BenPbuggy Samba Member
Joined: November 30, 2013 Posts: 4 Location: Montreal Canada
Posted: Sun Dec 01, 2013 11:54 am Post subject: NEW SYSTEM |
[img][/img]
It sounds good too. |
RedBaronofRedBud Samba Member
Joined: July 05, 2013 Posts: 505 Location: Southeast Missouri
Posted: Sun Dec 01, 2013 5:12 pm Post subject: |
Looks great! How about a few more pics a little further back of the rear and sides? OH yea...and video is always appreciated! _________________ Or you can call me………Tim
My two pennies…your mileage may vary
I’m not a complete idiot, there are parts missing |
joescoolcustoms Samba Member
Posted: Sun Dec 01, 2013 5:15 pm Post subject: |
RedBaronofRedBud wrote: |
Looks great! How about a few more pics a little further back of the rear and sides? OH yea...and video is always appreciated! |
Agreed!
I am in a bad need to see the rest of that buggy! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
motoRAT Samba Member
Posted: Sat Dec 07, 2013 12:35 pm Post subject: |
fited the rear bumper
_________________ Be curious, dismantle it all, reassemble it, go for a ride! |
Posted: Wed Dec 11, 2013 7:17 am Post subject: |
removed the rearlights, nasty butchering
going to quick fix that and try to fit a 60 lights
Posted: Sat Dec 14, 2013 9:21 am Post subject: |
I'll not blame anyone that starts to call my buggy the cyborggy from buggy hell
it was a very "not so" quick fix to fit this lights, I really hate the big ones, and I needed to cover those meteorite impact holes on the fiber _________________ Be curious, dismantle it all, reassemble it, go for a ride! |
Posted: Sat Dec 14, 2013 12:52 pm Post subject: |
You could paint the metal to match or contrast for the time being until you can fill the holes and do the repair correctly.
As long as its street legal, Cyborggy looks good! (C; _________________ Or you can call me………Tim
54Baja@14 Samba Member
Posted: Tue Dec 24, 2013 7:57 pm Post subject: |
Went from rear torsion to coilover. I'm stealing my son's old baja account.
[/img] _________________ Sponsors: Relevant Lighting
PlayTech Racing, Moore Parts, Printers Litho, Eimer Engineering & Buddies Garage |
Posted: Wed Dec 25, 2013 9:29 am Post subject: |
This was my christmas present to the buggy, replacing the outer right front wheel bearing. I believe the old one had some cavity problems
in replying in to RedBaronofRedBud, I'll live it as is, just hope the inspectors on the mandatory annual inspection don't give me any problems _________________ Be curious, dismantle it all, reassemble it, go for a ride! |
monomanx Samba Member
Joined: September 25, 2004 Posts: 715 Location: Southeast
Posted: Sat Jan 11, 2014 5:57 pm Post subject: |
I have been working on a simple 1600 Single Port for the monocoque for driving across the US in July. Today while putting the long block together I broke a piston ring. In all the years of building engines, that is a first..YEH...now I have to buy new rings.
