DSC Samba Member
Joined: March 08, 2005 Posts: 127 Location: Southern Maryland
Posted: Tue Jan 03, 2006 4:01 pm Post subject: Best way to lower IRS on a street buggy? |
Ok I'm a newb so go easy on me.
I would like to be able to lower the rear end about 1 1/2" or 2" What is the best way to go about this.
Has anyone used the adjustable spring plates? I do not want to fool with adding adjusters to the torsion so what are my options? If anyone can supply me with any links with info or simply tell me what I need to do it would be a big help.
Thanks for any advice.
Dave _________________ 1993 RX7 pT-67 .81 a/r
1308cc Two Rotor motor
430rwhp@16psi
Street Buggy currently under construction. |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 7034 Location: SoCal
Posted: Tue Jan 03, 2006 4:04 pm Post subject: |
rear suspension is cheap and easy. take it apart, put it back together and re-index the torsion bars. there's plenty of tutorials all over the internet on how to do that. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
DSC Samba Member
Posted: Tue Jan 03, 2006 4:06 pm Post subject: |
| HamburgerBrad wrote: | | rear suspension is cheap and easy. take it apart, put it back together and re-index the torsion bars. there's plenty of tutorials all over the internet on how to do that. |
I was hoping that was what I would hear. A link would be awsome if you have one handy, meanwhile I'll try google.
Thanks Brad.  _________________ 1993 RX7 pT-67 .81 a/r
430rwhp@16psi
DSC Samba Member
Posted: Tue Jan 03, 2006 8:23 pm Post subject: |
Well I looked around quite a bit here and on the web and did not find much of anything about disassembling the rear suspension and re-assembling it in a lower position. Where is this plethera of tutorials you speak of crazy man..  _________________ 1993 RX7 pT-67 .81 a/r
430rwhp@16psi
buggyblues Samba Member
Joined: August 21, 2005 Posts: 395 Location: charleston, SC
Posted: Tue Jan 03, 2006 9:05 pm Post subject: irs |
http://www.meyersmanx.com/garage/garage_suspend.htm
this is the only one I know off move the outside spline up to lower I just did mine last weekend and recomend buying the 20 dollar tool or borrowing it from a friend. If you look at the early pics of my car from the back it looks way out of wack we actually only moved it one notch to level it out. which I should have pics soon of that also.
hope this helps _________________ www.sticklestowingpittsburgh.webs.com
towing east coast |
DSC Samba Member
Posted: Tue Jan 03, 2006 9:40 pm Post subject: |
Brad I read the second link when I searched originally but with it describing a lift it was perplexing my little pee shooter sized brain as far as making sense of it in a lowering application. The first one seems better and the manx club link is good too.
Thanks fellas. _________________ 1993 RX7 pT-67 .81 a/r
430rwhp@16psi
Posted: Tue Jan 03, 2006 9:47 pm Post subject: |
instead of adjusting spring plates down, you adjust them up. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
DSC Samba Member
Posted: Tue Jan 03, 2006 9:53 pm Post subject: |
yea, no I get that now. My concern is that they all say the torsion is load with a shit load of force etc. So they say not to let the torsion bar come loose from the inside of the car but to slowly let the force slip the spring fall down ( to raise) the car. I'm wondering how hard it is to force the swing plate upward (opposite to lower the car) since it will be putting more load on the torsion bars right?
Sounds like heim joints and coil overs would be easier. J/k _________________ 1993 RX7 pT-67 .81 a/r
430rwhp@16psi
Posted: Tue Jan 03, 2006 10:09 pm Post subject: |
If you can get the tool from someone you will set the torsion use a jack a couple clicks and then use the tool to take the swing arm back up until its above the lip and knock it the rest of the way on. oh I just reread your response and what they mean by don't let the inside come free is the torsion bar is slid in place and set on the inside aswell as the outside just make sure it doesn't come all the way out. You just want the spring plate to come off. _________________ www.sticklestowingpittsburgh.webs.com
towing east coast
Posted: Tue Jan 03, 2006 10:10 pm Post subject: |
the tool isnt really necessary to lower a car from my own experience. its handy for raising it though. however, it has been a few years since ive needed to use one _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Tue Jan 03, 2006 10:15 pm Post subject: |
I'm a novice guy but I've done it both ways once and didn't have a great time without the tool but it did work. This weekend with the tool was so easy and problem free that's the reason why I recomended if he could borrow it but that's correct you don't need it. _________________ www.sticklestowingpittsburgh.webs.com
towing east coast |
merc Samba Member
Joined: October 03, 2005 Posts: 81 Location: Wichita Falls, Texas
Posted: Wed Jan 04, 2006 12:17 am Post subject: |
You can always run down to the local lumber yard and buy bricks. 200-300 pounds ought to drop it down there for ya...  |
