TheSamba.com So Cal Imports
New Mid-travel Manx Body & Chassis
Goto page Previous  1, 2, 3, ... 11, 12, 13  Next
Forum Index -> Off-Road
dansparts
dansparts is offline
PostPosted: Fri Feb 03, 2006 10:23 am    Post subject: Reply with quote
Does 4900.00 include the body?If that is just the rollcage tat is ridiculous expensive.
The body is not in that price. The body only cost is $2200.00
We are not selling a roll cage. we are selling a complet chassis which has the inside cage, outer rear cage for the motor, the cage supports that need to welded to the torsion tube and frame horns that will tie the inner cage and the rear cage together and the price includes the front tube chassis that has a 6" wider beam built into it. You will have to cut off the front frame horn and weld in a plate that is supplied with the kit. The 4 sections will all come together to make a tube chassis car. The only reason we used the stock pan is to make it street legal. We also tried to make this chassis kit a 100% bolt-on to your pan but we could not get the strength we wanted, so there are some pieces that you will need to weld on.
Baja Ben
Baja Ben is offline
PostPosted: Fri Feb 03, 2006 11:21 am    Post subject: Reply with quote
Any picks of the j arm set up, and what type breaks are you using and what sterring set up to plan to use with the j amr set up.
Baja
ben
Baja Ben.
Why do I try to wright some sort of banter down here. It doestnt mean anything
dansparts
PostPosted: Fri Feb 03, 2006 6:34 pm    Post subject: Reply with quote
Baja Ben; we are still working on that set up and should have it done in the next couple of weeks, I'll post some pic's of it as well as prices. as for the brakes I'm uesing the new Pro X Series with 3000M Micro stubs in the rears and Pro X Series for Combo spindle in the front. Both brakes use Wilwood calpers.
dansparts
PostPosted: Sun Feb 05, 2006 8:54 pm    Post subject: Reply with quote
Here's some progress pictures of the rear suspension.
This one is at ride height.
This is at full compression.
and this is at full droop. I'm getting 17" of travel with the 5x5 arms and 14" 2.0 Fox shocks. I should have the front done in the next couple of weeks so I can get the car on the ground as a roller. Pray
ft_irwin_73baja
ft_irwin_73baja is offline
PostPosted: Sun Feb 05, 2006 9:00 pm    Post subject: Reply with quote
So, just what exactly would your customers get for the $4900.00?
If it's good for ancient Druids, runnin' nekkid through the wuids, Drinkin' strange fermented fluids, it's good enough for me! - Pete Seeger
dansparts
PostPosted: Sun Feb 05, 2006 9:23 pm    Post subject: Reply with quote
Fort Irwin; A couple post back Ilisted what is in the chassis kit. I've post pic's of only the inner cage and rear cage but I should have the front pic's posted in a week or two. then you should see ALL the components of the kit.
TurboLark
TurboLark is offline
PostPosted: Mon Feb 06, 2006 8:31 am    Post subject: Reply with quote
Thats a really high price for what you are offering. You can buy a cro moly sandrail chassis(more tubing than you are offering), with front a arms and spindles, and rear trailing arms for almost 1000.00 less.
MB Products 4 seat beam chassis - 091 trans, 2332 VW
dansparts
PostPosted: Mon Feb 06, 2006 10:50 am    Post subject: Reply with quote
Tubrolark; I'm not building a sandrail chassis. I'm building a dual sport that will be street legal and when I'm done with the chassis it will have more D.O.M. tubing then a sandrail. I sell other chassis that are less money and have less quality then the chassis were building for this Manx. I will have some pic's in the next couple of weeks of the whole chassis put together with the body off and every can see what the chassis is.
bajaherbie
Samba Sooner
bajaherbie is offline
PostPosted: Mon Feb 06, 2006 3:42 pm    Post subject: Reply with quote
you've got good prices in you ad on page 25 of the new hot vw magazine. your buggy looks damn good too.
do you take payments? Laughing
blank
volksbuggy
volksbuggy is offline
PostPosted: Mon Feb 06, 2006 5:16 pm    Post subject: Reply with quote
those buggys are looking really nice man
i have a quasi-offtopic question-in the green buggy whats the deal on the rear seat? do you sell those?
thanks
dansparts
PostPosted: Mon Feb 06, 2006 6:43 pm    Post subject: Reply with quote
Yes we do, they are PRP seats.
BowlRider
BowlRider is offline
PostPosted: Mon Feb 06, 2006 11:24 pm    Post subject: Reply with quote
hey dan nice build!i'm looking for a set of rims. are those cms? $?
rex
dansparts
PostPosted: Tue Feb 07, 2006 12:27 am    Post subject: Reply with quote
no, there BTR racing wheels.
http://www.thesamba.com/vw/classifieds/detail.php?id=270914
dansparts
PostPosted: Fri Feb 10, 2006 9:26 pm    Post subject: Reply with quote
Here's a couple of new pictures of some of the progress over the last week.
Rear cage off with 5x5 arms
Start of front suspension
Tack up Tweed beam
Front seat mounts for PRP seats
dansparts
PostPosted: Mon Feb 13, 2006 10:33 pm    Post subject: Reply with quote
Here's some more progress pic's Very Happy
UKbillybob
UKbillybob is offline
PostPosted: Tue Feb 14, 2006 2:50 pm    Post subject: Reply with quote
They are very nice looking wheels.
Do they come with the centre caps for that price?
What size wheel & tyre combo are you running on the green buggy and the blue buggy.
dansparts
PostPosted: Wed Feb 15, 2006 12:07 am    Post subject: Reply with quote
UK Billy; The rims do not come with center caps. The pic's of the rims on the green manx show the cover of the micro stub axle brakes, so it looks like the rims have center caps.
dansparts
PostPosted: Wed Feb 15, 2006 12:11 am    Post subject: Reply with quote
Here's more progress pic's
BowlRider
PostPosted: Thu Feb 16, 2006 9:11 am    Post subject: Reply with quote
is your tranny offset to the right?
HamburgerBrad
Je suis Napoléon!
HamburgerBrad is offline
PostPosted: Thu Feb 16, 2006 9:57 am    Post subject: Reply with quote
091 trans is built offset at the bellhousing. skidmark's car:
OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels
Reply to topic    Forum Index -> Off-Road All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 13
Copyright © 1996-2009, Everett Barnes. All Rights Reserved.   | Archive
