Capecodster Samba Member
Joined: October 20, 2005 Posts: 72 Location: Wareham Ma
Posted: Mon Dec 05, 2005 2:14 pm Post subject: wheel adapters |
Hey,
Has anyone here ever tried bolting on 4x130 stock four lug pattern adapters to make it to 5x205 early style? this way you could keep the disk brake front end and run some cool early style wide 5 patterns. It will move your wheel out about 3/8th of a inch per side. But with a narrowed beam you could put it back to stock width.
Any info? |
60DoubleTurd Type 3 Contributor
Posted: Mon Dec 05, 2005 2:58 pm Post subject: |
But with a narrowed beam youd be running a bug set up so you would already have wide 5. The other option, if you want to keep your disc set up is to buy the wide 5 disc kit they sell for a type 3. And if you are going to run wide 5 OG type 3 wheels the offset will be correct so you dont need to go through the hassle of a narowed beam, tie rods, etc. _________________ Frank
66 L87 Variant Pigalle
SBS #17 |
jimmynotch Samba Member
Joined: February 11, 2003 Posts: 2901 Location: sacramento
Posted: Mon Dec 05, 2005 6:37 pm Post subject: |
I tried running adapters for 4lug to wide 5 and the didn't work because the adapters hit the calipers. It looked like you would have to grind about 3/8 of an inch off the face of the caliper to make it work and that is just plain sketchy IMHO. The wide 5 kit "they" sell for type 3 will run you between $1400 and $600 depending on the manufacturer. _________________ Jim in Sacto -
my wonderful loving supportive wife wrote: |
You guys are dorks. |
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2 |
Posted: Mon Dec 05, 2005 10:46 pm Post subject: |
I agree with the price but if you look at narrowing the beam and go with a type 1 set up you lose all the ride of a lowered type 3 and might as well just own a bug. No steering dampner, no shock towers, and then you are stuck with a wide 5 bug beam that drives like shit. If you are going to spend the $$ go the right way and do a wide 5 disc. _________________ Frank
SBS #17 |
topnotch Samba Member
Joined: June 22, 2004 Posts: 132 Location: weymouth, dorset, uk
Posted: Tue Dec 06, 2005 3:52 am Post subject: |
jimmynotch wrote: |
The wide 5 kit "they" sell for type 3 will run you between $1400 and $600 depending on the manufacturer. |
hi,
not meaning to hijack this thread, but its on topic - do you know which companies sell the wide 5 conversion kits for early type 3`s?
thanks,
mike |
Posted: Tue Dec 06, 2005 11:44 am Post subject: |
Ok, so I own a bug with a ball joint front end. lowered to the ground almost! rides great? no bump steer or anything. Also have owned aton of early type 1 front ends on alot of different bugs and dune buggies.
My notch 1964 isn't really banged hard. it's maybe one or two? at most splines.
It rides hard!!!? and has a ton of bump steer! you better not let go of the wheel and I fear any drops in the road or pot holes!
My type one frontends ride much softer. I have talked to a few people now how have switched over to a type 1 front end setup and love it! even with no shock towers, they claim the ride is great? no bump steer like before.
With a airbag setup, it helps in the shock absorbtion dept. as the bag always has resistance against it.
Never thought about the calipers hiting!
If a link pin front end is used, it can run the CB. wide five disk brake kit. It runs about $600 or so. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Tue Dec 06, 2005 12:14 pm Post subject: |
Capecodster wrote: |
It rides hard!!!? and has a ton of bump steer! you better not let go of the wheel and I fear any drops in the road or pot holes! |
do you need to replace the steering damper? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Tue Dec 06, 2005 1:09 pm Post subject: |
Ive owned a ton of type 3s which have all been floored from 3 in the front to 5 in the front and they all ride they are on rails. Smooth as hell. You got to run all new shocks, cut out the bump stops in the front, check the steering dampner and check the geometry on your tie rods, steering etc. It will smoke any factory type 1 set up. _________________ Frank
SBS #17 |
Posted: Tue Dec 06, 2005 1:24 pm Post subject: |
Yeh, maybe the bump stops are still on? I haven't seen if they are still in there. As I have been working on other stuff.
