falldownjaeger Samba Member
Joined: August 28, 2009 Posts: 25 Location: Colo Spgs
Posted: Thu Sep 24, 2009 11:56 am Post subject: |
I've got the phone number for the guy in Rocky Ford, CO rewelding the 5-lug VW center into 5.25" and 200x16 outer rims. |
MatPL Samba Member
Posted: Sun Oct 25, 2009 4:12 pm Post subject: Own project |
Hi everyone. I would like make own kubelwage. Firstly I should tell I am from Poland.
colud you tell me how engine did you used in your projects?
and where did you get a plans with physical characteristics?
I will be thankful if some one will add some links to page with some self-help book how to do this. |
Posted: Sun Oct 25, 2009 4:47 pm Post subject: Re: Own project |
MatPL wrote: |
Mat,
Ken's almost step by step Topic you're reading now is the closest you will find. I'm also starting a home-build Kube, using a Dragon 1:6 scale Type 82 model kit to scale up.
There are two other home-build Kubelwagen topics in this section, the Tuscon Kubelwagen topic has some good construction tips.
If you want to go fiberglass instead of metal, this guy in Romania is building one in glass:
http://www.vw166.com/forum/viewtopic.php?f=9&t=709
IF you are going to run it on the Autobahn, no way would I go with the original 25hp or even 30 hp engines. Minimum, go 1600cc, unless you want to build an original-look engine.
Good luck! I know I'm going to need it, too!
T
www.kampfgruppevonrybus.com |
vintagemx0 Samba Member
Joined: October 07, 2005 Posts: 427 Location: Portland, Oregon USA
Posted: Tue Oct 27, 2009 5:41 pm Post subject: |
I have a 1600cc in my car, and the real limiting factor with speed is the gear reduction boxes. I have the 1.4 ratio RGBs and I have a top speed of 50 mph. I haven't checked it with a tach, but beyond that it sounds like its just spinning too fast. I calculated that the 1.25 ratio RGBs would let me go about 55 with the same "comfort" level. Maybe some day... I've had 4 adult males in my car and really felt the load and felt better about having a 1600 in there.
Falldownjaeger - I received your e-mail about your question on the lever shocks. I can't remeber what application they were for, but they were '30's era American-made Delco brand. I found them on E-Bay and bought them because I knew I could adapt them to work. Begin a thread on your build! I'm sure I'm not the only one that would enjoy following along. Best of luck!
Ken _________________ Where ever you go, there you are. |
typ82kubelvw Samba Member
Posted: Tue Oct 27, 2009 9:36 pm Post subject: |
didn't some say they looked at using Snomobile dampers for the rear shocks? _________________ 62,65,69beetles |
Clark Kustoms Samba Member
Joined: October 09, 2006 Posts: 798 Location: las Vegas
Posted: Wed Oct 28, 2009 9:53 am Post subject: |
Clark Kustoms wrote: |
I think i would do my replica alittle... different. |
sacrilige! |
Posted: Fri Oct 30, 2009 11:11 pm Post subject: |
No Comment...
LeviMan2001 Samba Post Whore
Posted: Fri Oct 30, 2009 11:22 pm Post subject: |
It's not that I don't like customs, that's just not attractive. Perhaps, remove the top and spare wheel, then tub out the origonal fenders for slamming. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs |
Posted: Fri Oct 30, 2009 11:33 pm Post subject: |
Yeah, not very attractive at all. Kubel's are kind of wierd already, but that's down right bizzare. I'm thinking some things just can't pull-off the whole slammed thing. Besides, one of the best things about a kubel is it's ability to go just about anywhere (without scraping...).
SpitnSpatz Samba Member
Joined: February 01, 2009 Posts: 77 Location: wilmington, delaware
Posted: Thu Jan 14, 2010 3:13 pm Post subject: |
Sorry to resurrect an old thread (killed by the above photo-chop I believe!), but there was some discussion about 16" repro wheels that some folks had made from chevy 16" barrels and 15" smoothie centers and some ideas thrown around about using compact spare rims :
falldownjaeger wrote: |
jns wrote: |
I think a separate discussion of 16" rim options might be interesting. I have original kubel rims on my car, but none of them are really round and it's pretty annoying. One of them even blew out a few months ago (the actual wheel, not the tire). Since no one makes repros as far as I know, it's a pain.. |
Blue Baron wrote: |
Has anyone looked into rewelding the VW centers into 16-inch space-saver spares? That would seem to be the solution. They're narrow, have safety beads and can be found extremely cheap! |
...has there been another thread started on this topic or a few leads I could get for some shops that have done this kind of work? Any experiences/actual costs/pictures? Original Split or Barndoor wheels are out of the budget and the vintage tires I want to use on my project are only available in 16"...
