Koni shocks
insyncro
Banned
insyncro is offline
PostPosted: Mon Dec 19, 2011 5:30 pm    Post subject: Reply with quote
70coupyel wrote:
insyncro wrote:
All but one settled on 2 rotations after driving the van for a minimum of 500 miles.
This is where I have mine set.
edit:
Kombi///M3 wrote:
I have Konis with weitec on my 2wd 7 seater.
I dialed the Konis to max stiff ride and it doesn't
nose dive. I like the way it rides.
Also you guys(gals) the Koni's are only REBOUND adjustable. You are not changing the compression.
yup.
singler3360
singler3360 is offline
PostPosted: Thu Jan 26, 2012 11:41 pm    Post subject: Reply with quote
Got my Koni front and rears from VC this week. The Koni install guide online refers to up to five 1/2 turns clockwise. By 2 rotations, do you mean two 1/2 turns?
70coupyel
70coupyel is offline
PostPosted: Fri Jan 27, 2012 1:09 am    Post subject: Reply with quote
1 rotation = 360 deg.
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
singler3360
PostPosted: Fri Jan 27, 2012 11:27 am    Post subject: Reply with quote
2 rotations = 720 deg. = four 1/2 turns = stiff(er). Was this the preferred setting on all 4 corners?
Thanks, just trying to get an idea of where I should start based on the experience you noted.
presslab
presslab is offline
PostPosted: Fri Jan 27, 2012 11:45 am    Post subject: Reply with quote
My Konis are 0.5 turns out on the front and the rear at 0.75 turns out. And when I say turns out, I mean that the adjuster (shock body) is turned in gently (clockwise) just until the needle is bottomed out, and then the adjuster is turned out (counter clockwise) the specified number of turns.
More turns out means LESS rebound damping.
I have stiffer springs than stock (Moog 5660 front, Slam bags on rear) so keep this in mind, but it should be a useful data point.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
singler3360
PostPosted: Fri Jan 27, 2012 12:09 pm    Post subject: Reply with quote
CORRECTION:
2 rotations = 720 deg. = four 1/2 turns = SOFTER
911pickup
911pickup is offline
PostPosted: Fri Jan 27, 2012 7:04 pm    Post subject: Reply with quote
singler3360 wrote:
CORRECTION:
No, 4.5 turns is maximum stiffness.
http://www.koni.com/193.html
presslab
presslab is offline
PostPosted: Fri Jan 27, 2012 7:15 pm    Post subject: Reply with quote
911pickup wrote:
singler3360 wrote:
CORRECTION:
Really, it depends on whether you are measuring turns IN or turns OUT. I prefer to use turns OUT, as that to me is a more repeatable adjustment. Koni's instructions reference turns IN.
singler3360
PostPosted: Sat Jan 28, 2012 5:37 pm    Post subject: Reply with quote
presslab wrote:
911pickup wrote:
singler3360 wrote:
CORRECTION:
Do you think we are talking the same thing, only the reference is different? If you are holding the bottom of the shock stationary and turning the dust cover (rears), then clockwise increases stiffness. On the fronts, if the rod is held in place with a vice, then turning the bottom body of the shock counter-clockwise increases stiffness.
Nice day here today so I Just installed the rear shocks. Very easy. The maximum turns to stiffness was 4 half-turns, so I set them at 2 half-turns, or 360 deg or one rotation. I hope this is what is meant by Peter at VC and others as "2 turns". We drive washboard frequently on trips, so a slightly softer setting is preferred. My driveway is not level, but it appears the Konis lifted the back by ~1" to 16" with stock springs. Very Happy Now the van is nose down slightly and I really want to get the fronts on tomorrow (if it's not pouring rain).
If my thinking on this is off and I'm just not getting it, someone please correct my posts so that I can adjust them soon. I'm thinking of setting the fronts to 1 half-turn from max. stiffness (4 out of 5 half-turns counterclockwise).
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Feb 20, 2012 11:13 pm    Post subject: Reply with quote
singler3360,
I have 4 new Koni shocks in hand and wonder about the initial setting too.
My goal is a ride my family can live with. 1990 Multivan with stock springs.
Traditionally we always set Konis either total soft or 1 full turn (360) for the many sets we put in various cars over the decades. But, never a Vanagon.
So my initial thought is to go 1 turn from the bottom or hardest setting. We always set them hard and back out. Only way to get repeatable results just as Presslab states earily on here.
So did your shocks settle in?
TIA,
Walt...
dubbified
dubbified is offline
PostPosted: Tue Feb 21, 2012 7:34 am    Post subject: Reply with quote
I'm trying to figure out whether I am going to Koni for my van..
Anyone in Seattle area care to take me for a ride?
Smile
singler3360
PostPosted: Tue Feb 21, 2012 9:33 am    Post subject: Reply with quote
r39o wrote:
singler3360,
TIA,
Walt...
I haven't had a chase to remeasure ride height, but the I think they have settled in. At one full rotation (360 deg) on the rears with stock Westy not loaded for a trip ( no rooftop box, water, gear, etc), the ride feels slightly too stiff on asphalt. Backing off a 1/4 turn might be good but I don't want to change until we have a loaded trip on dirt.
