econo_bug Samba Member
Joined: March 03, 2009 Posts: 9 Location: Manila, Philippines
Posted: Sat Apr 04, 2009 8:04 am Post subject: |
| Quote: | It can work with an early car because the outer tubes are not stepped. The later ones are as seen here
it is easier to narrow in the center just to save that step. |
Thanks for the prompt reply, airkweld. I appreciate it.  |
Posted: Mon Apr 06, 2009 2:54 am Post subject: |
Airkewld,
By the way, what do you mean by "the outer tubes are not stepped"? |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 1656 Location: Airkewld 2010 is coming... 12/15/09
Posted: Mon Apr 06, 2009 11:14 am Post subject: |
| econo_bug wrote: | Airkewld,
If you look at the picture I posted, you will see that the lower tube is stepped, making it more difficult to narrow from the outsides. _________________ Join our eNews Letter
Twitter feed
info@airkewld.com
Facebook |
Posted: Mon Apr 06, 2009 10:49 pm Post subject: |
| Airkewld wrote: | | If you look at the picture I posted, you will see that the lower tube is stepped, making it more difficult to narrow from the outsides. |
How about on the stock German beams, cutting from the outside isn't also applicable?  |
Posted: Tue Apr 07, 2009 6:27 am Post subject: |
| econo_bug wrote: | | Airkewld wrote: | | If you look at the picture I posted, you will see that the lower tube is stepped, making it more difficult to narrow from the outsides. |
ALL ball Joint beams are stepped. _________________ Join our eNews Letter
Twitter feed
info@airkewld.com
Facebook |
Posted: Tue Apr 07, 2009 11:00 pm Post subject: |
Okay, thanks again, airkewld.  |
weekendwarrior Samba Member
Joined: November 23, 2008 Posts: 45 Location: Charlotte, NC
Posted: Thu Apr 09, 2009 5:05 pm Post subject: |
OK, I have read through this thread, and here is what my question boils down to...
I have a 73 standard, with 165/15 tires. I measure 3.25" clearance between the top of the tire, and the lip of the front fender. If I install 2.5" drop spindles, would that be ok, with the extra .75" of clearance, or is there something I am missing?
My other option is to install the drop spindles, and then trade the front tires for 145/15. _________________ This is my first "old" car, and I am trying really hard to learn as much as I can. 73 Standard Bug |
neil68 Samba Member
Posted: Thu Apr 09, 2009 5:53 pm Post subject: dropped spindles on standard Beetle |
| weekendwarrior wrote: | OK, I have read through this thread, and here is what my question boils down to...
My other option is to install the drop spindles, and then trade the front tires for 145/15. |
I added CB Performance 2.5" dropped spindles to my stock beam, which then caused the 165R15 tires to rub when turning corners. I switched the tires to 145R15 Nankang's and the rubbing was eliminated. Here's a picture with the 145's installed and stock shocks:
 _________________ Neil
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.9 seconds @ 104 mph |
Posted: Fri Apr 10, 2009 4:39 pm Post subject: |
Thanks for the reply. If Iwere to only want to lower the car 1.5"-2", what are my options?
Again, 73 Standard Bug _________________ This is my first "old" car, and I am trying really hard to learn as much as I can. 73 Standard Bug |
Posted: Fri Apr 10, 2009 9:38 pm Post subject: |
| weekendwarrior wrote: | Thanks for the reply. If Iwere to only want to lower the car 1.5"-2", what are my options?
Again, 73 Standard Bug |
Smaller tires or an adjustable beam. _________________ Join our eNews Letter
Twitter feed
info@airkewld.com
Facebook |
Wwildman Samba Member
Posted: Tue Apr 14, 2009 5:23 pm Post subject: |
| Airkewld wrote: | | weekendwarrior wrote: | Thanks for the reply. If Iwere to only want to lower the car 1.5"-2", what are my options?
Smaller tires or an adjustable beam. |
If he only wants to go 2 inches I would do dropped spindles |
davidnino111 Samba Member
Joined: May 05, 2008 Posts: 111 Location: Los Angeles- (626)
Posted: Tue Apr 14, 2009 6:09 pm Post subject: |
just get an adjustable beam.
if it doesnt clear and it rubs then bring it up one step and try again. this way you way youll be at the lower point with out rubbing. my 2 cents |
Posted: Wed Apr 15, 2009 5:53 am Post subject: |
Update
I picked up a set of slightly used, forged drop spindles for $70. I recently put new shocks on the car, and when I measure, I have 3.75" from the top of the tire to the lip of the fender. I am going to try them, and see what happens.
I checked with my tire guy, and he has a couple of 155/60/15 tires I can get for the front if mine rub.
We'll see what happens Friday when I install the spindles. _________________ This is my first "old" car, and I am trying really hard to learn as much as I can. 73 Standard Bug |
6volt "THE" Kabriolet Kid
Joined: April 14, 2007 Posts: 454 Location: North Carolina
Posted: Wed Apr 15, 2009 6:19 am Post subject: |
| good deal on those spindles, can't wait to see pics |
Posted: Wed Apr 15, 2009 7:23 am Post subject: |
I have read all 21 pages in this thread. My question comes down to this...
I have the 165 r15 tires. I know it has been stated time and time again that they will not fit with the drop spindles. I measure 3.75" of clearance between the top of the tires and the lip of the fender.
Should I go ahead and mount the 155/60/15 tires on the front, just to be safe, or is there any chance at all those 165 r15 tires will clear, given the 3.75" I have measured? _________________ This is my first "old" car, and I am trying really hard to learn as much as I can. 73 Standard Bug |
Posted: Wed Apr 15, 2009 7:33 am Post subject: |
| weekendwarrior wrote: | I have the 165 r15 tires. I know it has been stated time and time again that they will not fit with the drop spindles. I measure 3.75" of clearance between the top of the tires and the lip of the fender.
Should I go ahead and mount the 155/60/15 tires on the front, just to be safe, or is there any chance at all those 165 r15 tires will clear, given the 3.75" I have measured? |
If you have that much room they WILL fit.
Understand that if you install shorter tires,t eh car will drop that much more. _________________ Join our eNews Letter
Twitter feed
info@airkewld.com
Facebook |
Posted: Wed Apr 15, 2009 7:36 am Post subject: |
Thanks airkewled for the response...I just wanted to make sure I wasn't missing something.
I feel stupid for having asked that question twice now, but I just don't want to waste time putting on the lower profile tires if I don't have to (I already have them, so I am not complaining about the money, I just don't want to waste the time if I don't have to). _________________ This is my first "old" car, and I am trying really hard to learn as much as I can. 73 Standard Bug |
Posted: Fri Apr 17, 2009 7:03 pm Post subject: |
Well, today I lowered my Bug. It has the IRS rear, and that was a little bit of a pain. I put drop spindles on the front. The tires are 165/15, and they seem to be fine. Like I posted earlier, I got the spindles for $70, and I replaced 1 bearing that was $7.95...so I have about $78 in lowering my Bug. I am happy.
Before:
After:
Posted: Sat Apr 18, 2009 1:06 pm Post subject: |
| Airkewld wrote: | | weekendwarrior wrote: | I have the 165 r15 tires. I know it has been stated time and time again that they will not fit with the drop spindles. I measure 3.75" of clearance between the top of the tires and the lip of the fender.
Understand that if you install shorter tires,t eh car will drop that much more. |
Always good to know that they will fit. Great job, the car looks great!  _________________ Join our eNews Letter
Twitter feed
info@airkewld.com
Facebook |
