sb001 Samba Member
Posted: Sat Oct 22, 2016 11:42 am Post subject: Re: Automatic Stick Shift. |
montex01 wrote: |
Does the Three Speed tranny have it's own fluid seperate from the torque converter ATF? If so How do you change that fluid? Is the replacement at 75w-140w?
Thank you so much. |
Yep, the 3-speed tranny itself uses 80-90w hypoid oil.
Drain plug should be up front on the underside of the tranny, however I have seen some autostick trannies that had no drain plug, in this case you simply drain it by removing the drain pan.
Fill plug is on the left side of the transmission just above the left frame fork
_________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
montex01 Samba Member
Posted: Sun Oct 23, 2016 4:58 am Post subject: Re: Automatic Stick Shift. |
WOW! You are the best! I'm very excited and Thank you so much.
John |
itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Sun Oct 23, 2016 7:22 am Post subject: Re: Automatic Stick Shift. |
I paid too much $3000.
And, from somebody in the Midwest I can say that good autostick vehicles are rare because of previous conversions.
I think scarcity has too have locality thrown in, otherwise it doesn't mean much.
Yours probably has less rust on it than mine. Before you decide to go super beetle, might check in with whatever vw club in savannah you can find, somebody from there may be able to point you to an autostick expert near that locality.
Good luck, with whatever you do, and good luck in school!
Kyle _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.) |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Sun Oct 23, 2016 9:56 am Post subject: Re: Automatic Stick Shift. |
10yo thread....
-jeffrey _________________ Der Kleiner Kampfwagens |
johnjhazel Samba Member
Joined: September 18, 2009 Posts: 86 Location: Phoenix, AZ
Posted: Mon Dec 26, 2016 1:18 am Post subject: Re: Automatic Stick Shift. |
I dare say that autosticks are rare NOW. Not much of a selection out there. |
fatdog Samba Member
Joined: April 23, 2015 Posts: 68 Location: United States western N.Carolina
Posted: Mon Dec 26, 2016 10:07 am Post subject: Re: Automatic Stick Shift. |
There is separate gear oil in the tranny, the ATF is just for tge torque converter. The autos I've had required you to drop the plate on bottom of the trans to drain but I've read that some models have a drain plug. Make sure to use a hypoid gear oil for transaxles. _________________ Be carefull not to outsmart your common sense. |
Posted: Fri Jan 20, 2017 12:11 am Post subject: Re: Automatic Stick Shift. |
Using counts from this site, for all states, for the model years that autosticks were sold, 1968-1976, autosticks account for only 3%. And about half of that 3% are beyond my help. I declare autosticks rare. LOL. |
jcdavis081 Samba Member
Joined: March 15, 2017 Posts: 8 Location: Charlotte, NC
Posted: Fri Mar 17, 2017 8:59 am Post subject: Re: Automatic Stick Shift. |
Currently resurrecting my wife's garage kept 71 super beetle that is an autostick.......so maybe one more in the mix makes them not so rare:). But I also don't have it running yet so don't count it as one yet!
I want to make sure I'm correct on this.....If I siphon out the ATF oil that I can get to from the engine compartment fill cap. Will I be getting oil from the transmission or the torque converter?
Once this oil is out what exactly should I be replacing it with.
Just think the guy that started this thread is out of college by now and by some of his original comments he should be a director for the last two or three years! |
sb001 Samba Member
Posted: Fri Mar 17, 2017 11:44 am Post subject: Re: Automatic Stick Shift. |
jcdavis081 wrote: |
Welcome to the autostick world!
Yes the fill pipe you see in the engine bay is just for ATF for the torque converter. And yes, you can siphon the fluid out that way, but it is MUCH easier (and probably a more complete drain) to undo the flex line underneath the tank and drain it that way (see my photo earlier in this thread.)
You can use any Dexron III compatible ATF fluid. _________________ I'm the humblest guy on this board.
1600 SP engine
randydog Samba Member
Posted: Mon Dec 18, 2017 4:53 pm Post subject: Re: Automatic Stick Shift. |
what is rare is to find a ass with it's butt welded in germany during the first and same time year the ass arrived in america with I.R.S. and had a better ass than it (356) lol! |
Alikhoso Samba Member
Posted: Tue Jun 25, 2019 7:36 am Post subject: Re: Automatic Stick Shift. |
Is this possible to switch/convert car with manual transmission into autostick shift? What website would help me in doing it? |
jwp67 Samba Member
Posted: Wed Jun 26, 2019 2:12 pm Post subject: Re: Automatic Stick Shift. |
https://www.thesamba.com/vw/forum/viewtopic.php?t=124538
A search brought up this topic. I hope it helps. Most people won’t approach the subject as if it were a sacred thing. _________________ 21 million of these cars were built,and everyone of them were sold...kinda astounding given how unreliable they are.---johhnypan |
