PaRacer Samba Member
Posted: Thu Oct 18, 2012 6:32 pm Post subject: |
I just replaced the shift rod bushing and coupler and the help I found here on TheSamba made a tricky job MUCH easier! I used a pull string to help return the rod to the bushing. Lots of grease and lots of patience is the trick! I did have an issue with the coupler, the cross pin would not fit in the hole at the end of the shift rod. Had to chuck it up in my drill and spin it on some emery cloth to get it to fit. It was the more expensive one that CIP1 sells. Everything else went well, can't wait to try it out tomorrow! (edit to add - It works great, just like new, well worth the time it took) _________________ '73 Standard "Sunshine" |
patroklus Samba Member
Joined: February 08, 2013 Posts: 8 Location: Portland, OR
Posted: Fri Mar 08, 2013 12:09 pm Post subject: |
I replaced the bushing yesterday on my 73 Super. Gotta love the extended length in the front, allowing me to do it without removing the front inspection plate. Thanks to Glenn for the detailed instructions. Now it's smooth shifting for awhile at least. |
SimiRon Samba Member
Joined: December 30, 2012 Posts: 46 Location: Simi Valley
Posted: Wed Mar 13, 2013 7:24 pm Post subject: Shift Rod Bushing |
I change my front shift rod bushing on my bus about once every other year. They don't seem to last longer than that, but its an easy job. I just changed the bushing and clip on my '64 bug today for the first time. Thankfully I researched the topic here and it went real smooth. I used an electrician's fish tape to guide the rod out the front. What a difference! _________________ '78 ASI Riviera Camper
'64 Deluxe Bug
'65 Delux Bug |
alex_juarez Samba Member
Joined: June 18, 2004 Posts: 295 Location: New Mexico
Posted: Thu Apr 25, 2013 6:51 pm Post subject: |
I read this whole thread and was kind of hesitant to do mine as I'm not that bad ass as some of you are. But I tried today and did it in an hour. was not bad at all and what a difference. thanks guys |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
snj Samba Member
Joined: October 18, 2006 Posts: 489 Location: Seattle, WA
Posted: Sun Dec 15, 2013 12:20 am Post subject: |
I'd like to use this thread to whine about the (lack of) durability of currently-available shift rod bushings.
When I bought my '63 Bug in 2006, the first real project I undertook was a shift rod rejuvenation. The shift rod bushing wore out some time in the past, and a previous owner had driven it until the bracket completely broke, letting the shift rod fall down to the point where the socket no longer engaged the shifter. At that point, someone devised a horrible strap system to hold the rod up enough to make the car semi-drivable. When I got the car, I put in a new bracket, and a new bushing and retaining clip along with it. A couple weeks ago (7 years and 47,000 miles later), I noticed that my shifter suddenly had significantly less resistance than usual. Today, I investigated the situation and found that my shift rod bushing had turned into 5 separate pieces. A pre-emptive answer: Yes, it was all well-greased. It's quite unfortunate that so many of the VW parts currently produced are of such terrible quality.
Look at this garbage:
Stock up on bushings, folks. Apparently if you drive your car more than on weekends, you'll need to replace the bushing every few years. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Sun Dec 15, 2013 12:34 am Post subject: |
It lasted for 7 years and 47,000 miles?
That doesn't sound too bad.
My low mileage '63 with 43,000 miles had a worn out bushing in it - the original.
I'm sure it had been worn out for a long time.
I replaced it with a repro when I got the car and it lasted about 5 years (guess)... but I only drove less than 1,000 miles in that time.
I was able to find an NOS one the next time and wow, it installed so much nicer than a repro. I could tell it was nicer just by touching it. I hope it lasts. _________________ How to Post Photos
snj Samba Member
Posted: Sun Dec 15, 2013 12:59 am Post subject: |
EverettB wrote: |
I was able to find an NOS one the next time and wow, it installed so much nicer than a repro. I could tell it was nicer just by touching it. I hope it lasts. |
OK, compared to 1ish thousand miles, mine did pretty well, I suppose. Still, there's a note in the shop manual (my '65 T3 manual, in this case, since my Bug manual is currently buried under piles of other junk) saying how the bushing "does not usually need to be replaced." I know these were economy cars, but I imagine they were looking at service lives of more than 50k miles.
The repro bushing I installed today felt overly tight. I'll keep an eye out for NOS bushings and see if I can get something that fits a bit better. |
wcfvw69 Samba Purist
Posted: Wed Feb 12, 2014 3:23 pm Post subject: |
Oh these cheap, crappy, aftermarket parts. This is the 2nd bushing I've installed in my 69 convertible a few years back. It had MAYBE 1500 miles on it before it failed. It actually failed a couple of years ago, I just finally got around to installing another new one. This one I bought from Wolfsburg West. We'll see how long it lasts.
The hanger was like new so it's not causing them to break. This new one slipped in the hole nicely. I greased it up and the was able to push the shift rod thru it w/out too much force. I greased it going thru the bushing and then hooked everything up again. It is amazing the difference this bushing makes when its in place and new vs. broken. Side note, my rod is straight, no bends at all. Not sure when this changed.
