City_Masher Samba Member
Joined: January 22, 2006 Posts: 40 Location: Rain City, Oregon
Posted: Fri Feb 10, 2006 4:48 pm Post subject: Help me ID the components I need for this |
So I can start looking for these parts and purchase them soon, please tell me the tech names of the parts that I need to complete what I am missing
What I need
What I have
Thanks |
redbug74 Samba Member
Joined: June 15, 2004 Posts: 292 Location: Far West Texas
Posted: Fri Feb 10, 2006 4:52 pm Post subject: |
Stock type 3, duel 32pdsit carb air cleaner assembly. Hey ! you more knowledgable guys.... did I leave anything out? |
Posted: Fri Feb 10, 2006 5:11 pm Post subject: |
cool, thank you.
As for the guts, the stuff I don't see under the tin. Is that it?
>>>>>Stock type 3, duel 32pdsit carb air cleaner assembly<<<<<< |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Fri Feb 10, 2006 5:58 pm Post subject: |
Yep, stock oil bath air cleaned, mounting bracket in back, rubber boot off inside engine bay and the assembly that ataches to the inner engine bay. Russ more than likley has the parts diagram. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Fri Feb 10, 2006 6:00 pm Post subject: |
Well, without really tweaking on it, it looks like you have some funky carb linkage going on, no heater boxes (need to cap off the fan), the return spring for the carb linkage looks incorrect.. although i may be wrong. is that engine installed? is it an earlier 1600cc engine in an IRS car? _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Feb 10, 2006 6:03 pm Post subject: |
notchboy wrote: |
Yep, stock oil bath air cleaned, mounting bracket in back, rubber boot off inside engine bay and the assembly that ataches to the inner engine bay. Russ more than likley has the parts diagram. |
http://classicvw.org/gallery/main.php?g2_view=core.ShowItem&g2_itemId=5697
You need the #10 style. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri Feb 10, 2006 6:07 pm Post subject: |
tell you the truth, I have no idea. Sorry.
It seems to be my luck with cars, so I would assume that it is an earlier year engine in a later year body. That's what seemed to be the story in my old gti. a 89 1.8l 16v transplant in a 90' body. I found that out when Dean from Futrell Auto werks told me. So I wouldn't be surprized if it was.
But cool, thanks for the info about what is missing.
Are these hard to find? I keep lookin in the classifieds here, and haven't seen any - but since I know what it is now, I will have better luck.
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1084 Location: Dover, DE
Posted: Fri Feb 10, 2006 6:30 pm Post subject: |
It looks like some one bent the left carb linkage to shorten it to fit. Also is that a transmission dipstick? You got an early motor on a late trans or someone converted the car to carbs. I guess I'm not the only one intimidated by FI. _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
Posted: Sat Feb 11, 2006 2:42 pm Post subject: |
Thanks guys and gals! |
Posted: Sat Feb 11, 2006 3:00 pm Post subject: |
First one is the better deal. It has the wing nuts for the carb, and the second one doesn't.
The second one does have the rubber boot. at the joint. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Feb 11, 2006 5:03 pm Post subject: |
Masher, if I'm seeing the pic of your engine right, you also need the little short snout that connects the aircleaner to the body. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sun Feb 12, 2006 5:39 pm Post subject: the short snout? |
If I need a snout, I need a snout. I guess I need a snout too.
Well, I have the money to buy. Just sent a messege to one person. About to send it to someone else too (about the linkages.)
hmmm, what can you tell me about this ... "snout" I'm hearing about?
Thanks guys! Now is the time for the t3i prep! |
Posted: Sun Feb 12, 2006 5:43 pm Post subject: |
>>>>>>>>>>Also is that a transmission dipstick? You got an early motor on a late trans or someone converted the car to carbs. I guess I'm not the only one intimidated by FI<<<<<<<<
what sould this mean? |
Posted: Sun Feb 12, 2006 6:08 pm Post subject: Re: the short snout? |
City_Masher wrote: |
I might have one around. I'll check. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
