gadget58 Samba Member
Posted: Tue Feb 14, 2006 1:08 pm Post subject: what is this on my 66 square |
well I sold my 69 and have moved the 66 in to the garage from the back yard, I am trying to get it road worthy to go to the show this weekend.
ok to the questions
what is this
is this a drain or a vent or what? it is on both sides of the rear of the car
is this the proper place for the shift pattern sticker
thanks for the help and I am back to work |
Zarana-X Samba Dreadnok
Joined: September 03, 2004 Posts: 372 Location: How could hell be any worse?
Posted: Tue Feb 14, 2006 1:12 pm Post subject: |
No 1 looks lik an aftermarket horn, or at least sounds like it from "tu tone chimes"
No 2 is a drain for all the crap that goes in through the vents.
No 3, I don't know if that's correct. Nice shifter, though. _________________ "In order to create, you have to destroy." |
Posted: Tue Feb 14, 2006 1:40 pm Post subject: |
thanks for the info
how about this
where does the hitch mount to
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Tue Feb 14, 2006 1:46 pm Post subject: |
gadget58 wrote: |
thanks for the info
how about this
where does thr towbar mount to
trailer hitches normally mount to the bumper brackets _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Feb 14, 2006 5:59 pm Post subject: |
That trailer hitch was mounted to the cross member under the bell housing. But you are missing part of it. There was also a piece that went across between the bumper braces to support the load at the rear. The cross member pulled the load, and the bumper braces carried the tongue weight. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
buzzbox Samba Member
Joined: September 16, 2005 Posts: 44 Location: sydney australia
Dr. Jeckill Samba Member
Joined: August 25, 2005 Posts: 43 Location: Ghent, Belgium
Posted: Wed Feb 15, 2006 1:54 am Post subject: |
well looks like some of the tu-tone went awol.Doesn't surprise me considering the location _________________ Svenska Bubbla |
Posted: Wed Feb 15, 2006 3:48 am Post subject: |
Ole' tu-tone comes away second best in grudge-match with newfangled speed hump...
Some kid kicks lump of metal down the street, on the way home from school.
a-HOO-ga! |
Posted: Wed Feb 15, 2006 11:20 am Post subject: |
Wow it’s amazing that someone would put a horn there
Thanks for the help
I drove it 30 miles last night with no problems
Then this morning drove it to the doctor and went to leave and it would not start. I was in a parking garage so I just pushed it out of the parking spot and down the ramp I went and started right up (push start). Got home and went to give my roommate a ride so we jumped in the square same thing cranked to there was no more power. Jumped in my other car and went to school. Was back to the house in 15 minutes and was going to push the square into the garage but gave it one last try and BAM started right up
Ah good old vw |
Posted: Wed Feb 15, 2006 11:42 am Post subject: |
gadget58 wrote: |
Thanks for the help
Ah good old vw |
bad ground strap? bad starter cable? got a spotty connection somewhere... _________________ póg mo thóin
Posted: Wed Feb 15, 2006 12:30 pm Post subject: |
cool, will look into that tonight
I bet it is the ground stap |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Feb 15, 2006 2:45 pm Post subject: |
gadget58 wrote: |
Don't forget the tranny/ground strap also. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
urchin Samba Member
Posted: Wed Feb 15, 2006 7:07 pm Post subject: |
Could also be the starter bushing. My 66 was doing the same thing. Real sporadic then quit altogether. I finally bought a new starter and it did the same thing so changed the bushing and its been fine ever since. |
Posted: Thu Feb 16, 2006 1:14 pm Post subject: |
well went and adjusted clutch, fixed a big old exhaust leak ,cleaned up the grounds witch seemed to fix the starting problem (we will see)but still have a lot to do
Need new shocks, rear break cylinders, rebuild on front end, and sand and primer the car.
Thanks again for the help
my work in progress
brent67 Samba Member
Joined: December 31, 2003 Posts: 515 Location: Port Townsend,WA
Posted: Thu Feb 16, 2006 2:14 pm Post subject: |
In my '67 Square the shift pattern is on the ashtray, but it pulls from underneath, so no knob. My '66 Fasty has the same ashtray as you but there is no visible shift pattern sticker. So I'm thinking that it was possibly dealer installed? Would account for varying locations or absence of it.
What color blue is that Square? _________________ DSD
Dark Side Disciples
(Inner Circle/4th degree) |
Posted: Thu Feb 16, 2006 2:35 pm Post subject: |
I would say ( vw blue ) |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Thu Feb 16, 2006 2:38 pm Post subject: |
gadget58 wrote: |
Thanks again for the help |
are you primering it to prepare for a paint job soon or are you primering it just to primer it?
if you aren't going to be painting it anytime soon why wouldn't you just rock that nice OG patina? _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Thu Feb 16, 2006 2:57 pm Post subject: |
gadget58 wrote: |
i'm guessing sea blue, by the dash. not sure if that was a 66 color.
definitely should roll with the paint as is. |
hoss Samba Member
Posted: Thu Feb 16, 2006 3:01 pm Post subject: |
Looks like L633 VW Blue for '66. _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
Posted: Thu Feb 16, 2006 3:08 pm Post subject: |
It looks like an American flag, but the primer is last on the list
Well after cleaning the grounds it is still having problems starting
It is very sporadic, could it be the battery or charging system?
pulled the battery, it was low on water and almost dead. so we will see tomorrow if a freshly charged battery helps. |
