airkooledchris Samba Member
Posted: Mon Dec 21, 2009 11:00 am Post subject: |
markz2004 wrote: |
Can anyone who switched to Koni shocks comment on an improvement in "nose dive" the van may experience during breaking? |
that is exactly why I bought my Koni's and they did wonders for the nose dive under heavy breaking. adjusted to be slightly stiffer than they come out of the box in the back and adjusted to be slightly softer than they come out of the box up front seems to be the perfect settings for my aircooled westy. |
1621 Samba Member
Posted: Mon Dec 21, 2009 12:03 pm Post subject: |
randywebb wrote: |
are you guys comparing NEW Bilsteins with new Konis??
or OLD shocks with new one?
FWIW, Bilstein will revalve your chocks for a nominal fee (at least they will for the ones that fit a Porsche 911) and set the jounce or rebound wherever you want it.
on the aforementioned 'azz-engined nazi-slot car' the typical hot setup is Bilsteins, not Konis
maybe the ones of the Vanagon are not as good, I dunno re that |
2 year old Bilsteins to new Koni's. Even new the Bilsteins were a bit bouncy, but an improvement over the tired stock shocks.
The Bilsteins are set to the factory rebound rates, just a more solid construction. The HDs are NOT any stiffer than the TCs, just a stouter construction designed to cycle more without failing. You can have them rebuilt, but it's an additional cost over purchasing them to begin with. Also, if you have it done you're still left with no adjustability should you decide the rebound rate is not to your liking.
The Konis lightest setting is the stock rebound rate for the Vanagon. Turning them all the way out will give approximately 100% increase in rebound rate. I set mine to 75% and love the difference. There are some who don't care for the ride in my van, stiffer in some respects, but the confidence I have in turns, stops, high winds is more important to me than a cushier ride.
BTW- the ride is not harsh by any means, just firmer. Could also be a combination of tires, tire pressure, springs, etc. _________________ '85 Westy |
SeattleDownhill Samba Member
Posted: Mon Dec 21, 2009 12:12 pm Post subject: |
I'm liking the sound of Koni's. I race downhill mountain bikes, so I can see the adjustability being really nice to tune in the ride quality. |
randywebb Samba Member
Posted: Mon Dec 21, 2009 2:20 pm Post subject: |
" The HDs are NOT any stiffer..."
for other cars, Bilstein Sports are significantly stiffer than HDs.
you may want to run various shocks on a dyno to really find out what is going on
what we all really want is an active shock... |
pighamling Samba Member
Joined: November 30, 2007 Posts: 67 Location: Southern NM
Posted: Tue Mar 09, 2010 3:26 pm Post subject: |
Konis on sale at Tire rack now. |
r39o Samba Polizei
Posted: Tue Mar 09, 2010 4:39 pm Post subject: |
pighamling wrote: |
Set of 4 is $362
Set of 4 at shox.com is $361.20 and they have FREE shipping.
Not a good sale.
You got my hopes up for nothing, sigh....... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
EvanDJ Samba Member
Joined: December 15, 2009 Posts: 49 Location: Minnesota
Posted: Tue Mar 09, 2010 4:47 pm Post subject: |
The Bilstein HD's that my son installed on our camper did not add any noticeable degradation in ride quality so that makes me think that they are valved pretty close to what the originals were. Still a pretty soft ride IMHO; you will NEVER think that you put on some stiffer shocks
My opinion is get in touch with them (Koni & Bilstein) via e-mail and tell them what application you have, trying to achieve, etc. so they can make an appropriate recommendation on what is needed. Both of these companies will build whatever you desire for any application you have in mind. The choices and prices they offer will boggle the mind, at least it did mine when I was still seriously playing with cars
http://www.koni-na.com/index.cfm
http://www.bilsteinus.com/ |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 944 Location: Portland, OR
Posted: Tue Mar 09, 2010 9:02 pm Post subject: |
r39o wrote: |
That's what I got a last week. Got the Koni's in and I do like them much better than the Bilstein's I had on previously. To be fair, the the Bilstein's were on the van when I bought it, so I have no idea of their age.
I set all the Koni's to 3/4 of their maximum stiffness. Nose dive in breaking is vastly improved and cornering is better. I good upgrade for the money if you ask me. _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Wed Mar 10, 2010 9:38 pm Post subject: |
The Koni's are rebound adjustable only. So they will compress at the factory setting but will come back up , (rebound), at your setting. Try not to make them too stiff. It's just as important for the suspension to bounce up as well as down.
I run the Koni red's on our 78 Westy. I had it lowered 2.5 inches. I thought that the shocks needed to be stiff for the ride height. What I found out is that when the Bus would go into a corner or blaze across the whoops and dips in the road, it had a tendency to stay down too long. This meant that it would bottom out more often than when the shocks had a more neutral setting that allowed the vehicle to back back to a more resting position.
I now run them at 1/2 from soft in front and 3/4 from soft in the rear. All seems well.
