Lowering a Bay
Goto page Previous  1, 2, 3 ... 167, 168, 169 ... 191, 192, 193  Next
cdennisg
cdennisg is offline
PostPosted: Sun Jun 17, 2012 10:17 pm    Post subject: Reply with quote
^^^ See that hole on the end of the springplate? It is right in the middle of the four bolt holes, and it has a notch cut out of it to the rear. That is the one I was talking about.
Rustbus is right, just do whatever you can to keep the stress off the brake hose while doing your work. I have used a light colored spray paint to mark the location of the rear bearing hub in relation to the spring plate. Once you're all done, just give it all a quick shot of black and it's all purdy again. Some chisel marks or a dab of white out works to mark the baseline location of your torsion bar/springplate connection.
Olddog52 wrote:
horn test. one tab to ground, the other to a 12 volt source. Listen intently for a sound.
Daverham
Daverham is offline
PostPosted: Mon Jun 18, 2012 9:13 am    Post subject: Reply with quote
You guys are awesome. Thanks for the pic! Awesome re-bar jack stands too. Home made?
Look at all those splines! Really.... just rotating ONE of those amounts to 2 inches drop? Amazing.
I'll definitely make sure to not stress the brakes hose or CV joints... and to mark everything, per Bentley. Stuart is probably going to help.... I bet we can do both sides in under 2 hours, including clean up and photos - what do you think? I bet he can do his side in 30 minutes - the guy should work pit crew.
Hole noted - wurd to the Early Bay drivers. Should be already open for me I guess. Thanks again, guys.
78 Kombi, 65 Bug, 69 Baja Bug, 63 Camper Van, 66 Bug, 72 Bug, 60 Ghia
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Mon Jun 18, 2012 10:11 am    Post subject: Reply with quote
I'll definitely make sure to not stress the brakes hose or CV joints... and to mark everything, per Bentley. Stuart is going to help.... I bet we can do both sides in under 2 hours, including clean up and photos - what do you think? I bet he can do his side in 30 minutes - the guy should work pit crew.
fixed that for you. Wink
MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.”
BDubVdub
BDubVdub is offline
PostPosted: Mon Jun 18, 2012 6:30 pm    Post subject: Reply with quote
Lowered mine a little more over the weekend.
Kirk Premium Member
Kirk is offline
PostPosted: Mon Jun 18, 2012 7:31 pm    Post subject: Reply with quote
You sand it down? Stance loosk nice.
Oppenhiem
Bear
Deluxe
BDubVdub
BDubVdub is offline
PostPosted: Mon Jun 18, 2012 7:46 pm    Post subject: Reply with quote
Thanks. I didn't actually sand it. I stripped it with aircraft stripper so I could see how much bondo was on it and where.
autohaus
autohaus is offline
PostPosted: Wed Jun 20, 2012 12:58 pm    Post subject: Reply with quote
drop job with FRENCHSLAMMER Stuff
www.vintageautohaus.com
FRENCHVWMAFIA MEMBER
do not forget, only the mountains do not meet
Daverham
Daverham is offline
PostPosted: Thu Jun 21, 2012 7:26 am    Post subject: Reply with quote
^^^ What a dream bus! Nice job.
As soon as my just-in-case spring plate bushings arrive, I'm going to take my rear end down a notch. I have a pretty precise measurement I'm looking for to get the bus even, so I'll be doing a combo of inner and outer splines. Anyone have some tips on knowing how you're indexing the INSIDE splines? Somebody said "by feel" - anything more to say about that? You pull it out just enough until you can turn it an then just FEEL it bump bump bump as you rotate it? Sounds like it would be very easy to lose count, skip one, etc...
Any tips would be appreciated!
cdennisg
cdennisg is offline
PostPosted: Thu Jun 21, 2012 7:41 am    Post subject: Reply with quote
That's pretty much it. Make sure you clearly mark your starting point with a stripe of paint or a chisel mark so you can get back to square one of you screw up. Also, a ten dollar protractor from the hardware store helps as a guideline for the angle, using the chart that was previously posted.
It really is not that difficult, and once you get going on it, you'll figure it out pretty quick. You may have to do it more than once to get it exactly right. That is why folks often pay for adjustable spring plates. they can be dialed in more easily to achieve the ideal height. They are not necessary, they just make it easier.
Daverham
Daverham is offline
PostPosted: Thu Jun 21, 2012 8:15 am    Post subject: Reply with quote
You, sir are a gentleman and a scholar. Thank you.
beetjunky
beetjunky is offline
PostPosted: Thu Jun 28, 2012 3:51 pm    Post subject: Reply with quote
Who makes adjustable Spring plates for Bays?
Mild-Core
Mild-Core is offline
PostPosted: Thu Jun 28, 2012 4:16 pm    Post subject: Reply with quote
In the US I only know of Bus Boys.
http://www.bus-boys.com/bbsusp.htm#springplates
In the UK I think there are quite a few more suppliers to choose from.
cande83821
cande83821 is online now
PostPosted: Thu Jun 28, 2012 7:37 pm    Post subject: Reply with quote
I bought mine from these guys I'm in the US
These guys are from UK but no problem
http://www.creative-engineering.com
1966 Slammed Vert
1966 Sunroof (Sold it..Bummer)
1955 Hardtop Oval OG
1966 Bahama Blue Sunroof (sold)
1964 Ruby Red Variant S
Invest in the Bank of VW and watch your money grow!
Mild-Core
PostPosted: Fri Jun 29, 2012 11:30 am    Post subject: Reply with quote
Nice, how much was shipping? Did they discount the tax that is included in their domestic UK pricing since you're not in the UK?
cande83821
PostPosted: Sat Jun 30, 2012 12:09 am    Post subject: Creative Engineering spring plates Reply with quote
They did remove the tax. It was 187.50 plus 60.00 for shipping
For a total of 247.50 of course that's in Pounds(UK money)
I can't seem to find the credit card receipt showing the conversion
But just type in dollars to pounds on Google for the converter
It seems like from what I've researched the adjustable spring plates
Are the way to go in the rear, we're saving up to build a king/link pin
For the front now. Plans to go super low on this bus
1966 Slammed Vert
pat1730
pat1730 is offline
PostPosted: Sat Jun 30, 2012 9:35 am    Post subject: Reply with quote
from the UK: http://transporterhaus.de/index.php?option=com_content&task=view&id=176&Itemid=163
Justin Qutami
Justin Qutami is offline
PostPosted: Sat Jun 30, 2012 1:04 pm    Post subject: Reply with quote
Would a late bay lowered front beam (75 or 76) be compatible with a 70 bay so I can get some lowered action and disk brakes or is it more complicated than that?
1967 Bug aka "Junior" (SOLD)
1970 Campmobile aka "Penelope the BEAST"
Student at The Academy of Art University in San Francisco.
http://qutamiart.blogspot.com/
autohaus
autohaus is offline
PostPosted: Sun Jul 01, 2012 10:51 am    Post subject: Reply with quote
http://www.vintageautohaus.com/prod-lamereglablearly.htm
fleetlinebay
fleetlinebay is offline
PostPosted: Wed Jul 04, 2012 8:48 pm    Post subject: Reply with quote
still needs to go lower it looks like a 4x4, but i thought i would share a pic anyway
1977 bus, 1962 beetle,1974 beetle,1973 bus
www.nanaimovwclub.com
fleetlinebay
PostPosted: Wed Jul 04, 2012 8:50 pm    Post subject: Reply with quote
Applause looks good
Page 168 of 193
