brianscurious Samba Member
Posted: Mon Feb 13, 2006 7:26 pm Post subject: Custom fiberglass Speaker Box? |
| I want to have a custom fiberglass speaker box built for my '71 bug, but I haven't had any luck finding anyone in Southern California that builds custom fiberglass boxes for vw bugs. I have the rear seat out so I have more to work with, does anyone have pictures of boxes that they had made? If so, please post them. And if anyone knows of anyone that can build my custom box? Thanks, Brian |
JonF Samba Member
Joined: December 16, 2005 Posts: 2070 Location: Oklahoma
candyflame73 Samba Member
Joined: September 03, 2005 Posts: 301 Location: Texas
Posted: Tue Feb 14, 2006 5:11 pm Post subject: |
Nothing fancy, but this is what I did. The top is fiberglassed to blend the box up to the speaker, and the front is glassed between the amps just for something different. Pretty simple process using fleece to stretch and get the shape, then resin, then add fiberglass and resin it on for strength. I also did my own kick panels with 8", 5 1/4", and 1" tweeters. On the kick panels I just used speaker grill cloth to stretch for the shape, its a little harder to work with but it doesnt soak as much resin.
This box is very basic, but the process is the same if you want to all out.
Maybe it will give you some ideas.  |
OVERHAULIN67 Samba Member
Joined: December 12, 2004 Posts: 288 Location: Fort Polk, Louisiana
Posted: Tue Feb 14, 2006 8:17 pm Post subject: Custom speaker box |
Here is what I'm doing so far with mine.
Above is where we taped the area we want to fiberglass.
We taped the fibglass in place to make it easier for us.
This is of course after we finished the first layer. This was all done on Monday . We will add the the next few coats thursday..Saturday we will remove it from the car and prep it for the over coat. |
JonF Samba Member
Posted: Tue Feb 14, 2006 11:05 pm Post subject: |
whats the sound stage like with those kick panels? _________________ 68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix
when wishing for a type 2 make sure to include vw in the wish so its not diabetes you end up with! |
renderit Samba Member
Joined: October 09, 2005 Posts: 1155 Location: Austin, TX
Posted: Wed Feb 15, 2006 4:52 am Post subject: |
| I'll bet you were high for a week after the last coat! Fans, mask I hope? |
Posted: Wed Feb 15, 2006 4:28 pm Post subject: |
| The kick panels really pulls everything up front, as if the music is in front of you. Even the bass sounds like it is coming from up front, maybe the 8" mid-bass are helping with that some. Then again, the only speaker in the back is the sub. I mostly did this to simplify things. |
Fibersport Samba Member
Joined: September 23, 2005 Posts: 1157 Location: Lansing, IL
Posted: Wed Feb 15, 2006 6:47 pm Post subject: |
Candyflame - Very nice, the carpeting looks so plush, what kind is it and how hard was it to form? For the kick panels, you said you stretched speaker cloth to get the shape but did you form it over something first? I like the VW logo in back as well, blown out any windows yet????
Hope the little guy in the background keeps his fingers out of the speakers!
Greg _________________ 1973 Standard Beetle |
thehecticskeptic Samba Member
Joined: December 08, 2005 Posts: 249 Location: philly, pa
Posted: Wed Feb 15, 2006 7:41 pm Post subject: |
| nice work, like the rear hatch setup! Not to thread jack, but where can I get the good front kick panels for speakers, read a lot about plastic one's (prolly empi) |
bug_me Samba Member
Joined: December 20, 2005 Posts: 216 Location: Washington MO
Posted: Wed Feb 15, 2006 7:44 pm Post subject: |
| candyflame73 wrote: | Nothing fancy, but this is what I did. The top is fiberglassed to blend the box up to the speaker, and the front is glassed between the amps just for something different. Pretty simple process using fleece to stretch and get the shape, then resin, then add fiberglass and resin it on for strength. I also did my own kick panels with 8", 5 1/4", and 1" tweeters. On the kick panels I just used speaker grill cloth to stretch for the shape, its a little harder to work with but it doesnt soak as much resin.
Damn! how many watts is that one sub pulling with that amp setup? |
Posted: Wed Feb 15, 2006 8:59 pm Post subject: |
Thanks guys! Fibersport, the box, along with the flooring, headliner, and seats are covered in tweed. The color is called Bone. It is extremely easy to work with, and stretches very well. The box in the back is covered using just one piece that is stretched and glued. I ordered it from www.autoheadliner.com they have great color samples on there site. on the kick panels, basiclly I cut the large piece that makes the back, then cut a ring (or panel) that the speaker sits on and used some small strips of wood to prop it above the back panel. Then I simply stapled the grill cloth on top of the speaker panel and stretched it down to the back plate and stapled it to the back and covered it with resin. Once it hardened I layered the fiberglass on top and more resin for strength. Now that I read this its clear as mud. I wish I had taken some pictures during the process.
bug_me, the 12" in the back is running off of the silver Lanzar Opti500.2 on the pass. side of the car. Its rated at 250 x2 RMS @ 4ohms and 500 x2 RMS @ 2ohms. The other two amps are running the three way set up in the kick panels. |
Posted: Wed Feb 15, 2006 10:43 pm Post subject: |
| candyflame73, that is a nice setup and it has given me some ideas. Thanks! |
Posted: Wed Feb 15, 2006 10:49 pm Post subject: |
| thehecticskeptic, don't get plastic speaker panels. They crack easier. I got my fiberglass kick panels from http://www.glass-action.com/ and they work great. They were easy to install and look geat. I put 6 1/2" speakers in them. |
Quik Samba Member
Joined: February 07, 2006 Posts: 48 Location: Grapevine, TX
Posted: Thu Feb 16, 2006 10:58 pm Post subject: |
you can also get great fiberglass kickpanels from Ralph at
www.vwinnovations.com
I have also bought fenders and a dash from him, fantastic fiberglass work _________________ Out of all the voices calling out to me
I will choose to listen and believe the Voice of Truth
WTB: Cal-look popouts |
Hortin Samba Member
Joined: January 21, 2006 Posts: 55 Location: Fort Smith, Arkansas
Posted: Sat Feb 18, 2006 6:25 pm Post subject: |
candyflame, your car looks great. I see that you have relocated the fuse block inside. Why didn't you upgrade to a better style of fuse? Just curious.
edit: never worked on a super
Posted: Sat Feb 18, 2006 7:09 pm Post subject: |
| Thanks, but that is the factory location for the fuse box on a 73 super. |
Posted: Sat Feb 18, 2006 7:22 pm Post subject: |
Today the speaker box mold came out pretty nice. I cleaned them up put them back in and started fiberglassing in the braces to hold the shape. I would have pics but I forgot my disk at home.....tommorow there will be pics.
Tommorow I will be building the speaker rings and putting them in the box to make sure of the position of the speakers. Now to figure out where to put the Amp's. More to come.... |
Posted: Sat Feb 18, 2006 11:14 pm Post subject: |
OVERHAULIN67, Can't wait. Keep us posted and show us as much pics as you can.
Thanks! |
Posted: Sun Feb 19, 2006 5:18 pm Post subject: |
I got a few pic before my camera decided to just quit on me....anyway......the pics I do have show where I have cleaned up th edges and fiberglassed in some braces/dividers. The other pick is the speaker rings I made today and placed where I would like for the speaker to be positioned in the box. I had taken more but the camera didn't record them...POS!!
Posted: Sun Feb 19, 2006 11:00 pm Post subject: |
| It's coming along let me know when you get a new camera and some more pics. Can't wait to see the finish product. Later! |
