7d4vdub Samba Member
Joined: October 14, 2008 Posts: 71 Location: Maryland
Posted: Fri Dec 12, 2008 5:45 pm Post subject: |
drift-monkey wrote: |
hi there guys im new to this forum and my dad has just got back into beach buggies and weve been trying to find out why the clutch when engaging makes a noise and ive read on this post that u cant use a early throwout baering with a 1600clutch and flywheel which he currently has in his vw, what would he have to change to allow him to still keep the new clutch and pressure plate he has but to still make the throwout bearing work without failure???
anyhelp appreciated , cheers |
Buy a new bearing $18 cip1.com _________________ Brian
74 Std Beetle
***Check out my stuff for sale*** |
nosehairdreadlocks Samba Member
Joined: September 20, 2006 Posts: 12 Location: Hawaii
Posted: Fri Dec 19, 2008 4:01 am Post subject: Oops |
I actually made the mistake of putting an early style pressure plate with a late style t/o bearing. The motor went on but made a metal on metal squeak when I started the thing. Then I read this thread. Got informed. She's running smooth now! Thanks! |
Wilfredo R Samba Member
Posted: Mon Jan 26, 2009 8:48 pm Post subject: |
Should the clutch pedal be just as high as the brake pedal or higher? |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
Posted: Tue Jan 27, 2009 5:05 pm Post subject: |
They should be about the same. _________________ Mike
Sold my sedan
Parts... |
BrianHulud Samba Member
Joined: June 28, 2006 Posts: 174 Location: Oxnard, Ca
Posted: Tue Jan 27, 2009 10:39 pm Post subject: |
hey guys im trying to put my new TO bearing in and cant figure out how the heck to get the clips on. I know where they are supposed to go into but i cant get them to spring open at all. Anyone have any tricks for getting the dang clips in? _________________ '67 Beetle w/ 1600
'65 beetle w/ 1914 |
hpw Samba Member
Posted: Sat Jan 31, 2009 7:12 am Post subject: |
wompninja wrote: |
Any tricks for putting on the centering ring? |
Or how to take it off? I see all the posts advising to remove the centering
ring, but not on HOW to do it. Do I need to remove the clutch from the
engine to remove the centering ring? I don't want to screw something
up never having done this before.
[img][/img]
Also I have the late style tranny with the collar, so I assume that this
collar (pictured) has to come off _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
hpw Samba Member
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sat Jan 31, 2009 7:48 am Post subject: |
I personally would get the later style pressure plate and not use that early one with the collar removed. I have never had much luck with that.
hpw Samba Member
Posted: Sat Jan 31, 2009 7:53 am Post subject: |
keifernet wrote: |
thanks keifernet, sumof-a-biatch, does this ever end? Every time I turn
around, I need something else. Would you be so kind as to recommend
what I need so that I don't have to do this again. Wish my builder would
have told me this. _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
hpw Samba Member
Posted: Sat Jan 31, 2009 11:23 am Post subject: |
Thanks, This looks like the best one. So is this the one you would buy
if you where using my money
Now if it will work with the Copperhead Cluch Disc that is already installed
on it?
When you start changing parts out from stock, does it ever open up whole
new can(s) of worms. _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
Posted: Sat Jan 31, 2009 11:38 am Post subject: |
I am just saying that I have tried the "remove the collar" from those earlier style ( spring type/non diaphram type) for use with the 71 and later trans and it never worked out. I pulled engines out several times trying to figure it out and gave up. Installed the correct stock PP ( like Mike posted) and never looked back.
Maybe your builder did not know you were using the later style trans?
I agree Sachs is just fine. German if you can get it but I have never had an issue with Sachs de Brasila either. I have had a few problems with some LUK and other no name brand PP's and parts.... but only once in awhile. ( kwality kontrol krap shoot)
Is this a stock engine? or what are the specs? why the use of the non stock disc? |
hpw Samba Member
Posted: Sat Jan 31, 2009 11:44 am Post subject: |
Quote: |
Maybe your builder did not know you were using the later style trans? |
I bought my tranny from him also, but in his defense, at different times.
