legotech7 Samba Member
Joined: May 09, 2009 Posts: 263 Location: North Carolina
Posted: Tue May 15, 2012 5:32 am Post subject: |
Thanks banditwolf, I'll lower the voltage a bit ( my welder only has 4 setting )
its set on 3 now. The settings are from the label that's inside the machine and for the thickness of the material, that's how I set it.
But I will try your advise and see how it goes....... |
Posted: Mon May 28, 2012 10:40 am Post subject: Some practice welds |
Did some practice welds on some thin metal doubled up on the welds. These are two pieces over lapping each other. Used a #2 setting for the voltage and a 5 speed setting for the wire speed. Ground the welds down, gave it a tinsel strength test with a 5 pound hammer. Folded it over ( should have took some pics ) and straighten out again. It didn't come apart. The welds held up pretty good. but the welds aren't pretty. Did this on my 135 Mig from Northern Tool, gasless flux core. Gonna try it with the argon c02 mix soon. Maybe the welds will look better.
Gotta practice some more.... Please feel free to comment, Thanks.....
catarinoforlife Samba Member
Joined: November 15, 2009 Posts: 169 Location: Covina, CA
Posted: Sat Jun 09, 2012 10:50 am Post subject: |
can anyone tell me if this is a good deal?
http://losangeles.craigslist.org/lgb/tls/3036869428.html looking to replace the tranny front mount as well as do repair panel work.
Can someone also recommend what size wire and type wire we should use as well as any settings to be aware of? This will be our first time welding and we want to practice using the same settings and equipment before we hit up that torsion housing. |
MMW Samba Member
Joined: April 30, 2012 Posts: 361 Location: northern NJ
Posted: Sun Jun 10, 2012 5:27 pm Post subject: |
I did not read through this whole thread but thought I would post a comment on machines. I am a welder by trade & have 30 years in the industry. Mainly sheet, plate fabrication & repair work. Not a lot of body work. For those of you looking for welding machines I would recommend Miller, Lincoln or Hobart. No the box store Lincolns as they are different than the dealer machines. They all have support & parts availability for years to come. The cheaper machines you can buy usually have no part availibility in a few years & it is hard to find a service center to repair them.
A great source of welding info is at millerwelds.com. I am not affiliated with Miller but am on their forum. I found this area of the Samba since I joined the Porsche 356 forum here. _________________ Mic McWilliams
1959 356 coupe
Missing the original engine 72488
Anybody have it? |
Posted: Sat Jun 16, 2012 2:46 pm Post subject: Spot Welds |
Did some practice spot welds on two pieces of sheetmetal. The settings on my welder were #3 for voltage and 4-5 for wire speed. Drilled a 5/16 hole on one side of the sheetmetal; thought 3/8 was way to big a hole, and puddled away. I tried to to get a nice puddle in the holes. Didn't look to bad. Check the other side. I think I got good penetration. Need to practice a bit more for when I start doing my pans and heater channels. Cleaned them up a bit.All comments welcome. Oh, notice the bottom weld beads and a little burn thru on the edges. Used .030 flux core wire. I think with the gas I'll do a bit better, Like I said, still practicing.....
krusher Samba Member
Joined: September 24, 2002 Posts: 7617 Location: california
Posted: Tue Jul 17, 2012 11:50 pm Post subject: Re: Spot Welds |
| legotech7 wrote: | Did some practice spot welds on two pieces of sheetmetal. The settings on my welder were #3 for voltage and 4-5 for wire speed. Drilled a 5/16 hole on one side of the sheetmetal; thought 3/8 was way to big a hole, and puddled away. I tried to to get a nice puddle in the holes. Didn't look to bad. Check the other side. I think I got good penetration. Need to practice a bit more for when I start doing my pans and heater channels. Cleaned them up a bit.All comments welcome. Oh, notice the bottom weld beads and a little burn thru on the edges. Used .030 flux core wire. I think with the gas I'll do a bit better, Like I said, still practicing.....
Flux core wire just utterly sucks for car welding, just give up on it till you get some shielding gas.
If your going to do test welds and show us pictures, dont grind the weld off, if i could see the weld you had actually done I would have chance to give constructive criticism if i was needed, but seeing you have ground it off I can't.
If you get a spot weld in a hole right you should be able to grind it off an not see it. _________________ (06:31:07) RoachGhia: "i drink dick way too fast"
(06:54:29) BoomsVW: "i always feel free down there" |
Posted: Wed Jul 18, 2012 12:55 am Post subject: Re: Second try |
| legotech7 wrote: | Well I put another bead on the other side of the angle Iron and ran it on the inside corner as straight as I could. Looks a little better, but still a lot of splatter. I guess its because of the flux core wire. No pics this time, too blurry, camera I guess. I'll keep on trying till their perfect. Its only my first time and only a few attempts. More pics to follow.......
