Bobnotch Samba Member
Posted: Thu Nov 27, 2014 9:40 pm Post subject: |
VolksWorld did a great article on it in the last year. It ended getting bought by Tamiya Japan, and sits in their show room. It IS a fully functioning model. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
GeorgeL Samba Member
Posted: Thu Nov 27, 2014 10:29 pm Post subject: |
Bobnotch wrote: |
beetlenut wrote: |
This one looks like all kinds of fun and well thought out! Maybe some more padding on the seat though! |
Agreed, it definitely looks like fun. Any more pics of it? |
I'm afraid not. In the thread where this picture appears someone said they had more but never posted them. It's been reposted on Pinterest a bunch of times but no other angles.
vwsonmybrain wrote: |
GeorgeL wrote: |
This one barely qualifies, as it has VW wheels. It does seem to be an efficient way to die:
Wow, yeah. Efficient and very painful way to die. Though, maybe the one good idea that design could have is that it only goes 5 mph. |
That Mazda rotary probably can push it to lethal speeds which, with that steering , probably begin at 10MPH! |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Fri Nov 28, 2014 3:04 am Post subject: |
GeorgeL wrote: |
I like caliper and disc used for a drive-line brake, that's some optimism!
It's strange though, I went to the site that hosts the image, and I can't find the context! All I can find is references to this ordinary rail-
Never-mind, found it- http://www.smbaker.com/sand-rail/misc/junk-yard-dog-mazda-sandrail-project
The purple one is in a private album, so no luck there. The image name- 67bus100 doesn't seem that useful, unless it's a username somewhere. |
beetlenut Samba Member
Posted: Fri Nov 28, 2014 6:25 am Post subject: |
VeeDubWolf wrote: |
GeorgeL wrote: |
I like caliper and disc used for a drive-line brake, that's some optimism! |
I especially like the impending doom look of driving that thing with shorts, sandals, and T-shirt. I don't guess the steering has to be all that good considering he can only turn it a few degrees before the back of the tire hits the the frame. Looks like a before shot of a Darwin Awards entry! _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
gator Samba Member
Joined: August 12, 2004 Posts: 475 Location: Tookiedoo, South Carolina
Posted: Fri Nov 28, 2014 7:43 am Post subject: |
Found on the local c-list. Do not recall seeing it in here, but if it is a re-post, I do apologize.
Seller is asking $8k.. |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Fri Nov 28, 2014 8:42 am Post subject: |
Bobnotch wrote: |
beetlenut wrote: |
FUN! Looks nuckin' futz! I'd have to relocate the battery though. A bump into something, even at walking speed, would shower the driver with acid.
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
vwsonmybrain Samba Member
Posted: Fri Nov 28, 2014 11:15 am Post subject: |
beetlenut wrote: |
VeeDubWolf wrote: |
GeorgeL wrote: |
I especially like the impending doom look of driving that thing with shorts, sandals, and T-shirt. I don't guess the steering has to be all that good considering he can only turn it a few degrees before the back of the tire hits the the frame. Looks like a before shot of a Darwin Awards entry! |
If nothing else, you've got to admire his determination to kill himself. Here's text from the build thread, below. If at first you don't succeed in bodily harm, try, try again
Test Run:
The test run was a great success…. At least for a while. I powered up the go-kart and drove through my neighborhood to the nearest empty field. Along the way, there were lots of started looks from the neighbors wondering what that ugly noisy machine was rumbling down the street.
When we got to the field, I made a couple of high-speed (well about 20-40mph) passes down the grass before all hell broke loose. The first thing was to happen was the hub on the front “wheelbarrow tire” broke, and the tire fell off. Not a real good thing….
Replaced the tire, and the next thing that happened was kaboom! a large jet of superheated steam from the radiator (rule #1: If you use an inverter to run your 110V water pump, make sure to turn it on!)
Okay, got that fixed and promptly got stuck in a ditch… Finally managed to limp to gokart home before yet another radiator steam episode (rule #2: make sure to follow rule #1 about turning on the water pump; it really is important)
So, the junkyard dog go-kart is currently awaiting a heavier front end with some better tires, and a mechanical water pump. |
Posted: Fri Nov 28, 2014 11:27 am Post subject: |
Test Run:
This sounds like the lead up to the "Man run over by his own car" story! _________________ scrapyards are for quitters
Wetstuff wrote: |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Nov 28, 2014 12:05 pm Post subject: |
beetlenut wrote: |
This sounds like the lead up to the "Man run over by his own car" story! |
To me.... this sounds more like a solid entry for the Darwin Awards...
Somebody get Jeff Foxworthy on the line..
Hahaha. ^ that coming from me...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
EVfun Samba Member
Posted: Fri Nov 28, 2014 12:44 pm Post subject: |
allthewayalive wrote: |
If he would chop a zero off the price and roll it over to the west coast I would be tempted to fix it up. A shorty single cab pickup would be cool! _________________
Wildthings wrote: |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Posted: Sat Nov 29, 2014 8:04 am Post subject: |
vdubyah73 wrote: |
Bobnotch wrote: |
beetlenut wrote: |
Bill |
I'm guessing the battery is up there to ad some weight to the front. Wouldn't be a bad idea to build some sort of battery box and clean up front end. That being said that thing is sweet. _________________ Jonathan
Romans 6:13
WTB 67 beetle rear seat belts.
59 Euro ragtop build with my dad
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553&postdays=0&postorder=asc&start=0
65 dlx Slow build
http://www.thesamba.com/vw/forum/viewtopic.php?t=391061 |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Sat Nov 29, 2014 5:30 pm Post subject: |
YOUBUGME2 wrote: |
vdubyah73 wrote: |
Bobnotch wrote: |
beetlenut wrote: |
Bill |
I'm guessing the battery is up there to ad some weight to the front. Wouldn't be a bad idea to build some sort of battery box and clean up front end. That being said that thing is sweet. |
This was forsale here on thesamba a year or so ago. Had more pics in the ad. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
kenj06 Samba Member
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
bandi Samba Member
Joined: August 24, 2005 Posts: 1064 Location: Campbellford, Ontario, Canada
Posted: Mon Dec 01, 2014 8:39 pm Post subject: |
Those bumpers look like absolute shit on it. _________________ '60 Canadian Standard, '64 Bug, another '64 Bug, '66 Bug, '69 Sunroof Bug, '69 GT3 Bug, '71 Super, '72 Super, '73 Canadian Custom, '74 Love Bug, '83 Mexi Bug, '85 Cabrio, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S, '03 New Beetle VR6. And some Fieros. |
Posted: Mon Dec 01, 2014 9:12 pm Post subject: |
Those bumpers'll be gone the first time a fool tries to tow it or pull it loose should it get stuck. |
kenj06 Samba Member
Posted: Tue Dec 02, 2014 6:09 pm Post subject: |
VeeDubWolf wrote: |
Front bumper doesn't look too bad but the back ones need some help. And the paint just doesn't look good on a newer vehicle. |
obesepolice Samba Member
Joined: January 19, 2012 Posts: 151 Location: Ft. Worth
Posted: Tue Dec 02, 2014 6:18 pm Post subject: |
the juxtapostion of the ratty exterior next to the stock new car interior look like ass. Personally i hate it. Good work, bad taste. |
super72beetle Samba Member
Joined: November 21, 2011 Posts: 491 Location: Wisconsin