Just some thought. YRMV _________________ Peace, Regis |
Posted: Thu Mar 11, 2010 12:12 am Post subject: |
That is true. We call that "packing up" in the mountain bike world. When your suspension doesn't rebound fast enough to take up the next bump it just puts you further into your travel after each consecutive hit. Slow is good, but too slow is bad. There is a fine line between the two. But it also depends on what type of terrain you're on. |
Posted: Thu Mar 11, 2010 8:09 am Post subject: |
"Set of 4 at shox.com is $361.20 and they have FREE shipping."
and Tire Rack is back ordered. Thanks for saving me some time and money! |
r39o Samba Polizei
Posted: Thu Mar 11, 2010 8:36 am Post subject: |
pighamling wrote: |
Welcome.
They are physically close to me, next city over, so I am hoping for a "cash discount."
gnarly 928 Samba Member
Joined: April 17, 2006 Posts: 46 Location: Lyle, Washington
Posted: Thu Mar 11, 2010 11:49 am Post subject: |
If you really want to be able to adjust your shock's action you need to get them with double adjustability. Koni red sport shock are just adjustable for rebound. They (Koni) also have a series (12?) that are double adjustable, for rebound and for compression. You can also adjust these Konis on the vehicle. They have some small dials up near the top mount that you can click for adjustment while on the vehicle. These are also readily 'valved' for the weight of the vehicle. If you are serious about improving handling...the way to go...
Look at Koni's website for further info.
Don Hanson |
r39o Samba Polizei
Posted: Thu Mar 11, 2010 8:06 pm Post subject: |
gnarly 928 wrote: |
Don Hanson |
Iam lost on that site. Do you have some part numbers or URLs? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
CTB Samba Member
Posted: Tue Sep 07, 2010 7:33 pm Post subject: |
1621 wrote: |
The Konis lightest setting is the stock rebound rate for the Vanagon. Turning them all the way out will give approximately 100% increase in rebound rate. |
1621, how did you determine this? Did you run them on a shock dyno? That's exactly the kind of info I'd like to know about them and the Bilsteins. Also, how many "clicks" do the Konis have? If the rebound range is from "stock" to 2xstock, how many clicks are in between those two? Also, do you know if the adjustment is only to low-speed rebound (bleeds) or is it more of a disc stack preload that increases the damping at all speed ranges? Thanks for any light you can shed, as I'm about to purchase shocks for my van and have been agonizing over the Bilsteins vs Konis. I'm a racer and love adjustability, but all the Bilstein road vehicles I've been in (no Vanagons, tho) have been very nicely done for damping.
Also, I had seen a thread that mentioned the Touring-class Bilsteins are "the same damping" as the the HD's. That's highly unlikely, given the TC's are twin tubes and the HD's are monotubes. Usually those designs give very different damping curves at the higher speeds, with monotubes often being digressive and twins being progressive. _________________ CTB |
dogcoves Samba Member
Joined: September 09, 2005 Posts: 266 Location: Santa Cruz, CA
Posted: Thu Jul 21, 2011 5:34 pm Post subject: |
I had my Koni shocks at 3/4 but after 3 years the fronts have become a bit too bouncing. Last long road trip left the family feeling sea sick. I just set them at 4/4 on the front and the Westy handles much better again. Time for new springs. But until then is there any problem with running konis at full stiffness? _________________ Current VW: 1987 Westfalia
My Past Volkswagens:
1958 karmann ghia
1963 Beetle
1963 Westfalia
1966 Westfalia
1970 Beetle
1970 Westfalia |
CTB Samba Member
Posted: Thu Jul 21, 2011 6:03 pm Post subject: |
Nope, as long as you're happy with the ride, there should be no issues with running the Konis at full stiffness. It sounds like they might need gone over by Koni, though. They have a lifetime warranty, don't they? If there's a time you can live without the van, maybe they can rebuild them for you. _________________ CTB |
insyncro Banned
Posted: Fri Jul 22, 2011 7:22 am Post subject: |
gnarly 928 wrote: |
Don Hanson |
There are two shocks shown under Van, 80-90.....both have a single rebound adjustment.
Where are you finding compression and rebound adjustments?
Are you sure they were not for a Eurovan??? |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Fri Jul 22, 2011 7:51 am Post subject: |
dogcoves wrote: |
I had my Koni shocks at 3/4 but after 3 years the fronts have become a bit too bouncing. Last long road trip left the family feeling sea sick. I just set them at 4/4 on the front and the Westy handles much better again. Time for new springs. But until then is there any problem with running konis at full stiffness? |
If you need to set your Konis at full stiffness (all the way turned in), something is wrong with them. At full stiffness you should not be able to extend them by hand, if you can that means that the fluid is bypassing the rebound orifice somehow.
I had one front and one rear Koni fail in this exact way on my van, but Koni replaced both without question.
Springs ONLY wear out by sacking out. That means you lose ride height. If your ride height is fine, your springs are fine. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
Posted: Fri Jul 22, 2011 8:21 am Post subject: |
presslab wrote: |
dogcoves wrote: |
Springs ONLY wear out by sacking out. That means you lose ride height. If your ride height is fine, your springs are fine. |
I agree with presslab 100% here! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
