coolrydes Samba Member
Posted: Thu Jul 03, 2014 10:35 pm Post subject: |
GLHTurbo wrote: |
reminds me of a Storm Trooper
As for the vent on the oil filler, a hose/tube goes to that, below the tin to the ground? Do you put a filter on the end or anything to keep the underside nice? I need to do something similar for my build...
and how did you run those plugs wires? |
Breather is going to be in the right rear fender area, while the oil cooler is in the left rear. As for the plug wires they go out through the bottom of the fan shroud below the alt stand.... _________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
Posted: Thu Jul 10, 2014 6:34 pm Post subject: |
CoolRydes So-Cal Customs next Turbo injected motor in moch-up...
MENDEOLA SUSPENSION
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Fri Jul 11, 2014 8:18 am Post subject: |
coolrydes wrote: |
Incredible! Very clean looking. |
Dauz Samba Member
Posted: Thu Jul 17, 2014 3:40 pm Post subject: |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76946 Location: Sneaking up behind you
Posted: Thu Jul 17, 2014 6:47 pm Post subject: |
Everytime I see that I wet my pants... AWESOME _________________ Glenn
Member #1009
#BlueSquare |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Fri Jul 18, 2014 7:46 am Post subject: |
^----I think I just came..... _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
LowType2 Samba Member
Posted: Fri Jul 18, 2014 9:41 am Post subject: |
How does one accomplish this and what is the cost?? It is amazing! _________________ ~Eric |
Glenn Mr. 010
Posted: Sat Jul 19, 2014 11:25 am Post subject: |
Gary Berg 1904. The attention to detail is top notch.
Member #1009
#BlueSquare |
Posted: Tue Jul 22, 2014 12:28 pm Post subject: |
Another engine I did awhile back that the guy never finished the install....
MENDEOLA SUSPENSION
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
cseay1 Samba Member
Joined: March 22, 2012 Posts: 1341 Location: Elkwood VA
mabbo Samba Member
Joined: October 13, 2004 Posts: 208 Location: United Kingdom
Posted: Sun Aug 24, 2014 2:44 pm Post subject: |
Brian Silva Samba Member
Posted: Wed Sep 03, 2014 3:11 pm Post subject: |
Here is picture of my current 2332cc engine with IDA's. I had a magneto on it before but decided to modernize the ignition system and went with a full msd setup. Loved the look of the mag just had a few downsides..
Hotrodvw Samba Member
Posted: Wed Sep 03, 2014 3:32 pm Post subject: |
Looks awesome Brian!
Eric _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Glenn Mr. 010
Posted: Wed Sep 03, 2014 4:22 pm Post subject: |
So many IDAs, so few air filters. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Sep 03, 2014 4:25 pm Post subject: |
Been torn down a couple times since running these, nice signs of wear. To each their own.
Eric
lots of money!
Hose & Fittings |
Posted: Wed Sep 03, 2014 6:03 pm Post subject: |
Thanks Eric! your fitting worked great btw! I agree with you Glen..I have socks I put over the stacks when driving around but the car is a weekend warrior and only sees 2-3k miles per year. On the other hand, if I drove it as many miles as your car, I WOULD definitely have air cleaners of some sort. |
67Callooker Samba Member
Joined: January 24, 2008 Posts: 158 Location: las vegas
Posted: Fri Sep 05, 2014 3:12 pm Post subject: |
Brian Silva wrote: |
what issues were you having brian ? _________________ "dumbass" red foreman if you paint an engine case you probably forgot the tin |
Posted: Fri Sep 05, 2014 4:12 pm Post subject: |
The mag was cutting spark around 6800-7000 rpm. Also, the auto meter rev limiter wasn't accurate at all. The other part was that we couldn't get a torque reading on the dyno because of the magnetic field. Would have loved to see the torque reading. We got to 195hp at the wheels at 7k and it still had a lot left in it. |
Posted: Fri Sep 05, 2014 10:05 pm Post subject: |
i had problems with the auto meter signal convertor for the tach and just found a tach on a hot rod site stack st 200 clubman tachometer which states it can be used with a magneto ignition I'm going to try that nice hp I'm sure you can get more out of it ! i also have an old auto meter magneto tach but the wiring seems to be for a v8 where the loop to go around the mag wire is close to the firewall so i don't think it would work _________________ "dumbass" red foreman if you paint an engine case you probably forgot the tin |
