bleeding brakes tip needed
thumpergti84
thumpergti84 is offline
PostPosted: Mon Dec 12, 2005 9:14 pm    Post subject: bleeding brakes tip needed Reply with quote
Do you guys have any tips on bleeding your brakes if your wife won't even help out.I have to do it solo.
msinabottle
msinabottle is offline
PostPosted: Mon Dec 12, 2005 9:25 pm    Post subject: Hope You're Handy with a Drill! Reply with quote
Go to this URL:
http://www.bmw-m.net/TechProc/bleeder.htm
and build that gadget. You will do a much better job of bleeding the brakes than if your wife WAS mechanically inclined, and while you're at it, I'd keep going and change out the brake fluid entirely. Cheapest source of DOT4 is Wal-Mart or NAPA. For a cheap air gauge, I used a Wal-Mart dial tire gauge, which worked very well. You'll have to keep getting out from under the Vanagon to pump the sprayer back up again, but you get it down to a rhythm.
Make a bottle to catch the old fluid, of course, and put some fluid in the bottom of it if you're only bleeding. You can get a cheap brake fluid cap from Arizonapartshaus.
Good luck!
Ericthenorse
Ericthenorse is offline
PostPosted: Tue Dec 13, 2005 12:32 am    Post subject: Reply with quote
You should only use DOT 4 if you can completely flush the lines. This is best done when doing a complete rebuild of the brakes since otherwise you will never be able to get all of the DOT3 out. The two are not compatible... Shocked
'69 bug--rusty as hell
'91 vanagon carrat-slammed,5 speed,4 wheel disks,17x8.5's
Phil G
Phil G is offline
PostPosted: Tue Dec 13, 2005 1:13 am    Post subject: Reply with quote
Go to Sears and buy the inexpensive trigger-grip vacuum pump - it's a snap. Has a drop tube and bottle accessory included specifically for brake bleeding. Clean and fast, you won't know how you ever lived without it.
Silicon fluid is a total waste of money for a street car. Moisture is the enemy and reduces the boiling point of all brake fluids. I think everybody understands the corrosion issue. A complete annual fluid change is the only way to eliminate the effects of moisture absorption. This and cleaning/lubricating rubber parts (caliper piston boots, etc.) with a silicon compound are why the original master cylinder and calipers on my 24 year old Benz are still in perfect condition.
mightyart
mightyart is offline
PostPosted: Tue Dec 13, 2005 5:06 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=128526&start=0
My Art:
http://www.instagram.com/flynn8552/
VDubTech
VDubTech is offline
PostPosted: Tue Dec 13, 2005 5:56 am    Post subject: Reply with quote
Your wife WON'T even sit there and pump the pedal for you?? I would kick her to the curb...what is she too good to sit there and help you out? My fiancee has done everything from helping to bleed brakes to helping me tow old Buses home with my car. You don't have one friend that would help you out for a half hour?
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
thumpergti84
PostPosted: Tue Dec 13, 2005 6:59 am    Post subject: Reply with quote
It is to cold in the garage for her to be helping out.That's the next thing HEAT in the garage.
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Dec 13, 2005 7:31 am    Post subject: Reply with quote
That Motive unit is the greatest thing since canned beer. I am buying one for my WIFE for Christmas.
VDubTech
VDubTech is offline
PostPosted: Tue Dec 13, 2005 7:51 am    Post subject: Reply with quote
How sad...just makes me love my girl all the more. She would never say it's "too cold" to help me out...she would button up, throw a jacket on and be right out there with me. My problems are her problems and vice versa. We work together and help each other out no matter what...god I love that girl.....
We have a pressure bleeder at work and I have to say it does do an incredible job if you by some chance end up bleeding them by yourself. Good luck Thumper......
SlowLane
SlowLane is offline
PostPosted: Tue Dec 13, 2005 9:57 am    Post subject: Reply with quote
That's the first I've heard of this. Are you sure you don't mean DOT 5, Eric?
See here: http://www.russellperformance.com/frequentlyautomotive.htm
Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett
msinabottle
PostPosted: Tue Dec 13, 2005 1:11 pm    Post subject: Winston's Cap DEMANDED DOT4 Reply with quote
I'd never heard of it, myself, but, cap said DOT4, DOT4 it would have! Fellow at the NAPA said that DOT 4 is compatible with DOT3, just has a higher boiling point. With brakes, I don't experiment.
On the subject of DOT5, the Silicone--VW, I've heard, emphatically warns you NOT to put in a Vanagon--seals can't take it. And, since the brake fluid's also the clutch fluid, again--DOT4 it wants, DOT4, it gets.
thumpergti84
PostPosted: Tue Dec 13, 2005 7:51 pm    Post subject: Reply with quote
I have to do a full flush NOW Mad I used synthetic and did not know it till after the fact.I took the day off so I will be picking up dot 4 and my wood burning stove!! Very Happy .Thanx guys N gals
SlowLane
SlowLane is offline
PostPosted: Tue Dec 13, 2005 9:28 pm    Post subject: Reply with quote
Whoa, Thumper: "synthetic"? D'you mean silicon (ie. DOT 5)? If so, then yes, you oughta flush it out.
If not, check and see if your synthetic is DOT 3 or 4. Even though Bentley and the reservoir cap specify DOT 4, I don't believe that having DOT 3 in there will hurt anything.
Present:
Back in the day:
'72 Super Beetle
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Tue Dec 13, 2005 11:54 pm    Post subject: Reply with quote
Dots 3 and 4 are totally compatible. Always have been, always will be.
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
Ericthenorse
PostPosted: Wed Dec 14, 2005 2:32 am    Post subject: Reply with quote
I stand corrected... Very Happy Very Happy
thumpergti84
PostPosted: Wed Dec 14, 2005 6:36 am    Post subject: Reply with quote
That's nice to hear early in the morning.It is dot 3 synthetic.
runscx
runscx is offline
PostPosted: Sat Dec 17, 2005 9:25 am    Post subject: Reply with quote
my brake fluid says dot 3 & dot 4, is that cool?
foodeater
foodeater is offline
PostPosted: Thu Jun 05, 2008 1:51 pm    Post subject: Reply with quote
thats pretty cool...i guess.
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
Christopher Schimke
PostPosted: Thu Jun 05, 2008 2:00 pm    Post subject: Reply with quote
Funny!!! Applause
camerahunter
camerahunter is offline
PostPosted: Mon Feb 28, 2011 10:11 pm    Post subject: Reply with quote
So, I am reading up on bleeding my brakes because I have the pump once and it' soft, twice and it's good.
By soft it means low to stop, acting like it's not really grabbing much, 2nd pump and they are normal and stop normally.
This is in my white 1985.
I have bled them too many times to count.
Engine of, furthest first, clear tube into ajar of fluid, someone pumping and holding while I operate the bleeder screw.
My question about building or using the pressurized deal posted here is why would it work?
Put the cap on, pressurize the system, remove the cap to put on the real cap and doesn't all the pressure escape?
Thank you,
David
1984 - Daily driver