Thanks.......... |
if your doing close up camera shots (under 12") them you need to set your camera to macro mode (usually a flower symbol) _________________ (06:31:07) RoachGhia: "i drink dick way too fast"
Endicott jb Bondo King
Joined: February 17, 2008 Posts: 1945 Location: Havre, MT
Posted: Wed Jul 18, 2012 10:11 am Post subject: Re: My first weld |
| legotech7 wrote: | Well I got my welder in. Set it all up to lay a bead on a 1/8ht of an inch of angle steel. The welder is set #3 voltage and wire speed at #5. Running flux core wire just to see if I can at least try to run a bead. Well if you can tell by the pic ( a little blurry ) I tried to start with the wire at about a 1/4 inch away from the metal. I started getting splatter everywhere. Then I placed my left hand under my right to steady it a bit and ran a bead in the middle. Not straight but a little better and another on the edge of the piece. Again not straight but a little smoother. I'm trying to every inch of the angle iron,cause its the only piece of scrap I could find to practice on.
I managed to get that sizzling bacon sound that they talk about. Lets see; Machine set at correct setting for the piece to be welded, start arc at correct distance from the piece,place nozzle at correct angle and run bear bead at steady pace or speed. I know; it looks like crap, but I'm going to keep on practicing.
Please any comments, tips suggestions. Critique all you like, all are welcome. I have to get this right if I;m going to work on my dub.
Thanks
Set the amps higher and the speed lower. Go slow with the trigger until you start a puddle. Once the puddle has started, slowly move left to right counting to 3 on each side. This will make the weld actually penetrate the metal and the splatter go away a little bit. _________________ Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs. |
Posted: Wed Jul 18, 2012 10:20 am Post subject: |
I decided at work today to do a few test welds as examples for people to learn from.
My welder at work is a 190amp (with plain CO2 gas, which make the welder need to be on the next amps setting up than if i was using argo mix)
The welder goes from 1 to 8 on the power and I use 3 to 7 for vw welding (you can see labeled on the test pieces which setting i have used.0
The top is a butt weld, we cam see in the setting 5 spot welds that at the edge on the spot it has fallen/burnt away slightly, so i switched down a setting for better welds, then are some examples of the spot welds joined together.
Line 2 is an example of welds through a punched hole 5 was a little cold/lack on penetration through to the second piece of metal 6 and 7 are both fine. the the far right there was one more which i have ground off, with a flap wheel it would completely disappear.
The bottom line is a joggled over lapped joint, first example of a single spot weld, then using the trigger on/off technique some joined spots, then finally a continuous run (run was done right to left)
the back for some penetration shots
And some close ups.
This welding is not perfect and I am not certified, but I hope it will give you some examples to try to copy to get the setting on your welder right. _________________ (06:31:07) RoachGhia: "i drink dick way too fast"
Posted: Wed Jul 18, 2012 12:32 pm Post subject: |
Good deal krusher, they look like good welds to me and is what I'm striving for. Just need some practice to start my bug project. Those welds seem sufficient for the task at hand.
Thanks for the pics and detail, good info. as always....... |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 210 Location: Lancaster PA
Posted: Fri Aug 10, 2012 10:55 am Post subject: |
I switched from flux core to MIG today (man tanks are expensive) and I cannot believe the difference. Same machine same recommended settings. I could do almost nothing with fluxcore but even my first MIG weld looked great. _________________ Trying to track down my old 86 syncro.
Last seen in VILLAS, NJ
wv2yb0252gg092706 |
hill  Samba Member
Posted: Sun Sep 30, 2012 12:08 pm Post subject: |
| MayorMcCheese wrote: | | I switched from flux core to MIG today (man tanks are expensive) and I cannot believe the difference. Same machine same recommended settings. I could do almost nothing with fluxcore but even my first MIG weld looked great. |
Yours is a very common reaction. People resist having to use gas - some don't understand the need for it, some don't like the cost or hassle of getting a tank and having it filled. But it's a very rare and obstinent person who does not immediately recognize the improvement of his welds once he finally succumbs to the purchases of a gas mig setup.
I think that fluxwire welding can be good practice since it develops the patience needed to go back and clean off spatter. I guess....  |
Posted: Tue Oct 02, 2012 5:45 am Post subject: |
Well finally got gas fro my welder. What a big difference! My welds are much cleaner and my passes look almost pro. Some times I have a problem seeing where I'm welding so I added some external lighting and that seemed to help a lot. So I think I'm going to get a Mig light to attach to the welding tip. Anyone have any comments on the Mig lights? My eye sight is not that great and my garage ids dimly lit. So I think the extra light would help.
