bbugman74 Samba Member
Joined: April 21, 2004 Posts: 159 Location: south of here and north of there
Posted: Thu Feb 23, 2006 11:08 am Post subject: rear subframe removal/install (I searched) |
How hard is it? What all is involved? Could I do a swap at a salvage yard? (subframe+engine+trans out in one piece and into another car in one piece) I found a nice 65S Notch, but it doesn't have a rear subframe. The guy also has a 67 Square that is complete but has been smashed in the front. I was wondering if this is possible and how hard it would be. Thanks for the help _________________ 65 Notch (project)
74 Standard Beetle
01 Jetta VR6
"That beer I had for breakfast, wasn't bad, so I had one more... for dessert"-Johnny Cash |
sofaking Samba Member
Joined: January 24, 2005 Posts: 151 Location: Orange County
Posted: Thu Feb 23, 2006 4:55 pm Post subject: |
I would say yes, make sure you keep ever nut, bolt and rubber bushing from the Square. Just make sure the shift rod, brake line, e-brake cables, fuel lines,clutch cable, throttle cable, starter wires, and heater boxes (if it has them). Remove bolts from top (shock tower area & under rear seat). then under the car there is 2 bolts on each side and 4 bolts in center to remove plate and then 1 bolt under the plate. Have someone to help you and use caution! Safety is a must! |
GjMan Samba Member
Joined: June 05, 2004 Posts: 822 Location: Grand Junction, CO
Posted: Thu Feb 23, 2006 7:42 pm Post subject: |
Yes, you can do the swap at the salvage yard if you bring enough tools, especially a good jack and jack stands. If there are tires on the rear wheels, you can easily removed engine, trans, and subframe as a single unit and roll it under your new Notch. I've done this job a couple times by myself, but a buddy and a few beers make it go much quicker. |
Posted: Fri Feb 24, 2006 8:07 am Post subject: |
thanks for the input guys I have a squadron of the aircoold faithful going with me. All I had to say is "I'm going to get another car" and then everyone wants to go _________________ 65 Notch (project)
74 Standard Beetle
01 Jetta VR6
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Fri Feb 24, 2006 8:25 am Post subject: |
Take some boards with you to put under the jack and jackstands. Nothing worse than jackstands that sink in the soil under the weight of a lifted car. Surely your life is worth that much? _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Fri Feb 24, 2006 9:43 am Post subject: |
This isn't my first rodeo, just the first time I'll be swapping a T3 rear subframe _________________ 65 Notch (project)
74 Standard Beetle
01 Jetta VR6
