65beeter Samba Member
Joined: December 15, 2007 Posts: 93 Location: Sherman, TX
Posted: Wed Mar 26, 2008 8:01 pm Post subject: |
Glenn wrote: |
I think CB Performance sells them. But i'm sure they are "take offs" from ones they install and don't need the ring. |
I emailed CB to see if they sell just the ring. Throughout the past few months, and many many questions I've had, I've found that you are a perfect example of "the Go-To-Guy". I'm sure you hear it a lot, but thanks Glenn, you are the man. |
Posted: Thu Mar 27, 2008 9:20 pm Post subject: |
If anybody ever needs this, Kennedy sells the part themselves. However, I placed an ad here on the Samba looking for one and recieved no less than 20 replies in less than an hour! So they are out there and readily available. Thanks Samba |
Stuggi Samba Member
Joined: October 16, 2007 Posts: 1208 Location: Jakobstad, Finland
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Apr 02, 2008 1:23 pm Post subject: |
The one on the left is fubared. The one on the right is how it should be for a 70.
And for the nit pickers, yes, the one on the left is 180mm. It was the first one I saw.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Torkman Samba Member
Joined: April 06, 2007 Posts: 66 Location: Pullman, Wash
Posted: Tue Jun 10, 2008 9:06 am Post subject: |
Anybody have a centering ring for a Kennedy Stage 1? I have a 68 Tranny with the early TOB and bought an engine that came with the Kennedy Stage 1 but it does not have the centering ring (must have been removed in that the engine came out of a 74 Thing.) Will pay for shipping.
Also, I have heard that if the pressure plate is not removed by taking each bolt out a little at a time, the PP may warp. I did not take off the PP, it was off when I picked up the engine. Anyway to test/check the PP to see if it is OK? _________________ 1968 Ghia Coupe |
Otisfootball Samba Member
Joined: July 08, 2007 Posts: 2 Location: McGuire AFB, NJ
Posted: Fri Jun 13, 2008 4:44 pm Post subject: 1970 Convertible |
Not being a mechanic by any means, however trying to learn...I bought a 70 convertible and the clutch made a horrible grinding noise and didn't engage. After pushing it to the nearest shop they attempted to fix the bug. Now the clutch makes a weak whiny noise when pushed in and shifting to third gear is a pain (with noise). Anyone have thoughts about what they did wrong, so I can fix it?
Exact words from the mechanic were, "Old parts with new parts..."
My thought is he put the old parts in without the center piece.
The bill was paid by the seller since it happened so fast after the sell...Also, I'm dropping the bug off next week for work on the emissons that failed a New Jersey inspection and I need the lingo for the clutch if possible to kill two tasks at once.
Thanks,
Jack |
WAYNE HENSON Samba Member
Joined: June 08, 2008 Posts: 2 Location: COVINGTON GA
Posted: Sun Jun 15, 2008 5:58 am Post subject: TRANNYS AND CLUTCHES |
THANK YOU SO MUCH !
THESAMBA IS A GREAT SITE |
Wilfredo R Samba Member
Posted: Sun Aug 03, 2008 1:21 pm Post subject: Throwout Bearing |
Could i use the late throwout bearing on a 1974 Super Beetle? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Aug 03, 2008 1:25 pm Post subject: Re: Throwout Bearing |
Wilfredo Rumingan wrote: |
Yes... 1971 and newer. _________________ Glenn
Member #1009
#BlueSquare |
2002sportside Samba Member
Joined: January 27, 2004 Posts: 1489 Location: New England
Posted: Sun Aug 03, 2008 1:26 pm Post subject: Re: Throwout Bearing |
That is what the late throwout bearing is for, any transmission after '71. _________________ 1973 Volkswagen Beetle never ending project |
Posted: Sun Aug 03, 2008 1:28 pm Post subject: Throwout Bearing |
Ok, thanks guys, really appreciate it |
chi-townbug Samba Member
Posted: Mon Aug 04, 2008 10:59 am Post subject: Clutches and throw out bearings |
I am having difficulty installing the engine. Everything looks to be lined up properly but the engine will not slide on as it is described in the two repair manuals I have. The throw out bearing became un attached from the springs that hold it in place on the clutch lever, which is why I thought the engine would not slide in. Researching this forum to find out what I was doing incorrect, I came upon the pictures posted by Glenn in Dec. of 2005 on this subject. The pictures leave me a bit more confused. The photos posted by Glen show a Centering sleeve for the late models. My 73 super does not have a centering sleeve. Is there anyone in the Northwest side of Chicago that can give me a hand?? you can reach me off line at [email protected]
Regards,
Mike |
hpw Samba Member
Posted: Mon Aug 04, 2008 2:01 pm Post subject: Re: Clutches and throw out bearings |
chi-townbug wrote: |
Regards,
Mike |
Post up a couple pictures of the problem _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
Posted: Mon Aug 04, 2008 3:34 pm Post subject: |
The '73 should not have a centering ring. The photos he posted show an early style (with centering ring) and late style (without). Yours sounds like it's the late style. You have to make sure the throwout bearing is the correct type, and that you have the late model sleeve as well. _________________ Mike
Sold my sedan
Parts... |
Stuggi Samba Member
Posted: Wed Oct 08, 2008 11:58 pm Post subject: |
Russ Wolfe wrote: |
Thanks mate (forgot to check this tread for updates! ^^). Any idea on how they get that FUBAR'ed, cause mine looked exactly the same? _________________ 1970 Beetle
1969 Panelvan
Orange VW Fest!
Pulled out of a Lake Fest! |
neverlift Samba Member
Joined: June 23, 2008 Posts: 34 Location: Pittsburg,Ca
Posted: Sun Oct 12, 2008 9:31 pm Post subject: |
Ok I have read the posts and am still lost. I have a sandrail that im trying to finish. I had it working good untill I pushed the clutch pedal too far and cut the springs that held the throw out bearing. Its a dp1600 and irs tranny. dont know the years. Here are some pics. I have jamar pedals with a hyd slave cylinder. Im going to make a stop for the pedal so I dont cut the clips again. But im lost on the center ring stuff. Thanks for any help.
[/img] |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Posted: Fri Oct 31, 2008 9:22 am Post subject: |
^^^ you need the centering ring on your pressure plate. ^^^^^ |
Posted: Mon Nov 03, 2008 7:15 pm Post subject: |
Any tricks for putting on the centering ring? |
aircooledfever07 Samba Member
Posted: Tue Dec 02, 2008 1:09 pm Post subject: |
I just checked my Trans and it has the earlier t/o bearing but has the three holes tapped for the later t/o bearing guide sleeve. Looks like maybe the t/o bearing was changed out to the older style?? If thats the case, should I buy a guide sleeve and change back the t/o bearing to the late style? Sounds like the late style doesn't have as many problems as the early style?? I haven't bought a clutch or pressure plate yet, so that wont be an issue. |
drift-monkey Samba Member
Joined: October 28, 2008 Posts: 61 Location: auckland ,new zealand
Posted: Tue Dec 02, 2008 3:33 pm Post subject: |
hi there guys im new to this forum and my dad has just got back into beach buggies and weve been trying to find out why the clutch when engaging makes a noise and ive read on this post that u cant use a early throwout baering with a 1600clutch and flywheel which he currently has in his vw, what would he have to change to allow him to still keep the new clutch and pressure plate he has but to still make the throwout bearing work without failure???
anyhelp appreciated , cheers |
