SiggyManx#33 Samba Member
Joined: June 13, 2005 Posts: 877 Location: Southeast PA
Posted: Fri Aug 01, 2014 6:25 am Post subject: |
Joe…I like it. |
Joe…I like it. |
jpfahrstar Samba Member
Joined: November 12, 2003 Posts: 43 Location: Columbia, MD
Posted: Fri Aug 01, 2014 2:59 pm Post subject: |
Nice hat, Joe! |
RedBaronofRedBud Samba Member
Joined: July 05, 2013 Posts: 505 Location: Southeast Missouri
Posted: Fri Aug 01, 2014 5:25 pm Post subject: |
Cool ride, Joe! I like finding places like that off the beaten trail too. Never know what you're gonna find!
The hat is cool, but it needs a spike in the top and needs to be chrome. _________________ Or you can call me………Tim
My two pennies…your mileage may vary
I’m not a complete idiot, there are parts missing |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11053 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Aug 10, 2014 12:46 pm Post subject: |
Swapped shifters in CopperTub...
From a Berg knock off to an Empi trigger shifter... Shhhhh...
I've actually always had good success with them.. plus Im removing stuff on my 67 Blue Bomber Beetle for an upcoming sale next year.... ...sooooo recycling..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Ratt Samba Member
Joined: April 15, 2003 Posts: 753 Location: Puyallup, Wa
Posted: Mon Aug 18, 2014 3:52 pm Post subject: |
Today I pulled the gear assembly from the transmission to flip it back to the right direction(used to be reversed for a corvair motor). Just have to wait on my list of parts from CIP1. Hopefully in 2 weeks my seats will be here and I can get them mounted and finish the pan! |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Thu Aug 21, 2014 1:55 pm Post subject: |
Replaced the carb and changed the oil,old carb had a open needle valve,full flow of gas into carb,Had a rebuilt from summit, german solex 34 pic3,put it on and it would not idle,vacume leak,base of carb had high spot at mounting stud ears,filed it down to get a good seal,also they did not replace the o ring at the bypass valve,there was no reistance when turning the screw,replaced o-ring and it ran well,after adjusting. |
BIG_IRON1911 Samba Member
Joined: May 30, 2014 Posts: 15 Location: Greeneville, TN
Posted: Fri Aug 22, 2014 4:37 am Post subject: |
Picked it up from the mechanic |
joehadams Samba Member
Joined: May 19, 2011 Posts: 242 Location: Connecticut
Posted: Mon Aug 25, 2014 7:47 am Post subject: |
replaced my bowden tube and clutch cable and realized that it isnt whats causing the chattering. I guess the engine is getting pulled out soon. |
joescoolcustoms Samba Member
Posted: Mon Aug 25, 2014 7:51 am Post subject: |
joehadams wrote: |
Look for a broken/loose clutch tube in the tunnel. Have someone work the clutch and you watch what is happening at the forward boden tube area for flex and make sure to have at least 1 inch sag in the boden tube. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
tgodber Samba Member
Joined: May 02, 2004 Posts: 410 Location: Okanagan Falls B.C. Canada
Posted: Mon Aug 25, 2014 9:36 am Post subject: |
Sunday drive. Went to the top of Gerry mountain. Was a forestry lookout. Has great views of the Okanagan valley. Had a bad shimmy in my front end at certain speeds. Found a bad tie-rod end so will have to replace.
_________________ My wife said I never listen to her.
Or something like that! |
doubravsky Samba Member
Joined: July 30, 2014 Posts: 133 Location: Riverside, CA
Posted: Mon Aug 25, 2014 2:47 pm Post subject: |
Bought it!
Posted: Tue Sep 02, 2014 9:03 pm Post subject: |
Added new steering wheel today.....
Here's the old one.....
And the new one....
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
Posted: Wed Sep 03, 2014 7:30 am Post subject: |
Started taking it apart for the build! Removed windshield and steering wheel/shaft, disconnected wires, and broke the hood free from the mulitple layers of silicone sealant used between the hood and body.
_________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-Original Home built buggy that started all. I learned to drive in it back in 1985.
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983 |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Wed Sep 03, 2014 8:49 pm Post subject: |
I put a few coats of high temp brake paint on my new custom drilled and studded rear drums. These have the Chevy 5 on 4-3/4" pattern and fit my '72 IRS pan. There just aren't very many 4-lug wheels that appeal to me, and I don't like the adapters that are currently on there.
I used the Harbor Freight Iron Armor brand paint, and it went on nicely. I masked off the braking surfaces and sprayed the inside as well. I hate rust, even if you can't see it! |
Ravinsomniac Samba Member
Joined: June 20, 2009 Posts: 300 Location: Palm Beach Gardens
Posted: Sun Sep 07, 2014 5:20 am Post subject: |
Nice WWII German helmet. You need to get a couple SS decals for the sides. Ferdinand Porsche, who first designed our cars for Adolf Hitler 'The Peoples Car' in 1935, was using Hitler's SS in 1942 to operate a special unit called, SS STURMWERK VOLKSWAGEN. Your gold helmet is a little flashy though, as the originals were a dull, light brown in color. You look right at home in your German Volkswagen ! |
Posted: Sun Sep 07, 2014 5:57 am Post subject: |
Ravinsomniac wrote: |
Even though its "history" which we should never forget..., some of that shit just needs to stay in the past.. its what some say is bad JuJu...
Thats just my opinion.. and you know what said about those..
The helmet draws attention alone without any added attributes
Posted: Sun Sep 07, 2014 8:27 am Post subject: |
VOLKSWAGNUT wrote: |
If I were to letter the helmet, I would put Puzzle Manx on it.
IMO, if I had a Kubel, the SS would match, but the buggy did not come around for another 20 years and it would be out of place, to me. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Sep 07, 2014 8:41 pm Post subject: |
Took it for its first camping trip!
motoRAT Samba Member
Posted: Wed Sep 10, 2014 5:09 am Post subject: |
new headlights for the buggy
_________________ Be curious, dismantle it all, reassemble it, go for a ride! |
