DaVonZip Samba Member
Joined: February 15, 2007 Posts: 734 Location: Fort Myers Florida
Posted: Thu Apr 19, 2007 1:28 pm Post subject: afraid |
ok yall..after reading this entire sticky im getting really nervous about next weekend.
this is when i am attempting to drop my engine for the first time and put in a clutch kit for the first time..
some say its not hard to do...you will be fine...but after you read so many comments like "HELP ME>>IM LOOSING MY MIND"..im beginning to wonder.
_________________ -No, the point is, it's your frickin car. Drive it. park it, light the bitch on fire-- it's not for us to say. (samba member)
-For once in my life, i'd like to get up in the morning and be as happy as my pennis is... (samba member) |
4desertrats Samba Member
Posted: Thu Apr 19, 2007 2:08 pm Post subject: |
what part of the process is of concern to you? |
GeorgeL Samba Member
Posted: Thu Apr 19, 2007 3:30 pm Post subject: Re: afraid |
righteous rick wrote: |
As long as you replace like parts with like parts you will have no problems. The difficulty comes when you mix early style and late style components. |
CHARLES JETT Samba Member
Joined: March 24, 2006 Posts: 115 Location: ORANGE PARK FL.
Posted: Fri May 18, 2007 7:38 pm Post subject: |
Glenn, My 71 had the sleeve and centering ring, should I leave the centering ring off the rebuilt unit. |
mrreddog Samba Member
Posted: Sat Jun 02, 2007 7:42 pm Post subject: |
my centering ring needs to come off but it looks different then the one with the spiral lock, heres a picture. should i still remove it? i did a swing axle to irs conversion and the new tranny has the sleeve.
first picture is outside the second is inside view
[/img] |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sat Jun 02, 2007 7:46 pm Post subject: |
I'm not totally sure but you should be able to remove it. If you can't then you need to buy a new pressure plate. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jun 02, 2007 8:43 pm Post subject: |
ok i removed it, this is what i have now, hows it look? the engine slid on nice now and it locks into gear but i cant pull the clutch lever by hand, how hard should it be?
Posted: Sat Jun 02, 2007 8:49 pm Post subject: |
heres a shot with the pressure plate and disc bolted up..does this look correct?
Posted: Sat Jun 02, 2007 11:00 pm Post subject: |
ok i went back out to the garage and checked out the clutch again, it seems its working fine, once i put a screw driver through the lever eye,it activated nicely.
this thread helped me within an hour or 2, get my motor mounted and ready to continue the build. thanks guys..
heres another picture with the engine mounted....if anyone sees any problems please let me know,this is my first sandrail build.....
koolaidman Samba Member
Posted: Tue Sep 11, 2007 1:07 am Post subject: |
ummmm, i just installed a new clutch on my 66 and it has some chatter.... i have been looking at all these pictures and relized that i put a pressure plate on that has the center ring, and i also put a throw out bearing on with a center ring.... does this matter do i have to pull the motor:( |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Sat Sep 22, 2007 8:15 am Post subject: |
i belive it will be a problem, as the extra material will make the clutch always be slightly engaged. personnaly, I wouldn't rik it. ACtually, rereading your post, chatter, iirc is from insufficiant grab and a half engaged clutch would do that. so your set up is:
tranny: has the sleeve
TOB: late style
pressure plate: has centering ring
if that is true, you ned to remove the centering ring from the pressure plate. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Me. $erf Samba Member
Posted: Sat Sep 29, 2007 2:49 pm Post subject: clutch adjustment??? |
my clutch pedal catches really....really...high can i adjust this or do i need to start shopping around for new parts? HELP..... |
umai Samba Member
Joined: February 15, 2005 Posts: 31 Location: kuala lumpur malaysia
Posted: Mon Oct 08, 2007 10:54 pm Post subject: |
haha....i broke my TO again.. |
Daddylolo Samba Member
Joined: June 05, 2007 Posts: 253 Location: Sintra, Portugal
Posted: Sun Nov 25, 2007 3:43 pm Post subject: |
Well, thanx very much to everybody who really helped me, specially Glen with those pics, I think now how to solve this problem: _________________ '70 hot rod bug
'77 hawaiian bay van
'46 Buick Eight
'67 Ghia |
blackchop65 Samba Member
Joined: May 23, 2003 Posts: 176 Location: phoenix, az
Posted: Wed Nov 28, 2007 1:33 pm Post subject: |
got it! runs great again!
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
Posted: Wed Nov 28, 2007 4:28 pm Post subject: |
Huji wrote: |
so what is the trick to lining the engine back up so it acvtually goes back into place? |
Patience. Also, you might need to raise the motor up just a tiny bit more, especially if you only raised the rear of the car. If so you'll need to angle the motor down slightly to get the transmission input shaft into the disc. _________________ Mike
Sold my sedan
Parts...
Skate SBS Hit Squad
Joined: March 24, 2004 Posts: 995 Location: Acton Ca.
Posted: Sun Mar 09, 2008 5:32 pm Post subject: |
Good info everyone.. Just solved a problem I had. _________________ ~~~~~~> LEE <~~~~~~
AIRKEWLD
SBS NUMBER FOURTEEN 58.5 |
Plainbug Samba Member
Joined: March 02, 2008 Posts: 17 Location: Denver, CO
Posted: Fri Mar 14, 2008 1:08 pm Post subject: |
Regardless of throw out bearings and pressure plates, does it matter what clutch disk you get? I have a 71 super but with an older engine and the front seal is leaking so now I'm sure there's oil all up inside there as it went from normal to slipping like crazy in a matter of days. But with the older motor, not sure what I'll find when I take it off. But will a standard disk, (such as http://www2.cip1.com/ProductDetails.asp?ProductCode=C26%2D141%2D002 ) fit no matter what set up you have? I've never pulled an engine before so not sure what to look for. With oil, is the disk the only thing I need to change out (other than the engine seal, of course)?
Thanks |
65beeter Samba Member
Joined: December 15, 2007 Posts: 93 Location: Sherman, TX
Posted: Wed Mar 26, 2008 6:42 pm Post subject: |
This thread has helped me A LOT. However, is there anybody that sells just the centering ring or do I have to buy a whole new PP. (the PP is fairly new, I just put in a new trans) The car is a 65 so I ordered and installed a 65 trans. Apparently somewhere along the line somebody had installed a newer style trans that had the guidesleeve for the TO bearing, so the centering ring was not needed. |
Glenn Mr. 010
Posted: Wed Mar 26, 2008 6:45 pm Post subject: |
I think CB Performance sells them. But i'm sure they are "take offs" from ones they install and don't need the ring. _________________ Glenn
Member #1009
#BlueSquare |