I bought the tranny first then later the engine was sent to him for a rebuild
The engine is only making 100hp and approx. 120 ft. lbs of torque. _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
Posted: Sat Jan 31, 2009 11:52 am Post subject: |
I thought some outfit was making a stronger 1700 or higher version of the "diaphram" type PP nowdays but can't recall... anyone? Bruce??? |
Posted: Sat Jan 31, 2009 2:23 pm Post subject: |
hpw wrote: |
if you where using my money |
Actually, I bought this one http://www.peekperformance.com/shop/product_info.php?products_id=487 for my convertible, it's been fine. It was Sachs brand and is significantly cheaper at Peek for some reason. Call them to confirm it's actually Sachs. _________________ Mike
Sold my sedan
Parts... |
tigatfo Samba Member
Joined: July 11, 2008 Posts: 59 Location: Puyallup, Washington
Posted: Tue Feb 10, 2009 6:25 pm Post subject: |
How far from the trans housing should the throw out bearing be? I installed a bowden tube in my buggy and I think that clutch cable is now to short. The bearing is about 2.5" to 3" from the housing. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Feb 10, 2009 7:31 pm Post subject: |
keifernet wrote: |
I am just saying that I have tried the "remove the collar" from those earlier style ( spring type/non diaphram type) for use with the 71 and later trans and it never worked out. |
I've been using the earlier non-diaphragm type F&S pressure plate with the center collar removed with my 1835 in my 1971 Convertible for several years now, no issues, works fine. It was my used one, 1980s vintage, had a lot of miles on it previously with the 1835 in my '70 sedan. I did install a brand new spring clutch disc at that time however. Mine has the original transmission (never out), and original throw-out bearing. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Feb 10, 2009 9:20 pm Post subject: |
Cusser wrote: |
keifernet wrote: |
I've been using the earlier non-diaphragm type F&S pressure plate with the center collar removed with my 1835 in my 1971 Convertible for several years now, no issues, works fine. It was my used one, 1980s vintage, had a lot of miles on it previously with the 1835 in my '70 sedan. I did install a brand new spring clutch disc at that time however. Mine has the original transmission (never out), and original throw-out bearing. |
Lucky you... I have not had any luck with that at all and as stated prefer the later model diaphragm type which is most common for the 71 and later style anyway. I have tried it with good used stock ones ( that worked with the collar on in the early set up) and with at least 3 "new" PP from vendors that were the HD type aftermarket.
Maybe there is something I don't know or over looked at the time but every time I tried it no matter how I adjusted the clutch I could never get it to engage correct and it would just grind. Pulled out engine swapped PP and BAM... worked fine. go figure |
Cusser Samba Member
Posted: Wed Feb 11, 2009 2:19 am Post subject: |
keifernet wrote: |
Maybe there is something I don't know or over looked at the time but every time I tried it no matter how I adjusted the clutch I could never get it to engage correct and it would just grind. |
I didn't do anything special at all. In fact, I had figured that I would just use the '71's stock original pressure plate (or purchase a brand new one)when I installed that engine from the '70 into the '71. But I have always liked the old-style PPs (don't exactly know why, and I'm not a clutch expert) and had good success with that F&S spring-type while in the '70, and read here on the Samba about pulling off the center ring (had never heard that before), so I tried it. So maybe it was just happenstance or luck. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
63scout Samba Member
Posted: Fri Mar 20, 2009 4:51 pm Post subject: Pressure Plates |
My question arises from the fact that I have the 73 trans ( with the two bolt mount that goes to the bottom of the pan instead of the hoop ) but the pressure plate and disc are from a dune buggy which had been built on a 66' pan and trans swing axle type. When I attached the 72' dual port 1600 to the 73 trans, the t-bearing fork arm seems to swing freely for about an inch and half to the front of the pan and stops with no abitlity to flex any more forward at all even with a small pipe slid over it. Any ideas ? The pressure plate had no ring on it . |