It has all new KYB gas shocks and a new steering stabilizer. |
Posted: Tue Dec 06, 2005 2:25 pm Post subject: |
new shocks - with it being lowered, are they short shock or stock height? _________________ póg mo thóin
Posted: Tue Dec 06, 2005 2:36 pm Post subject: |
Quote: |
hi,
thanks,
mike |
There is a company from Germany called CSP that makes them. They are about $1400 and they are the sh!t. Totally badass. Find them at www.costomspeedparts.de.
Then there are the BAD BRAKES by Airkewld that are supposedly based on the stock setup but are available in any bolt pattern. I haven't seen these yet so I can't vouch for their product, but it sounds cool. _________________ Jim in Sacto -
TOOB member #2 |
R.Rabbit Samba Member
Posted: Tue Dec 06, 2005 3:52 pm Post subject: |
topnotch wrote: |
jimmynotch wrote: |
hi,
thanks,
mike |
http://www.csp-shop.de/cgi-bin/shop2/shop_main.cgi?func=start&wkid=93840823181 _________________ Opportunity may knock only once, but temptation eff' leans on the doorbell!
SBS #5
'54 RHD Swedish 3-fold
'60 L345 Doppelkabine |
Posted: Tue Dec 06, 2005 4:11 pm Post subject: |
Those are tight!! Now all I have to do is win the lottery and theyre mine!! Can you imagine the shipping from over there to here being that heavy. Probably another 1000. _________________ Frank
SBS #17 |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
Posted: Tue Dec 06, 2005 6:07 pm Post subject: |
So heres the "brake"down pardon the pun. This was a setup I looked into on their site.
About $1150. I havent used any of their products either but its still under the 1600 and shipping from UK. _________________ Frank
SBS #17 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Tue Dec 06, 2005 6:33 pm Post subject: |
ditto, i have had 3 slammed bugs 3 slammed type 3's and 2 slammed buses. and a fat chick bus but i don't like to talk about that.
the slammed t-3's rode way nicer. i'm talking low low low. IMO the only safe way to use a type 1 narrowed beam on a type 3 is with bags and discs. the type 1 torsions are ment for a much lighter car, ditto the stock type 1 brakes. I can't think of any other type of car in the collector car world where brake downgrades are an acceptable means to lowering.
that would be like using the suspension and brakes out of a escort to lower your truck. can you do it? yeah. does it lower the truck significantly? yeah. is it smart?
oh yeah, the wheel adaptors do hit, and yes, the calipers would need to be shaved way too much along with the adaptors _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue Dec 06, 2005 9:16 pm Post subject: |
so, as i said before.... spend $1400 on German shit or a little less on airkewld's set-up. Either way, disc bakes are definately better if you wanna drive your car every day. I am looking (dreaming) of a Wide 5 front and rear disc setup. _________________ Jim in Sacto -
TOOB member #2 |
Posted: Tue Dec 06, 2005 11:30 pm Post subject: |
I have to say the one thing I like about the Aircooled stuff is that you can go from 5x205 to 5x130 on the same disc. Slotted one day and alloys the next. Now thats ballin, switchin rims day by day. _________________ Frank
SBS #17 |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Wed Dec 07, 2005 9:21 am Post subject: |
or 4 different rims with different stud patterns. i'm not looking to switch my stuff up often, just some quality equipment. i'm assuming the rear kits made to fit a 68 bug will work on a type 3? CBs race ready kits look pretty good with the reinforced brackets, compared to some with a bent piece of metal to hang the caliper in the right place. i imagine those could bend under hard braking. |
Posted: Wed Dec 07, 2005 10:59 am Post subject: |
So what is the weight difference between the bug, say a split or oval link pin bug a a s-notch 1964?
How much weight difference |
