Glenn A Samba Member
Posted: Mon Aug 18, 2014 1:01 pm Post subject: |
My contribution.
mannys66 wrote: |
In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it. |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
covdubguy Samba Member
Joined: May 31, 2012 Posts: 37 Location: Centennial Colorado
Posted: Mon Aug 18, 2014 7:29 pm Post subject: |
I was reading another thread and came across these guys in the UK selling through rods and coil over shocks as another way to lower a bus.
Here is the link
http://www.red9design.com/type2.htm
What do you all think?
They also sell a really sweet looking front a-arm kit. _________________ 74 bus
Berrian warrior
Some other rail
Dirty hippies give busses a bad name |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Mon Aug 18, 2014 10:55 pm Post subject: |
covdubguy wrote: |
Here is the link
They also sell a really sweet looking front a-arm kit. |
If they do nothing to beef up the lower trailing arm shock mount, I would pass. That system appears to put the entire weight of the bus on that one little lower bolt. Not good enough for me. _________________ nothing |
Posted: Tue Aug 19, 2014 5:39 am Post subject: |
covdubguy wrote: |
Here is the link
It doesn't appear that either one of those solutions are narrower that stock. In order to prevent the tires from rubbing the doglegs on a lowered bus you have to narrow the front suspension. _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
J K Samba Member
Joined: August 07, 2014 Posts: 17 Location: Rogers, AR
Posted: Wed Aug 20, 2014 3:04 pm Post subject: |
Glenn A wrote: |
My contribution.
love the stance on yours, exactly what i'm looking for. tried searching your other posts and sadly, it looks like the only way to achieve this is by cutting and then adding the "tubs" ? not sure if that's correct, still trying to learn, but it looks like you've cut and then added a tub upside down to get more wheel clearance? is there another thread where you discuss your particular set-up? guessing the only way to use your tire/wheel combination/size and have that lowered stance, you have to use the tubs? |
Dogo Samba Member
Posted: Wed Aug 20, 2014 3:46 pm Post subject: |
Glenn A wrote: |
My contribution.
Your contribution would be to share specs
I guess, based on your album pics, you did tub the front. Does it really need them though? Seems "mildly" lowered (by some standards, I suppose). Looks like you would have decent clearance even without tubs.
Did you need to C-notch the frame at rear? |
Posted: Wed Aug 20, 2014 4:35 pm Post subject: |
Up front is an adjustable narrowed beam about 4.5". Oldspeed drop spindles with 944 rotors and Wilwood calipers. 215/40 17 Nankangs on empi Fuchs. Chase (Cage66) made the tubs for me.
In the rear I've got Nates (Wagonswest) 4.5" drop plates and adjusted the spring plates some to dial it in. The rear also has 944 rotors with Wilwood ebrake calipers and associated brackets made by Oldspeed. 235/45 17s in the rear.
With my 210 pound ass sitting up front it drops the nose almost an inch. The bus levels out nicely. The roads around NYC are a complete joke so yes the tubs are needed.
The rear has been notched and the shock towers trimmed for shock clearance. Also the dust shields on the front and rear shocks have been removed for clearance issues as well. _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
J K Samba Member
Posted: Wed Aug 20, 2014 6:21 pm Post subject: |
Thank you Glenn A for the additional info. The tubs look a little more complicated than my skill set allows. Was really hoping to get that look without the tubs and without having rubbing issues. How much do the tubs give you? 2 inches? |
Posted: Wed Aug 20, 2014 7:18 pm Post subject: |
Yes tubs are 2" _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Posted: Wed Aug 20, 2014 7:26 pm Post subject: |
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Dogo Samba Member
Posted: Thu Aug 21, 2014 7:16 am Post subject: |
J K wrote: |
If you are just getting acquainted with a bus or lowering a bus, and like the look of Fuchs, you might want to consider sticking with 15" Fuchs. Can get away without tubs and will probably save you some headaches with clearances, rubbing issues, etc. Could likely go lower if you chose to, and still looks pretty damn good. My 2 cents
Dogo Samba Member
Posted: Thu Aug 21, 2014 7:19 am Post subject: |
Probably a stupid question, but.... does everyone flip the tie rod ends?
What the process? same as bug? ream it? bushing kit?