Anything to get this project underway........ |
Altema Samba Member
Joined: June 20, 2010 Posts: 2051 Location: Lower Michigan
Posted: Sat Jan 12, 2013 12:45 pm Post subject: |
Quick question: I've been out of the loop since trading my huge Craftsman arc welder for car parts years ago, and need to do some minor repairs on my son's car, and possibly minor sheetmetal work on our Ghia (battery area). Are the Harbor Freight flux core welders useless for sheetmetal?
Paul |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12437 Location: Eugene, OR
Posted: Sat Jan 12, 2013 1:01 pm Post subject: |
Read legotech7's post above and you can see that gas shielding/using solid wire is essential for good results. They are not that much more expensive anyway. Hobart 140 is real popular. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
Posted: Sat Jan 12, 2013 4:38 pm Post subject: |
Personally i wouldn't waste my time or money on a hf flux cored welder. Get a decent gas welder. As posted before, Hobarts, millers, and Lincolns are good welders and worth the money. I think the local ranch store near me sells Hobarts for about $300 and up. I bought my Lincoln 140 set up for about 500 and i love it. Very user friendly. Tanks are expensive but flux cored can cost more. I think here flux cored is 3x the price of solid wire. _________________ Josh
OORAH!!
1974 VW Panel Bus
.|_____|.
(0\_!_/0)
Altema Samba Member
Posted: Sat Jan 12, 2013 10:36 pm Post subject: |
Thanks for the info, I suspected as much.
Paul |
Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 245 Location: California
Posted: Sat Jan 26, 2013 12:55 pm Post subject: Hobart 140 Vs. Longevity 140? Anyone Use Longevity? |
Hi,
I was wondering if anyone has any experience with a Longevity welder?
I was all set to buy the Hobart handler 140. I am looking to do some light duty welding to my bus and have read good things about the Hobart 140.
That said, when I was watching some welding videos on Youtube, I ran across a video for Longevity welders. Specifically a video on the Longevity 140.
http://www.youtube.com/watch?v=KTcg74W7PFA
Now, I'm maybe thinking about buying the Longevity, but not sure of the quality.
I like the Hobart 140 because I have read good things about it, especially for a novice like me. It is in the $500-600 range price wise. Easy to adjust, is not 220, high quality, all selling points for me. Also, I think with the Hobart 140, you can weld thicker metal than with the Longevity.
The Longevity is a bit cheaper, but I'm just unsure of the quality.
One thing that struck me about the Longevity was that I could also pick up the handgun and still be under the cost of the Hobart. This was a selling point of the video I posted above......But unsure of the quality in reality.
Although, I do not need to weld any aluminum on my bus, I thought having an option for the spool gun may come in handy down the road if I decide to take on more projects that require welding.
In the video the guy mentions that you can add a gun to the Hobart 140 but it is very pricey. Has anyone added the spool gun to the Hobart 140? Is it really super expensive, or is it reasonable?
Thank you for taking the time to respond and share some advice and knowledge. I am a welding rookie and just looking for a decent welder that I can grow into.
Spitty |
MMW Samba Member
Posted: Sat Jan 26, 2013 7:25 pm Post subject: |
I would buy the Hobart. If something ever happens to it they have good support & parts availability. Plus you would be buying a machine that has great reviews & has proven itself to be reliable & long lasting. Any of the name brand welders also hold their value so if you ever want to sell you will get most of your money back. _________________ Mic McWilliams
1959 356 coupe
Anybody have it? |
1967250s Samba Member
Joined: May 02, 2007 Posts: 363 Location: on the road to wisdom
Posted: Sat Feb 09, 2013 2:47 am Post subject: Welding |
Okay ,not much experience at mig welding myself( I have a campbell hausfeld Mig, but here are a few tips.
1. Welding thin metal-vw- do small spots about 2 inches apart, and not a continuous run, warps are avoided this way, large flat areas especially need this method
2. welding edges-- get a copper or aluminum backing plate-called a spoon- it holds up the metal, you can use it with clamps to hold the metal sheet together, and cools the surrounding metal. -starting at the edge- just do a small spot- stop, let it cool, then more small spots. Also use to back weld holes and butt joints.
3. Clean the weld area, much easier to do decent job. get down to clean metal.
4. practice on similiar size/thickness metal first, then practice some more
5. Look at as many youtube welding videos as you can then look at them again, there are also lots of vids on welding vdubs and doing bodywork, tons of great advice out there >free!
6. get the best equipment you can, you can always sell it at a better price than cheap garbage |
