Locknar Samba Member
Joined: October 18, 2005 Posts: 283 Location: Rebel South
Posted: Tue Jan 03, 2006 3:19 pm Post subject: Top 10 performer tips (?) |
I have a Stock 73 T3 Sqb 1600 FI and was wondering what are the most popular "basic" mods for adding HP/performance. If you have done mods yourself please share which ones were the best bang for the buck..
Thanks _________________ Life is a web woven by necessity and chance.
My Fav vw shop: www.airkooledkustoms.com
1973-T3-SQB
1971-1302 |
GjMan Samba Member
Joined: June 05, 2004 Posts: 822 Location: Grand Junction, CO
Posted: Tue Jan 03, 2006 6:25 pm Post subject: |
Header. No other single mod will give you more HP for the money. Be aware, however, that with your stock FI, you may need to bump up the fuel pressure slightly to take advantage of whatever mods you make. |
vdub Samba Member
Joined: September 07, 2003 Posts: 442 Location: Valley Springs, Ca.
Posted: Tue Jan 03, 2006 11:59 pm Post subject: |
I know I will get flamed for this but loose the FI. Go with a set of carbs. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Wed Jan 04, 2006 11:03 am Post subject: |
correcty inflated tyres. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22457 Location: Escondido CA
Posted: Wed Jan 04, 2006 11:37 am Post subject: |
krusher wrote: |
True that! A commomly overlooked item.
Make sure youer compresson is good. Ratio rockers and a clean air filter. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
vdub Samba Member
Posted: Wed Jan 04, 2006 11:42 am Post subject: |
notchboy wrote: |
krusher wrote: |
Make sure youer compresson is good. Ratio rockers and a clean air filter. |
will ratio rockers mess up your FI system. |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Wed Jan 04, 2006 12:28 pm Post subject: |
vdub wrote: |
You gotta back that up with something. Reasoning? _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Wed Jan 04, 2006 3:10 pm Post subject: |
what are your feelings on the stock coil? Do they have enough punch for an old car that runs rich no matter what you do. _________________ Life is a web woven by necessity and chance.
1973-T3-SQB
1971-1302 |
vdub Samba Member
Posted: Wed Jan 04, 2006 3:55 pm Post subject: |
Locknar wrote: |
what are your feelings on the stock coil? Do they have enough punch for an old car that runs rich no matter what you do. |
on a stock motor I have never had a problem with the stock coil. There has to be a reason your running rich. |
attatt Samba Member
Posted: Fri Jan 06, 2006 1:22 pm Post subject: |
the best thing you can do to feed your desire for more horsepower is buy a newer, faster car for the weekends. let your VW be a VW and by a mustang or something on the side like I did. |
squaret3 Samba Member
Joined: October 16, 2005 Posts: 44 Location: Redondo Beach
Posted: Fri Jan 06, 2006 6:30 pm Post subject: |
leave your stock engine alone. save the money for a bigger engine with a longer crank.
I used to have a squareback and trust me, the car is very heavy! You need more inches to make it move. Build a 2007 or 2110cc motor, big valve heads, moderate cam, merged exhaust, weber DCNFs and full flow oil system. keep the injected motor for a spare. common, you know you want to hear those webers man!!! |
