RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Sat Jul 14, 2012 1:29 pm Post subject: |
Steven G. wrote: |
How does the rear bolt look and why would it be more difficult to make? |
The rear bolt is described as a "Hex standoff" to people in the hardware business. One of these-
This first secures to rear part of your shifter base. Then you place the locker base over the oem shifter base. Then you take an 8mm bolt (blanchard ground head, just like the front) and it secures into the Hex standoff _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
German U-Boat Samba Member
Posted: Sat Jul 14, 2012 1:31 pm Post subject: |
Understood! : ) thank you kindly! _________________ ~Steven G.~
1957 Dove Blue Kombi |
Suboval Samba Member
Posted: Mon Jul 16, 2012 11:51 am Post subject: |
RareAir wrote: |
Steven G. wrote: |
I just purchased a Sperrwolf lock which is pictured above however it does NOT have the 2 main bolts that hold the unit secure to the tunnel. Is it true that I can use the stock 14mm bolt to hold the rear down and that all I need is a longer 14mm bolt to hold down the front???
Are these bolts to have allen heads??? |
It is NOT true, you can't just use regular 8mmx1.25 bolts to secure that lock. The rear bolt is easier to fabricate, but some ingenuity will be required to fit the front bolt (especially if you want the locker to function)
The SperWolf bolts have 14mm socket heads, not Allens.
The front bolt has a tapered hole located on it's head. This tapered hole is where the locking pin inserts to facilitate a "locked" mode. |
I have the same Sperrwolf that will be installed on my wife's Bus - the spacer is due to the higher shifter base mount. Take a look at the rest of the pictures.
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
You might want to check out the Technical Bulletins:
http://www.thesamba.com/vw/archives/manuals/techbulletins/z5/61_page1.jpg
http://www.thesamba.com/vw/archives/manuals/techbulletins/z6.php _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Louie Macias Samba Member
Joined: October 19, 2004 Posts: 92 Location: EL CHUCO TX.
Posted: Tue Nov 20, 2012 1:06 am Post subject: |
shifter lock "]Thought I'd post a few pics of my NOS Sperrwolf lock, guess it must be mid 1960's going by the info on this thread and the illustrations of VW's on the instruction leaflet.......
Its never been used, but am a bit puzzled by the seemingly Type 2 part number on the box ; 211 016 051 can anyone shed any light on this? Does this mean it could be fitted to a Type 2?
Lastly, having owned this for about 12 years now I don't really know what its worth (not that I'd sell it! ), can anyone give me an idea please?
Thanks!
[/quote] I have one just like this that came in my 58 right hand drivedrive bug, a guy at the classic told me they are worth about 600.00-750.00 if complete and working like mine ... _________________ ALWAYS HOLDING IT DOWN IN EL PASO TEXAS... |
Posted: Tue Nov 20, 2012 3:24 pm Post subject: |
Louie Macias wrote: |
Thanks!
I have one just like this that came in my 58 right hand drivedrive bug, a guy at the classic told me they are worth about 600.00-750.00 if complete and working like mine ...[/quote]
Because your shifter lock comes with the Aluminum spacer that sits below the base of the shifter, it can be used for a Type 2. If fitting to a Beetle or Ghia, DO NOT install the spacer. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Ronnie Laursen Samba Member
Posted: Tue Dec 11, 2012 4:23 pm Post subject: |
I got the same Sperrwolf lock as Louie Macias shows.
I can add that it is mentioned in vw's own sparepart catalogue with the same no 211 016 051, but the picture does show an older version.
But it is shown with the rubber part
I've used the Sperrwolf lock in my 65' bus for several years and it's been working fine.
But i never had the original aluminium spacer, so i just used the cheap 'short shifter' version.
