greanie2011 Samba Member
Joined: October 24, 2014 Posts: 27 Location: Round Rock, Tx
Posted: Sat Nov 08, 2014 1:53 pm Post subject: |
I am looking for feedback on the "Dump My Bay" package from Vintage V-Dubs? http://vintagev-dubs.com/
I am new to the VW and Bus scene. Not sure what im looking at or looking for. Only thing i know is i want to lower my bus as far as possible without tubbing or modding the frame.
Is this kit what im looking for? (From the research i have done this kit does contain all the components im looking for.)
More importantly ! Is this a quality kit as far as Quality, Longevity, and Fitment??
Any feedback in either a post or a PM would be much appreciated. I was looking at a wagenswest kit but their turnaround time is outrageous (Something like 9 weeks is the latest i have seen).
I posted this in another forum but im sure this was more likely the correct location for this post. |
busboy25 Samba Member
Joined: July 27, 2007 Posts: 97 Location: Rochester Hills, MI
Posted: Fri Nov 14, 2014 9:11 pm Post subject: |
So I started trying searching an answer for this but its a lot.
I have had a complete wagenwest system for years but even when it was new I had ball joint problems. They started making noise a few weeks in and the boot broke just as quick. So my questions are:
1) Does wagenwest replace the ball joints in the control arms before they ship the systems?
2) Do they make a lowered ball joint for bays? _________________ 76 Bay - 2056 Type four |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Fri Nov 14, 2014 9:18 pm Post subject: |
1) You would have to ask Nate, but I would assume everything is fresh.
2) No. _________________ nothing |
ballbag Samba Member
Joined: January 01, 2006 Posts: 204 Location: Cheshire, UK
Posted: Wed Dec 03, 2014 3:49 pm Post subject: |
I've just built my self a new 100mm beam and notched the rear. I'm yet to start tubbing, but I will be very shortly
I need to get it down at the front before it will fit in my garage though _________________ I never learned that much at school, but i've taught ladies plenty!! |
67sash Samba Member
Joined: December 14, 2012 Posts: 176 Location: Minnesota
Posted: Thu Dec 04, 2014 9:43 pm Post subject: |
greanie2011 wrote: |
I have purchased and awaiting mine, although I have heard great things about Wagenswest and my conversations with Nate were very informative at the end of the day I chose Vintage's Dump my Bay for two reasons.
1) lead time
2) Bruce was awesome in answering all my questions and making sure that I had everything. he ultimately gave me confidence and I chose him.
I will keep you updated and let you know about it more as it should arrive any day now. I am very interested to receive this as my mechanical design background my curiosity running ramped. I will take pictures of the product and show weld quality, machining methods and so forth but am expecting a high level of quality. |
Posted: Mon Dec 08, 2014 7:45 am Post subject: |
Well it fits
I'm hoping it should look like this pretty soon
odecom5 Samba Member
Posted: Wed Jan 21, 2015 5:56 pm Post subject: |
Hey, not sure if this thread is so active anymore, but I need help with the actual adjustment of my beam.
I have a 4" narrowed beam from Franklin's VW Werks with adjusters. I also have dropped spindles and was planning to leave it at the stock beam height (minus spindle difference) for the time being. The way I adjusted them:
1. Jack up front of bus, loosen both adjuster bolts.
2. Pull front wheels down towards ground, then tighten adjusters down on the lowest setting that they were at.
I read on WagensWest or some other tutorial that that would put the beam to the HIGHEST setting. This was my result after doing that:
This seems to me to be about 6-8" drop instead of 2.5". There is about 2 finger widths gap between the (underrated/undersized) tire and the wheel well... I like the look, but the ride is bouncy and awful (aren't shortened torsion leaves supposed to stiffen the ride?), and with my fat ass in it I rub all the time. I will be using this for a nearly daily driver, so this needs to improve.
My question: Did I do this right? Is there something else wrong? Should one beam be adjusted up and one down? Is it counter-intuitive and you have to jack up the wheels to raise the car? This doesn't make sense to me. The shocks are some silver KYBs and I think that is the only thing holding the ride up.
Any help anyone can provide would be great. Thank you!
Edit: I also feel like I had them both adjusted all the way up, and when you lower the jack the same thing happens, the bus just sinks. |
Posted: Wed Jan 21, 2015 6:54 pm Post subject: |
That beam was probably built with its "starting point" already lower than stock. Call Franklin and ask him. Sounds to me like you did the adjustment properly.
Smaller diameter tires will help with the rubbing, but will drop the front even lower overall. Not sure if there is any more room to go "up" with the beam without seeing where the adjusters are set.
Shocks do no hold the suspension up or down. They simply dampen the ride. (unless they have coil-overs) _________________ nothing |
gregoryrknox Samba Member
Posted: Sat Jan 24, 2015 2:28 pm Post subject: |
67sash wrote: |
1) lead time
I'm also in the market for a lowering kit for my 72 and was wondering how things were coming with yours. What were you initial thoughts on build quality? One of my concerns was the need to notch the rear frame; did you / will you need to do this?