Any info appreciated!! |
vwclap Samba Member
Joined: April 21, 2004 Posts: 519 Location: Qc, Canada
Posted: Thu Jan 14, 2010 6:21 pm Post subject: |
front wheel are too big but beside that I think it is OK!
Claude _________________ Claude
cox 1956, 1962 et 1975
Split panel 1963
Samba 21 fenetres 1966
Ghia 1968
Sport Ghia 73
West 1970
Jetta 1992
Jetta TDI 2015
West Multivan 2002 |
Posted: Thu Jan 14, 2010 6:27 pm Post subject: |
...now why did ya hafta go and do that Claude... |
Posted: Mon Jul 25, 2011 9:38 pm Post subject: July 25, 2011 update |
I've been driving this car around town for quite a while now, but this last weekend I drove it into the mountains and did a little "off-road" with it. From Portland, I drove out Highway 8 and merged onto Highway 6. I went to Browns Camp on the summit of the pass. I used to ride dirt bikes up there alot. There are literally 100's of miles of trails and logging roads.
The gearing is low. 50 mph runs around 3400 RPM, and I don't care to run the motor harder. I was able to maintain 50 mph all the way there (about 45 miles) with no problem - it ran real smooth and strong. I wondered what was going to happen when I had to climb the grade approaching the summit on the highway, and was delighted to find that I could maintain 50 mph effortlessly.
Turning off the highway into the OHV area, I pulled over and folded the windsheild down. Then, just went driving into the area and exploring some roads I used to know very well. I went to one place in particular that I knew was steep and rough and climbed up onto a vista that over looked a vast scenery of forest land. Awesome. I then drove back down from the vista and just drove around some of the roads for a while, then returned to the highway and took a nice long ride back home.
This is the first time I have ever drove this car in such a long round-trip, and the first time I took it "off road". It performed wonderfully on both counts. I was really impressed with the off road capabilty. The low gearing that seems like a pain in town pays-off big time in the woods. The thing is mountain goat! It crawls effortlessly up steep, rough, rocky terrain. Going down steep terrain, I just put it in 1st so I wouldn't have to ride the brakes and it just crawls down - smoothly and sure-footed.
I didn't hit any trails because I don't have an OHV tax sticker on the car and the area was busy with forest worker trucks on patrol. I am definately going to get a sticker soon and be going up there quite a few more times before the weather changes as I have found where this car really shines.
When I was up on the vista, it dawned on me that I had not taken a camera - so maybe after I've been back up there a couple of times I'll have a couple of interesting photos to post.
Between the long and scenic county-roads to get there, playing in the woods, and the long drive back home - it's a pretty fulfilling day of kubeling.
Take care,
mircea cotiga Samba Member
Joined: June 28, 2008 Posts: 82 Location: bucharest Romania
Posted: Mon Jul 25, 2011 10:35 pm Post subject: |
Nice to see you happy again...I have to wait for some this kind of fun . _________________ I always know when I'm stupid, so, don't tell me! |
Kraftfahrer Samba Member
Joined: January 26, 2008 Posts: 165 Location: Bavaria
Posted: Tue Jul 26, 2011 12:53 am Post subject: |
Hi Ken, good to hear you´re "using" the kubel and having fun with it !
Can´t wait to do some off road action with my kubel, too...
cheers,
CHRIS |
VWKDF Samba Member
Posted: Tue Jul 26, 2011 7:07 am Post subject: |
If you look at this picture you'll see that someone at VW wanted to slam the early reduction box vehicles. (note the VW symbol) |
Posted: Sat Aug 06, 2011 9:16 pm Post subject: |
We went back up to the coastal mountains in the Tillamook National Forest. From the Portland area, we travelled down Highway 8, and then got onto Highway 6 and up into the forest. It was about 100 miles round-trip with an estimated 30 miles of scouting some of the 100's of miles of roads in the forest - so about 130 miles of kubeling on a nice sunny day.
This is pretty much what the average road looks like in there. We went up and down some pretty steep ones too.
Our grandaughter Olivia had a good time. She has always liked to ride in "The Kubel"
I have ridden dirt bikes up there for years, but never ventured near the horsecamp. It's a camping area for people with their horses. We kubel'ed in there to have a look. Pretty neat place.
We were only about 15 miles from the ocean. Perhaps on my next post, I'll have some shots of the car near the ocean.
Best regards,
BNMike Samba Member
Joined: November 12, 2009 Posts: 333 Location: Hot Springs, SD
Posted: Sun Aug 07, 2011 7:28 am Post subject: |
Hi Ken.....
Nice work, and great pictures I'm glad to see you are enjoying your build.
BNMike |
engineerscott Samba Member
Posted: Sun Aug 07, 2011 3:57 pm Post subject: |
I remember following this thread a couple of years ago when it started. I still can't get over what an incredible job this guy did in fabing a repro Kubel from the ground up. |
