Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2940 Location: Fresno, Ca.
Posted: Wed May 21, 2014 11:41 am Post subject: |
Ok fine. Now back to the original question Why not just make it a sticky again? _________________ If you`re going to do something, do it right. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Wed May 21, 2014 11:42 am Post subject: |
Bryan67 wrote: |
Ok fine. Now back to the original question Why not just make it a sticky again? |
Jesus, It ALREADY is a sticky........ _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Wed May 21, 2014 11:46 am Post subject: |
Come on, you know what I mean. The split Bus forum has TWO lowering threads that are stickies. And by sticky I mean attached to the top of the thread listings. _________________ If you`re going to do something, do it right. |
Keith Samba Member
Posted: Wed May 21, 2014 11:48 am Post subject: |
Bryan67 wrote: |
Come on, you know what I mean. The split Bus forum has TWO lowering threads that are stickies. And by sticky I mean attached to the top of the thread listings. |
It's in the top of the thread listings in FAQS/Sticky , it really can't be any easier. It's like opening a book to the index..... Do want the index on the cover of the book ? _________________ Formerly known in the forums as "OVALTEEN"
jfdestree Samba Member
Posted: Wed May 21, 2014 1:34 pm Post subject: |
downhillinlepper wrote: |
updated pics of mine. new shoes.
Can you give some details about your setup?
Which kind of beam, spindles, rear end, wheels size and offset?
Thanks you |
a1steaksauce Samba Member
Posted: Wed May 21, 2014 8:19 pm Post subject: |
Keith wrote: |
Bryan67 wrote: |
It's in the top of the thread listings in FAQS/Sticky , it really can't be any easier. It's like opening a book to the index..... Do want the index on the cover of the book ? |
actually chief it's the most viewed thread in this forum and all it has is a link in the FAQ section. and we all know how well the FAQ section works....that is if people were to actually read it.
i agree that it should be in the sticky section. however the power of the purists is strong in the land of bay windows. they still think lowering is a "fad" that will pass |
downhillinlepper Samba Member
Posted: Tue May 27, 2014 2:03 pm Post subject: |
[quote="jfdestree"]
Thanks you |
Sorry. I don't check this place much. Hardly ever any action around here.
I have the Wagons West slambay kit. Narrowed 4" up front. It's lowered probably around 8" up front, and only 3.5" in back with horseshoe plates. I need to notch the rear so i can level it out. |
ZornigBus Samba Member
Joined: November 04, 2003 Posts: 46 Location: South Jersey
AirKooledGarage Samba Member
Joined: September 28, 2012 Posts: 314 Location: Wisco
Posted: Sun Jun 01, 2014 3:20 pm Post subject: |
Love it. Any shots from below (if that's even possible?) how did you handle the brake booster?
ZornigBus wrote: |
Im in the process of lowering my 75 kombi. Working in the front first.
7" beam raise or flip with top torsion tube now in the cab.
Stock spindles
Narrowed 5"
17" Fuch repos
205/40/17 tires
All fabrication work was done by me. More pics in my gallery.
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Tue Jun 17, 2014 3:28 am Post subject: |
this has been difficult to navigate through..
i have some 2.5 ww spindles. i was thinking of running a set of 215 50 17's (looking for a tall tire to help with gearing) all this on a 70 bus.
any issue this wouldn't work, or will it rub? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
DerKafer71 Samba Member
Posted: Tue Jun 17, 2014 10:02 am Post subject: |
The 215 50 17's are about the same overall diameter but the welded spindles add 7-12 mm, depending on year, increase to track width so check the offset of your wheels to make sure they fit. Might be some rubbing during cornering with more than one person in front. |
Posted: Tue Jun 17, 2014 11:11 am Post subject: |
Have you used them? I hate the "big n little" gasser look _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Jun 17, 2014 12:23 pm Post subject: |
No I haven't. My 79 bay is more of a project than I first thought so lowering and new wheels and tires are not coming soon but I've been reading a lot on other forums that are more "lowering friendly". On page 207 of this thread are some examples of slightly smaller and bigger sizes on some bays. I would be more worried about wheel offset even if you're only using drop spindles. I'm no expert on lowering bays, though from searching most people are slamming and running narrowed beams with 17's. |
Posted: Tue Jun 17, 2014 1:35 pm Post subject: |
see, that's the thing, i'm not 'slamming' it. just wanted to drop it a hair and fill the wheel wells.
this thread is a mess...i have tried to read through it for the past couple weeks, and it seems that it is hard to find the info i am looking for.
back to reading..... _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Jun 17, 2014 3:19 pm Post subject: |
Most retail tire store chains I've dealt with will loan you a tire for a day or two. Assuming long as it doesn't look used when you bring the tire back. Did this in '95 with a 14x10 slotted mag for my flared fendered 74 super. Took home two different sizes to see which looked better(neither). I did have to pay for mounting, $10 IIRC. Nowadays they would probably put a hold on your credit card. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Tue Jun 17, 2014 8:28 pm Post subject: |
skills@eurocarsplus wrote: |
any issue this wouldn't work, or will it rub? |
Much of this will depend on the offset of the wheels you plan to use. Finding specific info will be difficult because of the variety of offsets available. I agree with the above poster's advice about borrowing a tire from the tire store. If you have a good repoire with them, and you buy tires locally, they will likely help you out. _________________ nothing |
Notvanity Samba Member
Joined: March 30, 2011 Posts: 57 Location: Russian Federation Moscow
Posted: Wed Jun 18, 2014 7:52 pm Post subject: |
cdennisg wrote: |
Much of this will depend on the offset of the wheels you plan to use. Finding specific info will be difficult because of the variety of offsets available. I agree with the above poster's advice about borrowing a tire from the tire store. If you have a good repoire with them, and you buy tires locally, they will likely help you out. |
i have an account with k&w tire, as well as clown fair. the issue is that although the rim clamp machine i have is good, every mount and dismount makes the chance for damage that much greater. and seeing the tires have to be mounted with the rim upside down due to drop centers, i put little faith in the plastic covers protecting my wheels _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Jun 18, 2014 8:08 pm Post subject: |
cdennisg wrote: |
i have an account with k&w tire, as well as clown fair. the issue is that although the rim clamp machine i have is good, every mount and dismount makes the chance for damage that much greater. and seeing the tires have to be mounted with the rim upside down due to drop centers, i put little faith in the plastic covers protecting my wheels |
I can certainly understand the dilemma. But you might just have to break a few eggs to make that delicious cake. _________________ nothing |