Thanks! |
Posted: Sun Jan 25, 2015 9:34 am Post subject: |
cdennisg wrote: |
Shocks do no hold the suspension up or down. They simply dampen the ride. (unless they have coil-overs) |
Thank you for the info. I think I will just try to put stock spindles back on and gain a couple of inches back that way. That should hopefully be enough to keep things in order for DD. |
fogoo Samba Member
Joined: November 29, 2009 Posts: 100 Location: Toronto
Posted: Sat Jan 31, 2015 5:07 am Post subject: |
Hey All,
I've read through most of the forum, but couldn't find a direct answer. I'm sure it's in there somewhere, so forgive me for asking again......
I'm going to add adjusters to my stock 75 beam. If I wanted to do a 'mild' narrow as well, is it possible to shave off the ends of the beam without cutting/replacing the end plates and push the end bearings in an inch or so, or is there something stopping this from happening. Thanks _________________ 64 Single Cab
71 Bug.....sold
73 Bus......sold
75 Panel Bus - converting to Subi power http://www.thesamba.com/vw/forum/viewtopic.php?t=651073&highlight=
78 Kombi Camper |
67sash Samba Member
Posted: Sun Feb 01, 2015 1:16 pm Post subject: |
As it sits right now I will not be notching the rear frame, in my purchase I got drop plates (4") and will utilize those. I do believe the bumper will have to be removed but notching no.
The build quality is to my satisfaction however the powder although fine is marred/scratched on all most every piece do the method in which the product was shipped. I have discussed this with them, but overall I am very pleased by the product in hand and look forward to posting how well it installs in my build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=616613
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sun Feb 01, 2015 2:50 pm Post subject: |
that center pin looks way, and I mean way shady. I can't imagine it will live a long life out in the open like that _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
drakonis Samba Member
Joined: June 15, 2012 Posts: 251 Location: Granite Falls, WA
Posted: Sun Feb 01, 2015 8:58 pm Post subject: |
skills@eurocarsplus wrote: |
that center pin looks way, and I mean way shady. I can't imagine it will live a long life out in the open like that |
Why not? Keep plenty of grease in it and it should be fine. I dont see the problem. _________________ 71 Bay. "ketchikan" |
69Bugz Samba Member
Joined: September 29, 2011 Posts: 44 Location: Spartanburg SC
Posted: Mon Feb 02, 2015 8:01 pm Post subject: |
I have one question. And don't beat me up to bad. I did use the search function (alot). My questions is will 17" x 7" fit in the rear wheel wells of my 71 ' westy without any fabrication. I am going 4" narrowed beam, drop spindles, and 3.25' notch plates in the rear. I want to run 17" x 7' with 215-55-17 in the rear and 215-40-17 in the front. Any help will be appreciated. |
Tcash Samba Member
Posted: Mon Feb 02, 2015 9:28 pm Post subject: |
69Bugz wrote: |
I have one question. 3.25' notch plates in the rear. I want to run 17" x 7' with 215-55-17 in the rear and 215-40-17 in the front. |
Top of the page. Next to (post reply) type 17x7 in the search box.
Good Luck
Tcash |
67sash Samba Member
Posted: Mon Feb 02, 2015 9:38 pm Post subject: |
yes, please explain. Functionally it seems sound and if its kept greased it seems like it should be sound for a good duration of time. |
69Bugz Samba Member
Posted: Tue Feb 03, 2015 3:58 am Post subject: |
Tcash wrote: |
69Bugz wrote: |
Good Luck
Tcash |
Thanks for all your help Tcash.... (Not)..... I have already done that several times. I can't find anywhere with the same question that i am asking. I just want to know if 17" fuchs will fit in the fender well with no fab. Just bolt on? Thanks |
Posted: Tue Feb 03, 2015 10:28 am Post subject: |
69Bugz wrote: |
Tcash wrote: |
69Bugz wrote: |
Good Luck
Tcash |
My guess is you will have to break new ground and figure it out on your own. It may have been done before, but it may not have been posted anywhere to share. IF you can find a photo of the setup you want, you may be able to contact the person who posted the photo for more info.
My prediction is that it will not be possible without fabrication, and will most likely require that you narrow your torsion housing. It all depends on actual tire dimensions and wheel offset. There isn't much room for that stuff in the rear wheel well of a 71 bus. _________________ nothing |
Dogo Samba Member
Posted: Sun Feb 15, 2015 6:13 pm Post subject: |
I just wanted to share mine.
First try at it. Other than the bitter Canadian cold in the garage, I think I'm managing ok.
I'm not "mechanically inclined" but I like to think I'm handy, and have spent the last year and a half reading everything I could on lowering a bay, then made up my mind on which way to go about it and went ahead and bought everything I needed. I think i still might have made some not so great choices, but we'll see once she's rolling.
The original plan was to get someone to do the work, but things changed and I had to make the call to tackle it myself. Steep learning curve, but I'm enjoying it.
So far I have done the rear. I hit a couple of minor snags, but it's pretty much done. Getting started on the front soon.
My setup:
'70 Westy
17x7 fuchs
Rear:
205-40s
3.5" WW drop plates.
Late bay (shorter) stub axles, further narrowed about 10mm to clear wheel center cap (if/when swithching to 15" wheels)
Franklins' adjustable spring plate.
Old Speed's Porsche brake bracket/kit.
Gabriel Air shocks (still working on fitting those)
Front:
185-35s
2" WW beam
2.5" WW dropped spindles
Flipped tie rod bushing kit (just in case)
VDub Engineering Porsche brake kit
Gabriel air shocks
