El Guero Samba Member
Joined: January 03, 2004 Posts: 1197 Location: I.E. Y-QUE
Posted: Sat Dec 17, 2005 6:37 pm Post subject: alignment shop |
anybody know of any in so cal that do type 3's thanks _________________ Praise the Lowered... |
rust 1500 s Samba Member
Posted: Sat Dec 17, 2005 10:22 pm Post subject: |
ANY GOOD SHOP CAN DO IT IF ITS NOT LOWERD.
IF ITS LOWERD YOU WILL HAVE TO SHOP AROUND MORE .
CHECK YOU BALL JOINTS AND TIE RODS WELL,BEFORE TAKING IT IN. _________________ SQUARE NUT
62 NOTCH PROJECT |
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Sun Dec 18, 2005 6:18 am Post subject: |
Any alignment shop should be able to do it, lowering shouldn't make a difference. The ball joints and tie rod ends must be in good shape.
If you're mechanically inclined, it's not too difficult to do yourself. The Bentley manual explains it quite well. In lieu of that fancy VW tool shown in the manual I use a $5 Harbor Freight angle finder for setting the camber angle. _________________ OGST
Samba Member #4862 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Dec 18, 2005 8:49 am Post subject: |
And if you do take it to a shop to have it aligned, take your Bentley with you. (You do have one don't you). Their computerized, alignment machine probably won't have it listed. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1083 Location: Dover, DE
Posted: Sun Dec 18, 2005 8:52 am Post subject: |
Make sure you loosen up the tie rod ends before you go. The grease monkey that did mine was banging them with a hammer to loosen them when I came in to the shop. Stay in the bay so you can help, if they will allow it.
And double what Russ said. Most don't have the specs for our older cars especially type3's. _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