I guess some days you get the bear...and other days, the bear gets you |
167luckycharm Samba Member
Joined: January 17, 2007 Posts: 328 Location: Kauai Hawaii
Posted: Thu Jan 16, 2014 9:20 pm Post subject: |
Finally took some time to work on my own buggy for a change. Getting ready for the annual safety check inspection before the end of this month and had to address the new & stricter requirements. First off, installed a reverse light. I'm glad I added an extra wire inside the harness when I built the electrical system. Instead of the coil's terminal 15, I ran it from the dash fuse box to the nosecone switch. Next was a pair of hand-operated windshield wipers. Fabricated a pair of brackets to attach to the knock-off B&K frame mounts, found a pair of stainless steel windshield wiper arms at the local wrecking yard, and bolted them up. I hope these will pass the inspection. One last item that took a bit of creativity was the fan belt guard. All stainless steel; mounting plate and perforated sheet to keep fingers out of harms way. I'm headed out to have the inspection done tomorrow after work, hoping the rear tires that stick past the fenders will not prevent the car from passing the certification... _________________ Humble Pie, it might be good for you, but it always tastes like sh!t
See my 009 Distributor page on Facebook, search for VW 009 Distributor Discussion
http://www.facebook.com/pages/VW-009-Distributor-Discussion/499742640126712 |
vponder Samba Member
Posted: Mon Jan 20, 2014 4:48 pm Post subject: |
Made the most of the holiday, drove about 50 miles and got some parts from a vw mechanic that stocks parts. Then went to a friends auto shop and put the buggy up on the rack and changed the steering damper and it needed changing the old one was leaking at the seam. Then put a new belt on it the old had probably been on there since 09 when the engine was put in. Bought new rubber pads for the brake and clutch but dang those are hard to get on may have to wait till warmer weather so they'll flex more. I also found a wire loose on the pos battery terminal that went to the volt reg, it was causing radio noise. Love listening to the tunes cruising. |
StevieC Samba Member
Joined: January 01, 2014 Posts: 412 Location: Anza Borrego
Posted: Sat Feb 01, 2014 4:41 pm Post subject: |
Didn't do nothin yesterday
But today I put in an Empi trigger shifter and put a 12V accessory outlet in the dash
I also tried again to remove the transaxle drain plug and failed... again. So I just topped it off
There's a tranny support bracket mounted directly in front of the drain plug and I can't get a good shot at it. I've tried every tool and even made some of my own
I'm gonna have to take that bracket off to do it or just take the thing to a shop and tell em to change the fluid |
SoCal67Volks Samba Member
Joined: April 07, 2008 Posts: 158 Location: San Pedro California
Posted: Sat Feb 01, 2014 6:40 pm Post subject: |
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1166707
I must have measured my pan getting ready for the first cut a dozen times now. Each time I get ready to cut, my OCD kicks in (being an engineer sucks sometimes).
Today I measured (again) but this time I hung a laser.
I was surprised (not really) at the difference between my original measured lines and the laser lines. The lines at the bottom of the tunnel match but was off 7/16" at the top.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1166708[/img]
First Cuts Tomorrow! _________________ 1967 Type 1 Sunroof
Meyers Manx Kickout
Meyers Manx SR2
"Making a car look complicated is easy, making it look simple is hard." John Buttera |
Posted: Sat Feb 01, 2014 7:13 pm Post subject: |
Quote: |
First Cuts Tomorrow! |
May the SawZall be with you! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sat Feb 01, 2014 9:38 pm Post subject: |
Spent most of the day removing the sound deadening material from the floor pan before measuring.
This lead to a new addition to my "Bucket List": Travel to Germany to meet the vw employee that installed the sound deadening material, shake his hand and tell him; "Job well done!"
Thought I'd never get that stuff off! _________________ 1967 Type 1 Sunroof
Meyers Manx Kickout
Meyers Manx SR2
Posted: Sat Feb 01, 2014 11:10 pm Post subject: |
That sound deadening material comes off pretty easy in close to zero degree weather. Once you get it started, a wood chisel and a hammer will chip that stuff off. It becomes quite brittle at those temperatures. |
Posted: Sun Feb 02, 2014 1:48 pm Post subject: |
monomanx wrote: |
That sound deadening material comes off pretty easy in close to zero degree weather. |
Agreed......... I did the passenger side a while back when it was still hot. Yesterday was the coldest weather we've had in southern Cal but it was a far cry from "close to zero" _________________ 1967 Type 1 Sunroof
Meyers Manx Kickout
Meyers Manx SR2
Posted: Sun Feb 02, 2014 1:52 pm Post subject: |
First cuts to the pan today. The one task I've agonized over the most.
No turning back now...
Meyers Manx Kickout
Meyers Manx SR2
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Tue Feb 04, 2014 9:46 am Post subject: |
Sold the buggy, kept the engine.
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
