rnsdiesel Samba Member
Joined: September 08, 2013 Posts: 32 Location: Sun City, AZ
Posted: Wed May 21, 2014 8:05 pm Post subject: RE: Centering Ring |
Cusser wrote: |
The centering ring is part of the clutch pressure plate. If you have the 71 & later type of throwout bearing, remove this from the pressure plate. |
Is the centering ring easy to remove from the pressure plate? Anything I should know before trying this to avoid surprises?
Thanks |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed May 21, 2014 8:24 pm Post subject: Re: RE: Centering Ring |
rnsdiesel wrote: |
Cusser wrote: |
Thanks |
It was very easy on my pressure plate - 5 minutes - but I still have/run a 3-finger pressure plate. So I don't know if it removes as easily on a diaphragm pressure plate. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed May 21, 2014 8:43 pm Post subject: Re: RE: Centering Ring |
Cusser wrote: |
rnsdiesel wrote: |
Cusser wrote: |
Thanks |
It was very easy on my pressure plate - 5 minutes - but I still have/run a 3-finger pressure plate. So I don't know if it removes as easily on a diaphragm pressure plate. |
My pressure plate is a Kennedy Stage 1. |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Wed Jun 04, 2014 9:24 am Post subject: |
Is there suppose to be a gasket between the T/O guide sleeve and transmission? I seem to remember seeing an exploded view showing one, but can't find it now! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
BWD Samba Mailman
Posted: Thu Jun 05, 2014 7:19 am Post subject: |
Bump _________________ BWD
JHC
member #2850
1966 Beetle
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
BWD Samba Mailman
Posted: Thu Jun 05, 2014 9:08 am Post subject: |
Thanks! _________________ BWD
JHC
member #2850
1966 Beetle
Posted: Fri Jun 06, 2014 8:23 pm Post subject: Re: RE: Centering Ring |
rnsdiesel wrote: |
Cusser wrote: |
rnsdiesel wrote: |
Cusser wrote: |
Thanks |
Has anybody removed the centering ring from a KEP Stage 1 pressure plate? Just curious if this is possible or if I need to buy a new one. Thanks |
christiancarpenter Samba Member
Joined: June 08, 2010 Posts: 192 Location: edmond, ok
Posted: Sat Jul 05, 2014 7:44 pm Post subject: |
hey guys, not to beat a dead horse but one more bit of clarification please. I have recently started a '68 project (no engine) that has the old style throw out bearing no sleeve). I got an engine from another guy that is a 1600dp from 1974. I ordered my clutch to match up to the engine before reading this sticky. can I use the old style throw out bearing with the new style pressure plate? I will get a brand new old style t.o. bearing if that is appropriate. sorry for asking this after 11 pages of replies just want to do it right the first time as I've never mixed and matched engines/trans before. thanks guys.
Posted: Sat Jul 05, 2014 7:56 pm Post subject: |
or even better, just return my '74 clutch kit and buy a kit for a '68 beetle and be good to go? since my '74 engine has a 200mm flywheel the older models kit should mount up fine, right? |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Sun Jul 06, 2014 7:39 am Post subject: |
christiancarpenter wrote: |
This is the better option. You need an early style TO bearing... your clutch must match this.
'67~ Beetles all used 200mm clutches. They will all mount to the flywheel from the same years. _________________ AshMan40
Posted: Sun Jul 06, 2014 10:01 am Post subject: |
ashman40 wrote: |
'67~ Beetles all used 200mm clutches. They will all mount to the flywheel from the same years. |
thank you for the confirmation. I appreciate your time. |
BWD Samba Mailman
Posted: Sat Jul 12, 2014 4:03 pm Post subject: |
How does the late style TO bearing go on, the coil in the clip, up or down? _________________ BWD
JHC
member #2850
1966 Beetle
-Rusted_Radio- Samba Member
Joined: October 14, 2003 Posts: 246 Location: Siloam Springs,Ar
Posted: Sun Aug 17, 2014 10:53 am Post subject: |
I assume this pressure plate with ring can only be used in early transmission no sleeve? Thanks, _________________ Wes
61 Beetle on 69 Frame
Siloam Springs, Ar |
BWD Samba Mailman
Posted: Sun Aug 17, 2014 12:16 pm Post subject: |
You can take that ring off. _________________ BWD
JHC
member #2850
1966 Beetle
Posted: Sun Aug 17, 2014 7:17 pm Post subject: |
But for an early IRS throw out I need the ring right?
And there's no fingers under this ring, so if I took it off I'd have nothing? _________________ Wes
BWD Samba Mailman
Posted: Sun Aug 17, 2014 8:51 pm Post subject: |
Do you have the sleeve on your transmission? _________________ BWD
JHC
member #2850
1966 Beetle
Posted: Sun Aug 17, 2014 8:58 pm Post subject: |
Sure dont it's early throw _________________ Wes
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 953 Location: Sacramento, CA
Posted: Sun Aug 17, 2014 9:06 pm Post subject: |
-Rusted_Radio- wrote: |
And there's no fingers under this ring, so if I took it off I'd have nothing? |
There are the 3 big fingers rather than a lot of small fingers. If you don't have the sleeve it is an earlier style with the ring on the pressure plate. |
Posted: Mon Aug 18, 2014 4:34 am Post subject: |
I assume this pressure plate with ring can only be used in early transmission no sleeve? Thanks, |
If you wanted to use that pressure plate with a later style transmission/release bearing (that needs a sleeve around the trans input shaft) you would remove the center ring and it would look like this:
The late style release bearing would ride the three "finger tips" the same way it rides the tips of the many diaphragm fingers.
So to answer your question, the pictured pressure plate CAN be used with either early or late style release bearings. Just lift the spring clips and remove the ring to use with the later style release bearing. _________________ AshMan40
