pm Post subject: Re: windshield hinge question |
MedicTed wrote: |
The spot that your looking at is where the hinge mounts to the upper windshield frame. It's very likely that those screws will strip if and when you try to remove them. |
Thought he was talking about the lower frame-
To lessen the chance of stripped screws, take an old screwdriver (make sure it has a nice crisp tip), put an acetylene torch on it, and bend a 90 degree angle an inch or two from the tip (just stick it in a vice with the tip down, heat the outside part of the angle you're trying to bend, and set you're weight to it until you have the angle you want). If you have access to a welder, weld on a little plate on top of the bend so that you can press down and get some weight on it. If it's a long screwdriver, you'll get a lot of leverage and will be less likely to strip the screw. We all know how a drill can just sit there and ride the screw head and strip the sucka out before you know it. I've found this tool to work very well. There are tools sold like this (without the plate), but I've never seen one that's nice and long so that you can get the ones that are really stuck. Impact tools can strip it before you know whats happening too. Eh, hope it helps. Good luck! |
Posted: Mon Oct 17, 2005 8:37 am Post subject: |
Actually, the two outside screws are loose and come out very easily on both hinges. It's the inside part of the hinge that I'm concerned with. It looks like it's welded.
The reason I want to remove the hinges is that the outside upper edge of each hinge is pulling away and there is surface rust forming in the gaps. If there is an easy way to get the hinge to lay flat to the windshield without taking it off that would be preferable.
So, how do I get the inside part of the hinge off?
Halfgut |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Mon Oct 17, 2005 9:58 am Post subject: |
the hinge is spot welded to the lower windshield frame. if i understand you correctly, the rust is forming above the screws, where the hingeplate meets the upper windshield frame? the hing plate should fit flat against the upper windshield frame. if there is a gap here, it may be because someone has tried to pry the frame apart at some time in the past. to solve the problem, disassemble the frame and straighten the hinge plate, deal with the rust, reassemble, and then seal the hinge plate/windshield frame joint with some seam sealer, if you wish. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
Posted: Mon Oct 17, 2005 12:19 pm Post subject: |
Yes, rust is forming above the hinge where it meets the windshield frame.
What's the best way to remove the spot weld?
Also, what was VW thinking in putting two screws on the outside and spot welding the inside. If they wanted to make it removeable why not put four screws per hinge. If they didn't want it removed why not spot weld the whole thing? |
Posted: Mon Oct 17, 2005 2:25 pm Post subject: |
halfgut wrote: |
The hinge is made as part of the bottom of the windshield frame. The reason that the frame is able to be seperated is to replace the windshield. Remember that the 181 was designed for the Bundeswehr (German Army), and therefore needed to be easy and quick to maintain and repair. _________________ Ted Wojton
2003 GMC Sierra |
DraginInk Samba Member
Joined: March 02, 2003 Posts: 1945 Location: Down By The River
Posted: Tue Jul 17, 2007 3:29 pm Post subject: |
Grave digging here
I'm switching out a windshield but on the replacement windshield I have a broken hinge. The hinge (I need the piece that attaches to the hood) on the original windshield is in good enough shape for a switch IF.... if I could get that damn'd hinge pin out. AND I'll need to remove the same pin on the replacement windshield to remove the broken bit. Bangin' on it with a hammer and beat up screwdriver doesn't seem to be the answer
Any magic juju available out there to make this a clean easy removal and install.
Mahalo _________________ PHUCKANCER!!!
Aloha HBB & Mr. Wolfe |
Posted: Thu Jul 19, 2007 11:12 am Post subject: |
So taking that hinge pin out has never been approached by any forum members.... dang
Guess I'll just get a bigger hammer _________________ PHUCKANCER!!!
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Fri Jul 20, 2007 5:56 am Post subject: |
Didnt the thing shop sell a stainless steel hinge for the windshield?
Would be nice if there was a rivet or threaded tube/screw kit for the hinges. |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Fri Jul 20, 2007 6:44 am Post subject: |
FreakCitySF wrote: |
Try these people http://stores.ebay.com/VolksBolts Fast service and delivery. They may be able to answer your questions about SS fasteners.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Green Thing Samba Member
Joined: May 17, 2007 Posts: 1 Location: Lemon Grove, CA
Posted: Fri Jul 20, 2007 8:49 pm Post subject: |
Are you replacing lower frame, upper frame or windshield? I'm confused, there is 3 pieces to the windshield. |
