drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Jan 11, 2012 6:02 pm Post subject: |
Yes you will probably have to cut them off.
Welcome to the wonderful world of 6 band aid axe jobs to try to correct the negative results of one modification.
Don't forget caster shims. _________________ Mother Nature is a Mean Evil Bitch! |
63bugger Samba Member
Joined: February 25, 2008 Posts: 13 Location: Houston
Posted: Fri Jan 20, 2012 10:54 pm Post subject: |
Well guys my lower adjuster bracket broke and now I need to fix it. Right now I had to drive the bug 8miles back home on one adjuster. Ofcourse I had to raise the upper adjuster to pick the front end up a little to get home. My beam is narrowed 5 inches and with shocks. Will it hold up driving I like his until I fix it? |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
kanniff Samba Member
Joined: October 12, 2009 Posts: 811 Location: West Coast
Posted: Mon Jan 30, 2012 1:52 pm Post subject: |
I have a new narrowed adjustable beam 5" that I got with the purchase of a bug. I don't know who built it.
It came with the small bushings like these.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C12%2D6524
I keep seeing the longer bushings and I am wondering which ones I should be putting in.
Thanks. _________________ 1958 PGSG Standard |
JoshPecks65 Samba Member
Joined: June 01, 2011 Posts: 18 Location: Corvallis, Oregon
Posted: Wed Jul 25, 2012 3:36 pm Post subject: |
So i got a 6inch narrowed beam, but i still have to narrow my tierods.
Do i still just cut 3 inchs from each one, or what?
Thanks |
conrad94 Samba Member
Joined: February 02, 2012 Posts: 90 Location: pembroke pines
Posted: Wed Jul 25, 2012 8:35 pm Post subject: |
Germanpride wrote: |
If anyone is out there getting ready to shop for adjusters, let me add my input. If you already know about how low you want to go, then that's great, the 1st step is over. If you just want a mild drop, maybe a traditional Cal-Look style, you can go with either the Avis, or the Sway-a-way styles. If you plan on going LOW...I would suggest skipping the S.A.W. style all together, and just go ahead and get the Avis style. The bottom adjuster bolt on the S.A.W.'s will just grind off, and if you hit something hard enough, you will end up breaking the bolt off, or the entire bottom adjuster. You do not have this problem with the Avis style. (Just speaking from experience..)
A few days of driving around caused this:
While a week or so later it ended up looking like so:
(Notice the missing bottom adjuster all together..) |
how did u narrow your beam ? |
madmax120 Samba Member
Posted: Wed Aug 01, 2012 7:36 pm Post subject: |
So this is my car currently but it handles terrible as its only means of lowering is a beach buggy beam with welded in adjusters set at the highest point. So it can only go lower.....
Long story short I want it the SAME height and wheels as close to the guards but I want it to drive straight. What are my options?
I was thinking get stock beam, narrow 2 inches, new king and link pins, drop spindles (to fix steering geometry) and tie rod ends? |
MichaelJFox Samba Member
Joined: August 05, 2012 Posts: 10 Location: Auckland, NZ
Posted: Sun Aug 05, 2012 12:45 am Post subject: |
Hey man,
I have never posted here before, but been lurking for years.
Mine has a 2" narrowed beam, new shocks and dropped spindles with adjusters.
Is lower in the nose than yours I think and handles fine, almost like a normal car haha.
I'll link a photo;
Edit; I was a little annoyed when yours came on TM haha, so similar to mine, and much less than what I paid. And over rider bumpers haha. Nice though man, where abouts do you live? |
ovalshark Samba Member
Joined: December 26, 2001 Posts: 265 Location: Caldwell, Idaho
Posted: Sun Aug 05, 2012 6:33 am Post subject: rhd |
White on red, right hand drive, very cool ride! |
volkspider Samba Member
Joined: May 08, 2011 Posts: 17 Location: Calgary Alberta Canada
Posted: Sun Aug 05, 2012 9:00 am Post subject: |
[quote="conrad94"]
Whats the difference with removing the bottom bolt altogether?
wouldn't that be same as the lowest setting..you know, just a little lower? |
Posted: Mon Aug 06, 2012 1:17 pm Post subject: |
Serious...I'm bumping this because right now I am running without the bottom bolt in right now and I love how low it sits I just don't want to f@#* things up...is this ok or am I going to die my next sharp turn? |
flyboat Samba Member
Posted: Mon Aug 06, 2012 9:03 pm Post subject: |
Dropped spindles will put the geometry back to something closer to the way the suspension was designed. This will greatly improve handling and driving characteristics. Alot of guys run dropped spindles and a lowering beam. It sounds like there's aproblem with your beam. I'd get a new one. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
jims65 Samba Member
Joined: October 06, 2010 Posts: 14 Location: Pasadena
Posted: Thu Sep 13, 2012 12:27 pm Post subject: |
Hey guys i have a 4 inch narrowed on dropped spindles and 135s. I have a bumpsteer problem that I've been working on for a while. My drivers side tie rod is a little angled, would this cause a really noticeable bumpsteer? Or could this be due to a bad alignment. With a minor adjustment of the drivers side tie rod, maybe toe it in? Would this go away? |
topgun13b Samba Member
Posted: Sat Oct 06, 2012 8:25 pm Post subject: 1960 vw beetl lowered |
I need your advice I got my 1960 bug, and its already lowered and the beam shorted. I would like to rise it up a little bit from the front because its very low and diffecult to put it on the trailer. Could I loose the spindl and take off the two arms that connected to the spindel and the the beem, then move the two arms one step down, and then connect the spindel again? is that going to risa the car a little bit? and is it going to work?
or any way to adjust the beam? any idea? the car almost 2 inch far from the ground lol
I put a four stock old wheels and tires to rise it up a little bit, but the problem they are no enough clearance to turn. The tires almost touching the headlight buckets. There for the old owner installed RBM wheels with a low profile tires. |
Posted: Sat Oct 06, 2012 8:28 pm Post subject: |
Dude I have the same problem. My car looks like yours. I put the original wheels and tires to rise it up but I didnt have any clearance to turn right or lift because my tires very closee from the headlight bucket.
Did you figer something yet??? |
Ace Samba Member
Posted: Sat Oct 06, 2012 8:30 pm Post subject: |
you cant index front torsions at the trailing arms. If your beam is adjustable, there will be an adjuster in the middle of the top and bottom beam tube. |
Posted: Sat Oct 06, 2012 8:34 pm Post subject: 1960 vw beetle lowered |
Do you mean I can adjust the beam by making it wider? and then my tires will not touch the headlight bucket while the turning? |
Ace Samba Member
Posted: Sat Oct 06, 2012 8:50 pm Post subject: |
the adjusters are to raise and lower the car if you have them. When you adjust your front ride height, you usually have to redo the front alignment. |
Posted: Sat Oct 06, 2012 8:53 pm Post subject: |
Thanks for your help. Could you tell me how the adjusters work? and do I need to lift the car to adjusted? |
Ace Samba Member
Posted: Sat Oct 06, 2012 9:08 pm Post subject: |
I need to know the type of adjusters you have to guide you. There are usually 2 different types that could have been used.
They will either look like this
or this
If it looks like this one, it is not adjustable.
You will need to jack up the front end to adjust it.
