TheSamba.com Copperstate Show
Official "Ball Joint" lowering topic
Goto page Previous  1, 2, 3 ... , 22, 23, 24  Next
Forum Index -> Beetle - Late Model/Super
69calbug1114
69calbug1114 is offline
PostPosted: Thu May 21, 2009 2:53 pm    Post subject: Reply with quote
Love your bug. Nice job Very Happy
Cutman
Cutman is offline
PostPosted: Tue Jun 09, 2009 4:33 am    Post subject: Reply with quote
Just finished reading the entire thread and unless I missed it... no mention of "turned beams" to lower the car. I have a beam turned to lower the car 2", drop spindles, and I am in the process of narrowing it 2".
I bought the beam turned and I am doing the rest myself.
Any feedback on turned beams?
bugninva
bugninva is offline
PostPosted: Tue Jun 09, 2009 6:54 am    Post subject: Reply with quote
re-indexing the torsion bars by the cut and twist is no different than re-indexing by adjusters, except the obivous; you can't adjust it.... I've cut and twisted beams many times over the years to both lower and raise the front of the car...
Hotrodvw wrote:
This is the internet......use at your own risk.
The Noof wrote:
Let him do it, but remember...stupid SHOULD hurt.
lanceevox
lanceevox is offline
PostPosted: Wed Jun 17, 2009 10:03 pm    Post subject: Reply with quote
ok, I have an adjustable front beam (not narrowed). I want to lower the rear without creating a backward rake. If I lower the rear 2 outer splines will I be ok? I basically want the rear nice and low without creating an ugly backward rake.
ignore the photo shopped wheel color.
-Nikolai
1970 1600cc SP bug.
1992 VR6 Corrado.
hill climber
hill climber is offline
PostPosted: Wed Jun 17, 2009 10:09 pm    Post subject: Reply with quote
2 splines in the back will definitaly give it a backward rake. 1 spline should just about level it out
70' bug 1600sp
70' bug 1600dp
66' squareback
lanceevox
PostPosted: Wed Jun 17, 2009 10:12 pm    Post subject: Reply with quote
maybe one inner instead of one outer to get a little more of a drop?
-Nikolai
1970 1600cc SP bug.
1992 VR6 Corrado.
bugninva
bugninva is offline
PostPosted: Thu Jun 18, 2009 7:16 am    Post subject: Reply with quote
one inner from stock will net about 2 inches of drop... one outter will get you about 2 1/4 inches...
lanceevox
PostPosted: Thu Jun 18, 2009 8:27 am    Post subject: Reply with quote
according to this http://www.glenn-ring.com/tech/low.html the inner drops it more.
-Nikolai
1970 1600cc SP bug.
1992 VR6 Corrado.
pupjoint
pupjoint is offline
PostPosted: Tue Jul 21, 2009 7:39 am    Post subject: Reply with quote
atye wrote:
Glenn wrote:
Stevie Fierce wrote:
but yes, the bolts you can get at the hardware store. It's just that many hardware stores (Ace, by my house) doesnt deal with a huge variety of metric stuff. they have some metric, just not alot of it.
The ACE by me carries alof of metric hardware and in Grade 8.8.
Just to clarify one thing that I noticed here...
Grade 8.8 metric is NOT the same as Grade 8 standard.
For a hardened metric bolt, the grade is 10.9. Grade 8.8 is very close in strength to a standard grade 5 (non-hardened) bolt.
(borrowed from the Rockford Fastener website)
Metric fastener strengths are rated by "Property Class" rather than "Grades." Metric Property Classes are roughly equivalent to SAE Grade as follows:
Property Class=Min Tensile Stregth
Metric
8.8=120,350
10.9=150,800
12.9=176,900
Standard
5=120,000
8=150,000
Head marking for metric fasteners has the Property Class number stamped on the head together with the manufacturer's identification symbol. Metric nuts also have their Property Class number stamped on one of the bearing sides.
Hope this helps...
The stock bolts that come with the car are 8 Standard?
If i buy bolts from the hardware shop I need to look for 10.9 or 12.9 ?
What do you all use?
lanceevox
PostPosted: Sun Aug 02, 2009 5:26 pm    Post subject: Reply with quote
So I have an adjustable front beam (not narrowed) that is as low as it can go. Right now I am running the ?stock? blue oil filled shocks.. I read that the OPEL GR2 (344098) front shocks are a good replacement and will give better handling seeing they are about 2 inches smaller. Is this a good shock to go with? anybody running them? THANKS!
