Squareback17 Samba Member
Joined: December 19, 2005 Posts: 23 Location: Orange County, Ca
Posted: Mon Jan 16, 2006 10:22 am Post subject: type 1 trans? |
Im looking to start stockpiling parts for my 66 square project and I'm looking into transmissions. Are type 3 trannies and tyoe 1 trannies interchangable? It seems like all i can find out there is bug or bus trannies |
GjMan Samba Member
Joined: June 05, 2004 Posts: 822 Location: Grand Junction, CO
Posted: Mon Jan 16, 2006 11:17 am Post subject: |
Pretty much. What IS different is the selector rod (hockey stick); T1 has the set screw detent on the top, T3 has it on the bottom. You can use the T3 rod on the T1 trans. You could theoretically drill a T3 detent into a T1 rod, but it has to be placed exactly--a tiny bit off and you will never get it to shift right. There are also different axle lengths. You want long. |
thejoe138 Samba Member
Posted: Mon Jan 16, 2006 11:27 am Post subject: |
if you're going to run aftermarket wheels you may want to
use the short axles, but you will need T1 brakes also. |
Posted: Mon Jan 16, 2006 1:01 pm Post subject: |
thanks for the advice. I am planning on running 5-spoke empi's so does that mean I'll want to go with the short axes? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Jan 16, 2006 5:46 pm Post subject: |
check the rear end ratio's?? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Mon Jan 16, 2006 6:00 pm Post subject: |
thejoe138 wrote: |
Type 3 backing plates bolt up to a Type 1 transmission. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Bobnotch Samba Member
Posted: Mon Jan 16, 2006 7:37 pm Post subject: |
thejoe138 wrote: |
Or machine 5/8ths off the nose of the type3 drum, so it'll fit the short spline t-1 axle. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
jimmynotch Samba Member
Joined: February 11, 2003 Posts: 2901 Location: sacramento
Posted: Mon Jan 16, 2006 9:11 pm Post subject: |
I recently swapped trannys and I have run into a bit of an issue. I have a 65 notch and the tranny that came out of the car was geared a bit different than the one I put in. The one I put in was a rebuild out of a '67 square and it is geared much different (lower) in 3rd and fourth. With the OG tranny I could maintain 65-70 MPH without winding the motor too much. Witht he new tranny I am lucky to stay at 65 without pushing 4500 RPM constantly. I was told that the tranny I put in was probably a type 1 with a Type 3 nose cone... Anyway, as of now It really sucks for freeway driving. Any input on this thread would be appreciated, though I think it has been covered a few times before. _________________ Jim in Sacto -
my wonderful loving supportive wife wrote: |
You guys are dorks. |
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2 |
GjMan Samba Member
Posted: Tue Jan 17, 2006 10:19 am Post subject: |
There are two ring and pinion ratios for SW transaxles, 4.37 and 4.12, with most T3s using 4.12 and most T1s 4.37. T1s went from 4.37 to 4.12 at some point, but somebody more knowlegeable will have to jump in. |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Tue Jan 17, 2006 11:08 am Post subject: |
According to Kennedy Engineering (I have no idea how accurate this is):
3.88 '62-'64
4.13 '65-'66 '68-'70
4.13 '67
3.88 '71-'72
3.88 '72-'77
Not sure why they list Type 3s to 77 ?? _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Tue Jan 17, 2006 6:03 pm Post subject: |
I am going from the Without Guesswork book, 1960-1970.
Final drive ratios
Type 1 1200/1300 = 4.375
Type 1 1500/1600 = 4.125
Type 2 1200/1500 = 4.125
Type 3 all = 4.125
Type 2 1600 = 5.375
So, It looks like if you use a 6V T-1 tranny, you get the 4.375 ratio
If you use the 12V T-1 or any T-3 tranny, you get the 4.125 ratio. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
