hpw Samba Member
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Fri Jul 20, 2007 10:56 pm Post subject: Please, UPDATES ANYONE??? |
Any one have an update report on any of the afore mentioned products??? |
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Sat Jul 21, 2007 8:48 am Post subject: |
Quote: |
So far the best thing I've found for heavy rust removal is muriatic acid. |
I been thinking of using this on a bunch of old factory nuts, bolts, brackets, etc., but what could I coat them with afterwards, so they don't repeat? I've got an old coffee can of used motor oil I dip them in, which has done ok, but if I want to reuse them, I should look into something better? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Jul 21, 2007 10:20 am Post subject: |
I've had great results with Rust Mort, but you have to prime it after it sets up, so I plan my work around that. No adhesion problems that I've ever encountered, though. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Bugs'n'Pugs Samba Member
Joined: July 18, 2004 Posts: 1453 Location: Charleston, South Carolina USA
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Feb 02, 2017 3:30 pm Post subject: Re: Rust removal:Has anyone used... |
What I have read about POR products is that it is a combination rust converter/sacrificial metal coating. There are also reports that it does not work that well. If you are using it over rust that should not be an issue to remove anyways, it should work perfectly. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
BotanyBandit Samba Member
Joined: February 13, 2013 Posts: 224 Location: Kansas City
Posted: Fri Feb 03, 2017 8:19 am Post subject: Re: Rust removal:Has anyone used... |
vinegar and water for rust |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Fri Feb 03, 2017 1:55 pm Post subject: Re: Rust removal:Has anyone used... |
POR-15 encapsulates rust; it is not a rust converter. It has worked well for me as long as the area is clean and has some rust on it or, if not put on metal that has rust, the metal has been cleaned and scuffed up. (I don't use their marine clean or metal ready, and save money).
When I finished an underbody up restoration of my 1963 camper some 16 years ago, a few years later I cleaned the paint on the underbody, wheel wells, and front floor, scuffed up the paint, and brushed on grey POR-15. Fourteen years later, there has been no problem. _________________ Don't worry; be happy. (Baba) |
Posted: Fri Feb 03, 2017 4:40 pm Post subject: Re: Rust removal:Has anyone used... |
Quote: |
POR-15 encapsulates rust; it is not a rust converter |
I believe I read that it has phosphoric acid in it? Taking the rust out of the equation of causing rust again would be converting it,would it not?
Edit: I found this interesting webpage that includes a lot of products.
http://ecologicarchitecture.com/SoloHobbit/rust/
also
http://www.autos.com/auto-repair/rust-encapsulator...structions _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Sat Feb 04, 2017 4:51 pm Post subject: Re: Rust removal:Has anyone used... |
I searched on the web for 'Encapsulator' and did not find a technical definition for it. Corroless does not list their ingredients that I could find.
Here's Rustbullets pitch and a test on competing products.
https://www.rustbullet.com/advantage/product-comparisons
In their test, cold galvanizing compound finished 2nd and a head of POR. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
