RedBaronofRedBud Samba Member
Joined: July 05, 2013 Posts: 505 Location: Southeast Missouri
Posted: Tue Mar 18, 2014 10:52 am Post subject: |
Jim,
Thats a "hella" good upgrade! (c; _________________ Or you can call me………Tim
My two pennies…your mileage may vary
I’m not a complete idiot, there are parts missing |
EVfun Samba Member
Posted: Tue Mar 18, 2014 12:39 pm Post subject: Re: Running lights in 62' front signals |
jwanders32 wrote: |
A small task that has been on my list. I converted my small 1962 front turn signals to a double prong socket. This way I can use a double filament bulb and have both a running light and a brighter turn signal light. I used the 1967 socket base (plastic part with two prongs and two spade terminals) and inserted them in my smaller turnsignal base/bulb holder. I wanted to keep the period look as well as gain the running light. |
Did you check to see if the double base lamp will fit into the housing? The double base bulbs usually have the side nubs on the base at 2 different heights so the bulb only goes in one way. I think you will have to mod the base too. _________________
Wildthings wrote: |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Mar 23, 2014 8:07 am Post subject: |
Built a new intake to replace the German FI plenum.
IAT, Water injection, and vac/boost reference bungs installed with the original German Throttle body used and custom throttle return spring from a Pict34-3.
A good eye can see the linkage parts I scammed from a Pict34 to eliminate the secondary linkage of the stock German throttle linkage assembly.
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
lbass Samba Member
Joined: September 22, 2010 Posts: 134 Location: Bakersfield Ca
Posted: Wed Mar 26, 2014 10:49 pm Post subject: |
Tune up day! It's been running all along but has been cutting out and just worrying me a bit. Replaced pretty much everything from points to plugs. Runs great and now if I can find a couple tires for the back I'll be ready to take a little trip and see how it does. Maybe a run to Pismo or Morro Bay! |
motoRAT Samba Member
Posted: Wed Apr 16, 2014 3:31 am Post subject: |
what I've been trying to do for the past few days, is figuring a way to mount the damn fuel tank in order to work under the fiber like it should
I don't know how did they project the fiber to receive the fuel cell, but it was not with the normal tank, I cut it flip it weld it, seems this is the only way it fits under the fiber
new hole for the filler neck next to the old one
_________________ Be curious, dismantle it all, reassemble it, go for a ride! |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Mon Apr 28, 2014 11:39 am Post subject: |
This is more than a few "yesterdays", but we turned this -
[img][/img]
[img]
Into this -
[/img]
[img][/img]
[img]
Tom[/img] _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
herbsflat4 Samba Member
Joined: February 20, 2012 Posts: 159 Location: Greenville, SC
Posted: Mon Apr 28, 2014 12:58 pm Post subject: nice |
jaxjeeper wrote: |
Bought it!
Sweet ride! |
Bob Elgin Samba Member
Posted: Mon Apr 28, 2014 7:10 pm Post subject: |
Put gear oil for the 1st time in over 25 years(no Joke).1)spray penitrating oil and let it set overnite and. 2) made my own tool to take out the plug.(see pic) 3.) find a 17mm head of the bolt. 4.) find two 5/8 nuts. 5.)align the nuts and then JB Weld them to gether.
By doing this you wont have to spend the ridiculous amount of money for 17mm Tool.
_________________ OLD ENOUGH TO KNOW BETTER AND STILL TO YOUNG TO CARE!!!!!
My Build http://www.thesamba.com/vw/forum/viewtopic.php?p=5987690#5987690
My Youtube page
https://www.youtube.com/channel/UCqd2r1Af7uZgqlnxAtMap4A |
wythac Samba Member
Posted: Mon Apr 28, 2014 9:01 pm Post subject: |
Nice idea Bob!
I used to have one of the original engine oil and transmission plug tools with a dogleg in it for the trans axle plug but lost it. I just have the stupid single purpose hex socket now. I like your idea better. |
Wetstuff Samba Member
Joined: September 23, 2010 Posts: 700 Location: Maryland
Posted: Wed Apr 30, 2014 6:30 am Post subject: |
Tom, Nicely done. Paint is cool.. from the pics looks 'just blue' from a distance, but pretty of crystal up close.
The oil cooler is a little scary to my eye. (I tend to break things..)
Jim _________________ Manx #2614 |
Posted: Wed Apr 30, 2014 7:16 am Post subject: |
Thanks Jim! The oil filter will get moved when we make a rear bumper/skid plate setup for it after Big Bear. I hope I got the "old school" look correct. Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
FarmerJohn Samba Member
Joined: December 16, 2007 Posts: 417 Location: Long Island NY
Posted: Wed Apr 30, 2014 1:34 pm Post subject: |
Tom_Kathleen wrote: |
Thanks Jim! The oil filter will get moved when we make a rear bumper/skid plate setup for it after Big Bear. I hope I got the "old school" look correct. Tom |
Very Nice Tom , are you going to bring it to Carlisle ?? _________________ Now I Drive A Hard Top Buggy ! |
Posted: Wed Apr 30, 2014 3:12 pm Post subject: |
Farmer John - the plan is to do Carlisle & the East Coast Visits West Coast run with this car. I wanted to do the Sea 2 Sea run with it, but transaxle problems screwed that one up. Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
Posted: Sat May 03, 2014 4:52 am Post subject: |
finally finished the support for the fuel tank, and it turned out to be the brake oil reservoir support as well as the horn mounting place
it's summer time in Portugal and I'm far from going for a drive
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Mon May 05, 2014 9:34 pm Post subject: |
I installed a battery hold down. Incredibly, the PO had the battery just sitting in the well under the back seat, held in only by the cables and some carpeting. I installed a pair of stainless steel footman loops secured with bolts and fender washers, and strapped the battery down with a KevLok battery hold down strap that I replaced on my boat for cosmetic reasons. I also hard wired the quick connect pigtail for my trickle charger.
illinineverdie Samba Member
Joined: October 21, 2012 Posts: 57 Location: Illinois
Posted: Tue May 06, 2014 7:46 pm Post subject: |
Got a call from Sam that my new Rancho transmission is being shipped! |
SoCal67Volks Samba Member
Joined: April 07, 2008 Posts: 158 Location: San Pedro California
Posted: Sat May 10, 2014 9:54 pm Post subject: |
Got a pair of tires for a recent birthday gift from my wife and daughters.
Had a set of stock wheels widened to 10".
_________________ 1967 Type 1 Sunroof
Meyers Manx Kickout
Meyers Manx SR2
"Making a car look complicated is easy, making it look simple is hard." John Buttera |
Posted: Sat May 10, 2014 10:05 pm Post subject: |
A couple before and after shots.
BEFORE:
AFTER:
Meyers Manx Kickout
Meyers Manx SR2
