crunchyinmilk Samba Member
Joined: January 25, 2005 Posts: 8 Location: Everett WA
Posted: Mon Nov 07, 2005 10:49 am Post subject: Lurching Squareback |
Ok, I have 3 of these babys and 1 of them that I can actually drive right now.
It was driving fine a few weeks ago, then decided to die mid-driving - wouldn't idle for more than a couple of seconds. I found that the wire to the air sensor was broke free and fixed that... then it drove fine again all the way from Magnolia to Everett.
The next time I took it out for a run, a couple of days later, it ran pretty good for a few blocks, then began to lurch. I parked it for a couple of days, then drove it again... ran like a top for about 3 miles, then began lurching again.
Swapped air pressure regulator out with one off another square of mine (one that wasn't lurching - but still a used part). Still lurching. Went to swap the throttle control valve, but realized it was an adjustable part - so I adjusted it to match a non-lurching square. Ran like a top - drove it 20 miles city, parked, drove it 20 miles I-5 - awesome.
Went to drive it again this morning and it is lurching again!!!! It was running great just last night!
Whole tank of Chevron before the 40 miles last night. Fuel injector cleaner prior to that. Idles great. Timing is good. No exhaust smells or other clues. Oil light was flickering at stops on the 40 mile run.
Help? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Nov 07, 2005 11:15 am Post subject: |
Run it until it lurches and then check the resistance of the cylinder head temp sensor and the air temp sensor on the intake. Lurching + oil light flickering (hot engine)= too lean. Make sure your ignition timing is correct as well as the point gap first. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Nov 07, 2005 11:29 am Post subject: Points on electric distributor? |
How do I set the points on the electric distributor? |
Posted: Mon Nov 07, 2005 11:35 am Post subject: Re: Points on electric distributor? |
crunchyinmilk wrote: |
It came with points from the factory. It must have has a Petronix or CompuFire installed... unless you are mistaking the big plug in on the distributor body for electronic ignition. It isn't- it's for injector trigger contacts. If there are no points under the cap and an electronic pickup has been substituted, just check the timing and make sure it's right on. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Nov 07, 2005 11:51 am Post subject: You are the smartest person in the world |
Thanks Tram!
I ear time my VWs - the light never seems to work for me. I'll check it with the light this time.
Love your strings - I have a shrine in your honor. I will be making a fresh sacrifice on your alter when Lurch is happy again! |
Posted: Mon Nov 07, 2005 12:01 pm Post subject: Re: You are the smartest person in the world |
Thanks Tram!
Crunchy, one thing to keep in mind on injected Squarebacks- there are additional non- serviceable (except for periodic cleaning/ lubrication) points in the bottom of the distributor where that plug fits. These time the opening and closing of the injectors. If your distributor timing is off on an injected Type 3, you get a double- whammy of BOTH ignition and injection timing being off! You can get by- although I don't recommend it- by "ear timing" a carbed VW, but you can really mess up an injected car's performance that way. You can throw parts at the car all day long, but if the basic settings are incorrect, the car cannot run right.
Thanks for the kudos, and sorry for not being up to speed on current jargon, but "love your strings"??? Was bedeutet das? (What does that mean?) _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Nov 07, 2005 12:25 pm Post subject: Eeeek! |
Ok - I'll use the light. I gave up on it when it seemed like the light said it was right when it was running at it's worst.... I really haven't got a clue what I am doing on any of this - just stumbling through and trying not to fry too many VWs in the mean time. Fortunately, I seem to be doing alright - fixed more than I broke so far.
Thanks,
Jen (aka crunchy)
FYI: strings are what these online email things are called when they go back and forth. |
cwo4smith Samba Member
Posted: Mon Jan 09, 2006 6:41 pm Post subject: Query to Tram |
Hi - this is the closest post I've seen to my problem. 68 fastback - all original/stock - about 42K original miles... drive about 24 miles to work all OK, drive home (highway) about 8 hours later - get about half-way home and the car starts to lurch/buck... easing off the throttle and dropping into neutral sometimes gets back to normal, but generally get some bucking/lurching the rest of the trip home. I am getting a flickering green when the motor is hot (at idle), but I know my oil cooler is probably leaking a bit at the seals, but I have enough (have checked) oil. So - going to Tram's comments - if timing and point gap is OK, then what am I looking for on the head temp sensor in terms of resistance - what's indicative of "bad"? |
Posted: Mon Jan 09, 2006 7:56 pm Post subject: Update |
I never did get to run Trams test... I twidled around with what I believe is the throttle valve switch (noticed it was set different then another square I have) and have barely had any issues since. I don't think I fixed anything - I think my square just decided I wasn't so bad.
Still get a little of the light flickering at stop lights if I am in 1st with the clutch all the way in. Doesn't always do it, and barely when it does.
I was going to check the fuel pressure and my grounds too. I had a fuel pressure issue with a square that bow-wow had rebuilt and I guess they had installed the fuel pressure regulator straight out of the box set at almost 2x the psi. Drowned the fuel injection in gas and even dripped out the tail pipe. I am wondering if it would cause the rich running at stops if the pressure was a little too high. Also hear a lot about the main grounds torturing the sensitive fuel injection but being subtle enough that the fuel injection ends up getting blamed. Sounds like a good theory to me.
Jen |
Mauisquareback Samba Member
Joined: January 09, 2006 Posts: 9 Location: Maui Hawaii
Posted: Fri Jan 13, 2006 7:05 pm Post subject: |
sounds like a bad distributor, to me, had that happen to me, would happen every now and then. i check everything and it ended up being the dist. |
thepotz Samba Member
Posted: Sun Jan 29, 2006 6:41 pm Post subject: surging |
Fuel injection depends on good intake manifold vacuum.
Leaky injector seals cause vacuum leaks and engine surging.
Replace your injector seals to keep your engine running smooth. |
