Sperrwolf Shifter Locks
53 0val
Samba Professor
53 0val is offline
PostPosted: Mon Mar 27, 2006 1:34 pm    Post subject: Reply with quote
Not the same Gabriel. Wink That is a much later version(mid '60s) of the one you recently sold. https://www.thesamba.com/vw/classifieds/pix/1075541.jpg
Big difference in price.
Speedsterboy
Speedsterboy is offline
PostPosted: Mon Mar 27, 2006 3:18 pm    Post subject: Reply with quote
Did these Sperwolf shifter locks ever came with a rubber boot? I don't have or never had one on mine...
53 0val
Samba Professor
53 0val is offline
PostPosted: Tue Mar 28, 2006 10:07 am    Post subject: Reply with quote
I have had a couple of these from various years, some even NOS and in the box and I have never had a boot........that said; if you look at the pictures from the previous page you can see some with boots. It is just my experience that I have not had boots with the ones I have owned. Confused
Lind
Lind is offline
PostPosted: Tue Mar 28, 2006 12:38 pm    Post subject: Reply with quote
I think that you just use the stock boot. they are certainly set up to take a boot.
Wanted:
retrowagen
retrowagen is offline
PostPosted: Tue Mar 28, 2006 1:22 pm    Post subject: Reply with quote
For a WASO I had a few years back, I tracked down a old stock rubber boot that was designed for shift locks, and it was indeed larger in base diameter than a stock boot. I believe I found it at Bad Camberg; don't remember from whom.
IIRC, the Sperrwolf's boot lip is larger in overall perimeter than a stock shifter's flange, as well.
David Ruby
President, Karmann-Ghia World Club
53 0val
Samba Professor
53 0val is offline
PostPosted: Tue Mar 28, 2006 1:48 pm    Post subject: Reply with quote
When I had a Sperrwolf in my bus, I went to an auto upholstery shop and had a boot made out of leather. It was inexpensive and it looked great. Wink
retrowagen
PostPosted: Tue Mar 28, 2006 10:45 pm    Post subject: Reply with quote
That seems to me to be an elegant solution! Cool
David Ruby
splitpartsunlimited
splitpartsunlimited is offline
PostPosted: Thu May 31, 2007 3:22 am    Post subject: Reply with quote
regarding the boot , i have bought some grey , glossy , beautiful boots from bfy in the 90`s ..... they were real hard to reshape to make them fit the sperrwolf ...so
i have prepared a jarr of very hot water , submerged the boot for a few mins .....and voila !!! after that , the boot went there real easy ......
now , anybody could give me the height of the spacer???
i can manufacture them in steel or duraluminum , and paint them in the matching color , if anybody is interested , just let me know
i can also provide the longer bolts
ricardo
in my Garage:
1951 crotch cooler split
1971 1302 cabriolet
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring
The Vdub Hub
The Vdub Hub is offline
PostPosted: Sat Feb 05, 2011 7:57 pm    Post subject: What would be correct for a 56 Oval window Reply with quote
I'm starting my search for a Sperrwolf. Can anyone post a pic of the correct one for a 56 beetle with all the necessary bits and pieces. I know nothing about them- yet.
Mike Att
Mike Att is offline
PostPosted: Wed Oct 19, 2011 3:41 pm    Post subject: Reply with quote
I've just picked up these 2 shift locks
I don't recognise this logo on this one
Any idea's?
I know it's for pre 55 as the shape is designed to miss the handbrake
Unfortunately the lock has been drilled so I'm hoping the barrel in the other lock can be swapped across
sub-hatchtim
sub-hatchtim is offline
PostPosted: Thu Oct 20, 2011 3:23 am    Post subject: Reply with quote
looks like it says kamax they supplied vw with tons of hardware
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
alexwoa
alexwoa is offline
PostPosted: Thu Oct 20, 2011 5:08 am    Post subject: Reply with quote
rare advertisement for Sperrwolf.
vw dealer put that tag on the rear view mirror after maintenaced the customers car to advertice for the Sperrwolf ...
more pics on facebook
http://www.facebook.com/Alex.World.of.Accessories
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Thu Oct 20, 2011 10:31 am    Post subject: Reply with quote
What would be the correct color for these? Most I see look to be ivory, but this one seems to be more of a brown color?
That's the style I have...
53 0val
Samba Professor
53 0val is offline
PostPosted: Thu Oct 20, 2011 10:39 am    Post subject: Reply with quote
I was offered several of those tags last year. Seems like a stash was found recently. Confused
alexwoa
alexwoa is offline
PostPosted: Thu Oct 20, 2011 12:41 pm    Post subject: Reply with quote
yes i sold many of them already - now i only have 5 of them left - sorry i had to rise the price a little bit ...
German U-Boat
German U-Boat is offline
PostPosted: Fri Jul 13, 2012 8:31 am    Post subject: Reply with quote
I just purchased a Sperrwolf lock which is pictured above however it does NOT have the 2 main bolts that hold the unit secure to the tunnel. Is it true that I can use the stock 14mm bolt to hold the rear down and that all I need is a longer 14mm bolt to hold down the front???
Are these bolts to have allen heads???
~Steven G.~
1957 Dove Blue Kombi
RareAir
RareAir is offline
PostPosted: Fri Jul 13, 2012 11:36 am    Post subject: Reply with quote
It is NOT true, you can't just use regular 8mmx1.25 bolts to secure that lock. The rear bolt is easier to fabricate, but some ingenuity will be required to fit the front bolt (especially if you want the locker to function)
The SperWolf bolts have 14mm socket heads, not Allens.
The front bolt has a tapered hole located on it's head. This tapered hole is where the locking pin inserts to facilitate a "locked" mode.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
German U-Boat
PostPosted: Fri Jul 13, 2012 11:48 am    Post subject: Reply with quote
Thanks Rareair, anyway you can post a photo of what the bolts should look like or specs on them? Anyone out there that MIGHT have these bolts for sale? Looks like I need to find someone to fabricate a bolt to work for me. : (Q
~Steven G.~
RareAir
RareAir is offline
PostPosted: Fri Jul 13, 2012 1:51 pm    Post subject: Reply with quote
The front bolt would be the easier one to replicate. You'll need to have a machine shop "blanchard ground" the head of the bolt so it'll sit flush with the locker base. If you inspect the base, you'll see that the front bolt will sit inside a recessed area. When the bolt in in this recessed area, the head of the bolt must be flush so that the lockout plates can move back & forth freely. If the bolt head sits too high, the lockout plates will have little to zero movement.
Once you have the bolt properly ground down so it sits flush, you'll need to dimple the head of the bolt. This dimple will allow the keyed dead bolt to sit properly and lock the lockout plates in the reverse position. You can barely make out the dimple on the front mounting bolt in this photo-
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
German U-Boat
PostPosted: Sat Jul 14, 2012 10:53 am    Post subject: Reply with quote
This is very valuable information! Thank you! How does the rear bolt look and why would it be more difficult to make?
~Steven G.~
Page 2 of 4