-Nikolai
1970 1600cc SP bug.
1992 VR6 Corrado.
vendre55
vendre55 is offline
PostPosted: Mon Aug 24, 2009 6:51 am    Post subject: Reply with quote
How i install an avis beam adjusters
69 Jim Premium Member
69 Jim is offline
PostPosted: Mon Aug 24, 2009 7:39 am    Post subject: Reply with quote
Correct, less splines on the inner equals more of an increase/decrease.
Step up to a quality carb.... http://www.thesamba.com/vw/classifieds/detail.php?id=429441
Get your stocking stuffers here, don't be the only one left out---> http://www.thesamba.com/vw/classifieds/detail.php?id=845378
vendre55
vendre55 is offline
PostPosted: Thu Oct 01, 2009 2:20 pm    Post subject: Avis Adjusters instlation Reply with quote
I plan to low my 70 Beetle 3'' to 4'' where did i weld the avis adjusters, up or down to the center bolt in the beam
bugninva
bugninva is offline
PostPosted: Thu Oct 01, 2009 4:29 pm    Post subject: Reply with quote
wow...never received notice to this thread back then.... thanks for pointing out guys, I did indeed(not sure why) reverse what I was *trying* to say... Laughing
the further down(lower toward the ground) the center grub points, the lower the front end will ride..
olson1955
olson1955 is offline
PostPosted: Thu Oct 01, 2009 7:06 pm    Post subject: Reply with quote
i have a 70 std bug ...
i already got the adjusters in the beam.. and i know how to lower the rear
but what i wanna know is if i can run drop spindles?
i hear alot about only able to run 145 or 135 and thats to small for me.. lol
iam thinking about 165/55 - 165/65 tires..
with my adjustable beam can i put on drop sindles with those tires?
and my beam isnt narrowed..
70 std bug ( Daily Driver )
66 bug (project)
amazinglarry104
amazinglarry104 is offline
PostPosted: Thu Oct 15, 2009 9:59 am    Post subject: Reply with quote
I am a little confused about shock sizes.
I want to buy KYB GR-2 shocks from pacific customs. They have shocks for a ball joint front end (which is what I have) for a raised, stock, or lowered car. I have 2.5 inch dropped spindles and from what I read on here I would need stock length shocks, and not shocks for lowered cars. Is this correct?
Also, I have have rear lowered 1 spline, so would I use stock length shocks on the back as well or shortened ones?
69 Jim is offline
PostPosted: Thu Oct 15, 2009 11:50 am    Post subject: Reply with quote
Correct, dropped spindles don't change the geometry as far as shocks are concerned so stock size are used.
I am using stock size on the rear of my car that has been lowered 2" and have never had any problems. Good luck.
sdbritton
sdbritton is offline
PostPosted: Sat Oct 17, 2009 3:38 pm    Post subject: adjusting the adjusters Reply with quote
I am looking for some instructions how how to make adjustments to the adjusters. I have a 71 standard with adjusters in the beam already. the car is to low and I need to raise it some. I cant make them move at all, do I need to disconnect any parts before I can adjust them? I have accidently taken the grub screw out of the adjuster and now the hole is lower that the slot in the adjuster so I can not put it back in. Thanks for any help you could provide.
Fattie
I'd roll it
Fattie is offline
PostPosted: Sat Oct 17, 2009 7:56 pm    Post subject: Reply with quote
floor jack the front up...put the grub screw back in then adjust it and the other one..then lower the car off the jack....bounce on the front of the car to help it "settle" back down...repeat till you get the height you want
B.R.A.C.
The Golden Rake...'73 progress:
www.thesamba.com/vw/forum/viewtopic.php?t=293132&highlight=
71-BEETLE-SEDAN
71-BEETLE-SEDAN is offline
PostPosted: Thu Oct 22, 2009 10:12 pm    Post subject: Reply with quote
Hey,
I heard that you can lower the front of the car by removing 2 torsion bars,
what ones should i remove.
Reply to topic    Forum Index -> Beetle - Late Model/Super All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 23 of 24
Wolfsburg West
Copyright © 1996-2009, Everett Barnes. All Rights Reserved.   | Archive
