BDubVdub Samba Member
Posted: Mon Jun 11, 2012 5:58 pm Post subject: |
| a1steaksauce wrote: | | you can shim your rear to get rid of the camber. |
Where would it have to be shimmed? |
a1steaksauce Samba Member
Posted: Mon Jun 11, 2012 6:11 pm Post subject: |
it was discussed a few pages back.
as i have not done it myself i'm not the one to advise on the procedure. |
Posted: Mon Jun 11, 2012 6:41 pm Post subject: |
| a1steaksauce wrote: | it was discussed a few pages back.
I just went from page 160 to here and didn't see anything. I'll do a quick search. Thanks |
Posted: Mon Jun 11, 2012 7:26 pm Post subject: |
Found it.
"Actually, when lowering the rear, you can maintain good camber if you shim on the top bolts between where the spring plate and trailing arm meet." |
Posted: Mon Jun 11, 2012 7:38 pm Post subject: |
| BDubVdub wrote: | Found it.
that's it.
i went with a massive amount of lowering and narrowing on my rear so i cut and repositioned my inner trailing arm mounting point to yield me the same result  |
Posted: Mon Jun 11, 2012 7:42 pm Post subject: |
| a1steaksauce wrote: | | BDubVdub wrote: | Found it.
that's it.
I was considering doing the same. |
Posted: Mon Jun 11, 2012 7:47 pm Post subject: |
the only problem with doing so is that it's a very drastic change.
i'm narrowed 2.5 inches out back with massive frame notches for axle clearance. so to me it wasn't a big deal to simply reposition those inner mounting points as that wasn't more extreme than anything else i had done.
but if you're simply running drop plates out back and everything else is untouched i advise against messing with the inner mounting points and just shimming out the rear to correct the negative camber. |
Posted: Mon Jun 11, 2012 7:52 pm Post subject: |
| a1steaksauce wrote: | the only problem with doing so is that it's a very drastic change.
Cool. Thanks for the advice. I have notched the rear, too. |
67T1 Samba Member
Joined: September 30, 2007 Posts: 465 Location: Eh-SPAIN
Posted: Tue Jun 12, 2012 7:51 am Post subject: |
| Notvanity wrote: |
I love this Russian beast! _________________ '67 Bug
'71 Bay Double Cab |
fastwagens Samba Member
Joined: March 01, 2004 Posts: 1032 Location: Michigan (The other west coast)
Daverham Samba Member
Joined: August 27, 2009 Posts: 1214 Location: Seattle
Posted: Thu Jun 14, 2012 9:36 am Post subject: |
Hey kids.
I've got my Wagens West 2.5 inch drop spindles . Was thinking of tackling this job this weekend. Just making plans here and I have a wedding I don't want to miss... I've never done much front-end work. How much time should I set aside for doing the spindles?
I have a good selection of tools, jack stands and an impact wrench. Other than that, nothing too fancy.
A tub of wheel bearing grease, a 2-3 hours and I'm good? Looks pretty easy, am I missing something? _________________ 78 Kombi, 65 Bug, 69 Baja Bug, 63 Camper Van, 66 Bug, 72 Bug, 60 Ghia |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5408 Location: Edmonds, WA.
Posted: Thu Jun 14, 2012 9:48 am Post subject: |
| Daverham wrote: | Hey kids.
A tub of wheel bearing grease, a 2-3 hours and I'm good? Looks pretty easy, am I missing something? |
what about me? i bet i could find something to be helpful with
and saturday is the cruise from Bellevue to leavenworth...you dont wanna miss that.... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
galencurrington Samba Member
Joined: March 16, 2004 Posts: 137 Location: bowling green, ky
Posted: Thu Jun 14, 2012 2:18 pm Post subject: |
| Not unless you need to change out ball joints other than that you should be ok but you never know what might pop up Good luck |
Posted: Thu Jun 14, 2012 2:28 pm Post subject: |
Galen: Thanks for the reply. That helps me feel good about this. I'll estimate for about 3 hours, I guess. I've peeked at the ball joints. The boots have some superficial cracking, but aren't ruptured, no leaking grease... does that mean they are OK. Or at least probably OK?
Stuart: Was that an offer to help? You done this before, or just want to drink beer and supervise? I won't be going to the cruise. I'd rather get this lowering done. I'm planning on hitting up some meets/cruises later this summer though. _________________ 78 Kombi, 65 Bug, 69 Baja Bug, 63 Camper Van, 66 Bug, 72 Bug, 60 Ghia |
Posted: Thu Jun 14, 2012 2:30 pm Post subject: |
| Daverham wrote: | Galen: Thanks for the reply. That helps me feel good about this. I'll estimate for about 3 hours, I guess. I've peeked at the ball joints. The boots have some superficial cracking, but aren't ruptured, no leaking grease... does that mean they are OK. Or at least probably OK?
Stuart: Was that an offer to help? You done this before, or just want to drink beer and supervise? I won't be going to the cruise. I'd rather get this lowering done. I'm planning on hitting up some meets/cruises later this summer though. |
beer?
im 19 dude...
i wanna see how its done. i have a basic knowledge...and i am a learning a machine...so i figure i can at least help out. worst case, im good with my hands and can turn the wrench for ya
lemme know if ya want my help...ill be busy saturday though. _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Fri Jun 15, 2012 10:13 am Post subject: |
| you'll just have to use your judgement but if the joint is nice and tight and not loose and the boots are not that bad i would say they are find but it you poke one of them while your doing all of this then you probably have to get new boots you can buy just new boots as long as the joint is nice and tight. good luck. |
Posted: Fri Jun 15, 2012 10:44 am Post subject: |
Starting this now! Stoked. Stuart is coming over. Lowering party! PM me if you want to join . _________________ 78 Kombi, 65 Bug, 69 Baja Bug, 63 Camper Van, 66 Bug, 72 Bug, 60 Ghia |
Posted: Fri Jun 15, 2012 3:48 pm Post subject: |
| Daverham wrote: | Starting this now! Stoked. Stuart is coming over. Lowering party! PM me if you want to join . |
DONE AND DONE! looks fantastic...ignore any pics of me that he posts though  _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Fri Jun 15, 2012 5:02 pm Post subject: |
Thanks for your help man. That was priceless. Good times. ^^^ This guy does good work, and he moves fast! I've never met up with a real-life Samba-ite before. Great first experience. Hope to see more of you guys out at some meets/shows this summer.
This took about 4 hours, all told.... no real problems. Needed a tie-rod end remover and my impact wrench was very handy. Other than that, no real "special" tools required.
Before:
Working...
AFTER:
jibznotjobs Samba Member
Posted: Fri Jun 15, 2012 10:35 pm Post subject: |
| Either you two willing to help me as soon as i get my spindles? Itd be nice to have someone help whos done this before.. |