The good news? I've done it so often, It took less than an hour moving at a fairly slow pace, by myself. I just wish I had not procrastinated sssoo long to install this. _________________ Contact me at [email protected]
The Samba member since 2004.
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Wed Feb 12, 2014 10:33 pm Post subject: |
alex_juarez wrote: |
One step at a time to bad ass status... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
exploderjim Samba Member
Joined: February 01, 2014 Posts: 8 Location: Stoney Creek, Ontario
Posted: Sun Mar 23, 2014 12:35 pm Post subject: Shist rod bushing |
Can't say enough thanks for this how to. went easy as it said it would. Even installed new vintage shifter and simple. Thanks again. |
wagonmaster Russ Samba Member
Posted: Sat May 03, 2014 5:49 pm Post subject: |
Just finished mine, don't hesitate, if you can handle simple tools, you can do this yourself. Read the thread, easy beans. The hardest part was getting the new bushing into the hanger and that only tool a couple of minutes.
After I got the shaft started I just pryed it forward with long needle nose pliers (mine are bent at a 45) lubing as I went.
My old bushing was in fragments in the bottom of the tunnel, nice tight shifts now.
Glad I did it! _________________ Russ
OG paint Bahama Blue '65 |
theparanorm Samba Member
Joined: May 08, 2013 Posts: 14 Location: United States
Posted: Fri May 16, 2014 11:03 am Post subject: |
What a difference that little bushing makes. Smooth and tight shifting now. Feels like to new drive line.
Just did mine last night...solo. Took a little time, but very well worth it! _________________ '63 OG Bug |
billfred1 Samba Member
Joined: May 19, 2014 Posts: 287 Location: Bloomington, IN
Posted: Fri Jul 18, 2014 9:24 am Post subject: |
So I plan on doing this project. I looked last night and my bushing is gone. Clip is still there, but no bushing. I also looked at the coupler, there seems to be a decent amount of side to side play. I ordered a new coupler, bushing and ring.
I’ve read this thread, if I understand correctly, some people place the bushing on the shift rod first, and some people put it in the hangar first. Is that correct? Is one way preferred over the other. The hangar seems to be OK (complete hole, not busted).
Thanks _________________ Bill
1966 Beetle |
Posted: Fri Jul 18, 2014 12:01 pm Post subject: |
billfred1 wrote: |
Thanks |
Put it in the hanger, grease it up and then push your shift rod thru it. _________________ Contact me at [email protected]
Posted: Fri Jul 18, 2014 12:30 pm Post subject: |
wcfvw69 wrote: |
billfred1 wrote: |
Thanks |
Put it in the hanger, grease it up and then push your shift rod thru it. |
+1 on in the hanger first. _________________ Russ
Posted: Tue Sep 16, 2014 4:08 pm Post subject: |
Well, I got about 400 miles out of my bushing
I just noticed the shifter was rattling a bunch. Looked in there tonight and the bushing is not completely gone, but it looks like it has split radially. I don't think my holder was bad, I even remember taking sandpaper to the I.D. of the hangar to clean it up.
The bushing was a $2.50 Jbugs version. Is the WW bushing the one to get? _________________ Bill
1966 Beetle |
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Thu Sep 18, 2014 6:41 am Post subject: |
billfred1 wrote: |
The bushing was a $2.50 Jbugs version. Is the WW bushing the one to get? |
Got mine from WW and have not had any issues but I am unsure if it is my driving or the quality of the bushing that makes it last. I have about 2000 miles on it and still no issue from WW. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
djweaz Samba Member
Joined: October 05, 2014 Posts: 81 Location: Murfreesboro, Tn
Posted: Thu Nov 06, 2014 12:47 pm Post subject: |
Just went out and did it opposite of what I was doing and put the bushing in the hanger first as I saw some people do it. I highly recommend putting it in the hanger first. Took me 5 minutes and was bolting it back together. The plastic pieces that hold the back of the rod in place so the bolt will go through it I have to find and order next. I suspect that is where a little play is coming from. Although shifting is much better now than it was yesterday.
I would like to thank all the people that spend there time to help each other out on this forum, it sure makes things much easier. Maybe someday I will be as good and be able to help others as well. |
nvrgvupjw Samba Member
Posted: Sun Dec 28, 2014 6:51 pm Post subject: |
djweaz wrote: |
Hi all,
I realize this is an older, longer thread, but it's good information nevertheless. I've yet to do a shift-rod bushing replacement on my early ('63) bug. However, even though it shifts well, I'm anticipating a new bushing one of these days.
Just out of curiosity, and I've read almost all the posts, I've never seen an alternative to the cheap plastic bushing and lock ring set-up. Does anyone know of something more bomb-proof like a brass bushing? Maybe something like a link-pin front suspension bushing made to the proper size? If it were made in two pieces that would thread together and secure it into the support, it would probably last mucho years, yes?
Somewhere, years ago, Bob Hoover, or Gene Berg or someone described drilling a one/eight" hole in the tunnel right above the bushing, so that once a year or so you could pull back the carpet and lube the bushing with a drop of oil. Has anyone tried that? Thanks. |