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Feb 21, 2012 12:46 pm    Post subject: Reply with quote
What about the front?
My van is lighter from the factory. I am thinking of a half turn or just full soft to start.
The front is the major area of concern (or the old shocks are the most worn in the front and do not have much, if any, rebound control - meaning I can modulate the front end bouncing with the brake pedal. The kids enjoy this play, but it is not good for driving.....read she who shall be obeyed hates the ride currently and I MUST make her happy.)
singler3360
PostPosted: Tue Feb 21, 2012 7:54 pm    Post subject: Reply with quote
I did one 1/2 turn on the front out of 5 for a stiffer ride and like it so far.
madspaniard
madspaniard is offline
PostPosted: Tue Mar 13, 2012 2:07 am    Post subject: Reply with quote
I'm confused by the Koni online instructions
Th sketch shows a shock with the main body at the bottom and the dust cover (rear) or rod (front) at the top and goes to say:
1.Fully compress the shock absorber, at the same time turning the dust cap or piston rod slowly to the left (anti-clockwise), until it is felt that the cams of the adjusting nut engage in the recesses of the foot valve assembly (fig. 1).
NOTE: Some shock absorbers include a bump rubber concealed under the dust cover and this must be removed prior to adjusting. Don’t forget to re-install.
2.Keeping the shock absorber compressed make 1 full turn (360°) to the right (clockwise). The total range is about 5 half turns (fig. 2).
3.Extend the shock absorber vertically for at least 1 cm without turning in order to disengage the adjusting mechanism. The dust cap or piston rod may now be turned freely.
so, when you are done with step one above, are you at the stiffest or at the softest setting?
thatvwbusguy
thatvwbusguy is offline
PostPosted: Tue Mar 13, 2012 4:36 am    Post subject: Reply with quote
Unless you have previously adjusted the shock, they will be at the softest setting.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
presslab
presslab is offline
PostPosted: Tue Mar 13, 2012 7:21 am    Post subject: Reply with quote
Neither. You would have one turn more damping than when you started. It seems they forgot to say to turn counter-clockwise until the stop.
Fully counter-clockwise is fastest rebound (soft, less). Fully clockwise is slowest rebound (stiff, more).
I adjust mine a little different than the Koni instructions.
1. Compress shock fully.
2. Insert hex key in shock shaft (for the front), and turn clockwise while pushing down.
3. You'll feel the shaft drop down slightly, now you are engaged with the adjuster.
4. I turn the hex key clockwise until I feel it stop. Be gentle, don't force it into the stop, and slightly push down while turning.
5. Now turn counter-clockwise the amount desired for adjustment. This is where I deviate. The more turns counter-clockwise, the faster (softer, less) the rebound damping.
Currently I use 0.5 turns out in front and 0.75 in back. The desired rebound adjustment depends greatly on the spring rate. A stiffer spring needs more rebound damping, so my adjustment is appropriate for Moog 5660 in front and SS-6 bags in rear. Heavy wheels also need more rebound damping.
There is a big difference between 1 turn out and 0.5 turn.
dubbified
PostPosted: Tue Mar 13, 2012 9:35 am    Post subject: Reply with quote
Anyone using these with GW 2wd lifting springs, without modifying anything?
madspaniard
PostPosted: Tue Mar 13, 2012 11:06 am    Post subject: Reply with quote
Thanks Ryan,
I found a bit more detailed instructions here:
http://www.koni-na.com/adjustment.cfm
Adjustment Procedure 76, 80, 82, 86, 87, 88, 90, 8040, 8240 Series
Rebound Adjustment Procedures
Remove the shock absorber from the vehicle and hold it vertically with the lower eye or pin attached in a vise. Use clamp plates to prevent damage.
Fully collapse the shock absorber, at the same time turning the dust cap or piston rod slowly to the left (counterclockwise), until it is felt that the cams of the adjustment nut engage in the recesses of the foot valve assembly.
Some shock absorbers include a bump rubber concealed under the dust cover and it must be removed prior to adjusting.
The damper may have already been adjusted. Therefore check whether the shock absorber is in the adjustment position or not by keeping it collapsed and gently turning it further to the left counting at the same time the half turns until a stop is felt. Stop turning then and do not use force.
Keeping the shock absorber collapsed, make 1 half turn (180 degrees) to the right (clockwise). In case of prior adjustment add the number of half the turns previously found. The total range is about 5 half turns.
Pull the shock absorber out vertically without turning for at least 1 cm to disengage the adjusting mechanism. The dust cap or piston rod may now be turned freely.
ADJUSTING DIRECTION
Clockwise = Firmer
Counter Clockwise = Softer
911pickup
PostPosted: Tue Mar 13, 2012 5:39 pm    Post subject: Reply with quote
Presently, I have my front konis on a half turn (180 degrees) and my rear Konis on one full turn (360 degrees). The van feels good, and I don't plan on touching the setting again until I install my lowering springs and sway bars.
I don't mind taking my rear Konis off for an adjustment, but the fronts are a pain to take off just for an adjustment.
Ron
Page 4 of 8