Thx |
J K Samba Member
Posted: Thu Aug 21, 2014 8:08 am Post subject: |
Dogo wrote: |
Thank you. I am new to lowering AND buses. Changing direction from lifting jeeps I spent 3 hours last night reading through this thread and am still only on page 173. Im looking for a moderate stance. I/m not overly concerned with ride quality/comfort, but really want to avoid the rubbing if possible. I've found several buses in this thread, just trying to understand their specs. Thanks for the tips. |
J K Samba Member
Posted: Thu Aug 21, 2014 8:12 am Post subject: |
Dogo - I wasn't able to view the pictures on my desktop, but just looked on my phone. I think I've seen some of those buses in this thread. Are they all on 15's and no tubs. I certainly don't need lower than that. Again, appreciate the help. |
Dogo Samba Member
Posted: Thu Aug 21, 2014 9:54 am Post subject: |
J K wrote: |
All are on 15s.
I know the green one isn't tubbed, the others I don't know for sure, but I don't see why they would.
Below are two examples (including the green one). Pretty low, no tubs. The white one I also know has no tubs (at the time of this pic. He's tubbing it now, because going lower).
They do however all have rear frame notches, and the green one also has the frame notched in the front, but not sure it really would need it (maybe someone more knowledgeable can chime in on that). But obviously notches are far less involved than tubs. And of course, you're still going to have to take it easy over humps and bumps.
Green build: http://forum.earlybay.com/viewtopic.php?f=2&t=28327&hilit=fuch
White build: http://forum.earlybay.com/viewtopic.php?f=2&t=21827
^ these are both early bays, but you'll get the gist of it. A plus for you is that you don't need to change bolt patterns. 15 fuchs are readily available for your bolt pattern (except for deep6s. I don't THINK there are deep 6s for your pattern. Could be wrong) |
J K Samba Member
Posted: Thu Aug 21, 2014 10:57 am Post subject: |
dogo - thanks again... so helpful. actually didn't know there was another forum dedicated to the early bays. will have to read up on those build threads as well. this gives me hope... love the look of these and wouldn't even need to be lowered this much so i'm hoping i can get a little of both worlds, more aggressive stance without constant rubbing. |
Dogo Samba Member
Posted: Thu Aug 21, 2014 1:16 pm Post subject: |
J K wrote: |
There's also a late bay forum (yours is a late bay, right? 77?), but I don't think it is nearly as busy as earlybay.com or this site, but might be worth taking a peek at it.
www.thelatebay.com |
J K Samba Member
Posted: Thu Aug 21, 2014 2:00 pm Post subject: |
Dogo wrote: |
somewhat up in the air right now... i have committed with a guy that restores buses and his next build was a 77. he has a 1970 bus that is in better condition and honestly, i like the styling of the early bays a little better, so i've been talking to him about going with the '70 bus. i'm still trying to learn all of the differences - i understand the 70 doesn't have disc breaks, etc. don't want to get this thread off topic, so i'll just say that i'm still trying to decide which route to go - so as of today, i'm still open and very much appreciative of your info. |
Dogo Samba Member
Posted: Thu Aug 21, 2014 3:38 pm Post subject: |
J K wrote: |
Dogo wrote: |
I like small tail light bays way better as well. One of the most obvious issues in your situation (as far as wheels go) is the wheel bolt pattern.
'70: last year of the wide 5 bolt pattern.
'71 and up: small 5 bolt pattern.
Wheel choices for either pattern is quite different.
If you still want to run the 15 fuchs on the '70, I suppose you could always run adapters (probably not the first choice, and assuming you stick to no more than 5.5" wide rims), but you must account for the thickness of the adapter when measuring for fitment and clearance. Wide-5 to narrow-5, or Porsche pattern, adapters are about 1" thick.
The ideal, but more complicated and pricey, way would to convert hubs/brakes to porsche pattern, or to late brakes.
There are wide5 bolt pattern Fuchs, but IMO, don't look nearly as nice as the small5 bolt pattern. It's an option though. http://www.cip1.ca/SearchResults.asp?search=fuch+5+x+205&Submit=
decision, decisions |
J K Samba Member
Posted: Thu Aug 21, 2014 4:10 pm Post subject: |
i especially like the nose better... i like the turn signals down below.
the restorer has talked me through the axle issues and has a surplus of axles from parts vehicles and would be able to swap later bays for mine. while a little more expensive, it gives me the look of the early bays with some of the advantages of the later models. again, i haven't completely decided, but depending on what he comes back with from a cost perspective, i might opt for the early bay as the donor vehicle. |