As i am in process of fine tuning my gear selection, could anyone with the original spacer please give us the height of it
Best regards
Ronnie
Copenhagen[img][/img] _________________ 65' Doubledoor
68' Campmobile |
cavscout Samba Member
Joined: September 17, 2011 Posts: 83 Location: PA USA
Posted: Sat Dec 15, 2012 10:47 am Post subject: |
Question on this one. It is marked BKS and it is the older toilet bowl style. It came out of a 58 bug apparently. Original key. This should be a good fit in my 56 i hope. Any comments on the 56 fit and what is the deal with BKS? _________________ "Thanks to you I'm much obliged, such a pleasant stay" RP
56 ragtop
57 ragtop
79 vert
2010 VW CC Turbo |
Posted: Sat Dec 15, 2012 10:48 am Post subject: |
Same BKS. Will this fit a 56 bug? _________________ "Thanks to you I'm much obliged, such a pleasant stay" RP
56 ragtop
57 ragtop
79 vert
2010 VW CC Turbo |
Posted: Tue Dec 25, 2012 3:22 am Post subject: |
Hello
Did anyone know the height of the org. aluminium Sperrwolf spacer ??
Cheers
Ronnie _________________ 65' Doubledoor
68' Campmobile |
Nessy Samba Member
Joined: September 28, 2004 Posts: 424 Location: Wales,UK
Posted: Tue Dec 25, 2012 10:40 am Post subject: |
shifter lock "Thought I'd post a few pics of my NOS Sperrwolf lock, guess it must be mid 1960's going by the info on this thread and the illustrations of VW's on the instruction leaflet.......
Thanks! |
The above images are from a post I made a few years ago now....
Ronnie I will dig the Sperrwolf out when I get a spare moment and post up the measurements of that spacer .....
_________________ 1972 1302LS Convertible RHD |
Posted: Tue Dec 25, 2012 2:11 pm Post subject: |
Sounds great, Nessy
I will look forward to your answer
68' Campmobile |
Nessy Samba Member
Posted: Fri Dec 28, 2012 1:00 pm Post subject: |
I've just dug out the Sperrwolf from my box of goodies and measured the height of the spacer using a digital caliper, I obtained several readings, varying between 13.06mm and 13.1mm ...
Hope that helps Ronnie...
Posted: Fri Dec 28, 2012 4:53 pm Post subject: |
Cool !
It helps a lot!
Hopefully i get some time tomorrow to compare your measurements against my 'taiwan' part.
i'll let you know
(but it will not be as accurate as i only have and old school caliper )
Thanks !
68' Campmobile |
Posted: Mon Dec 31, 2012 4:40 am Post subject: |
Hello
Now i have made a few measurements, and it seems like i have to grind a bit on my taiwan spacer.
Pictures:
As you can see the spacer is a bit thicker than the 13.1mm, more like 19mm
The bottom of the gearlock , seems to be 49.5mm
Here they are combined. As i calculate it the correct height should be
49.5mm + 13.1mm = 62.6mm.
But as you can see..it is 66mm
So i need to clear 3.4mm _________________ 65' Doubledoor
68' Campmobile |
6of1 Samba Member
Posted: Thu May 09, 2013 12:42 am Post subject: |
Has anybody got any idea where I could buy one correct for a 57 Oval?
Is it possible to buy the spacer?
Thanks
Arthur |
Posted: Fri May 10, 2013 11:48 pm Post subject: |
Maybe that guy from Singapore Tony has one, he have adds on thesamba now and then.
Otherwise Ebay or here.
Its important it's all there..unless you just want is as a dummy item.
Regarding the spacer;
It worked fine for me to grind af bit of my taiwan spacer, you could also have one made local..(like we all know someone, who working with metal)
Its a nice touch for any bug or bus etc..people thinks it is automatic gear.
R. _________________ 65' Doubledoor
68' Campmobile |
6of1 Samba Member
Posted: Fri May 10, 2013 11:58 pm Post subject: |
Thanks Ronnie for the information.
Arthur
From Bromley Kent UK |
The Lord Samba Member
Joined: February 25, 2004 Posts: 83 Location: NORMANDIE, FRANCE
Posted: Tue Jun 23, 2015 5:37 am Post subject: |
Thanks to all for contributing, its all becoming clear now when you don't have the original spacer. |
jwr! Samba Member
Posted: Mon Aug 03, 2015 7:03 am Post subject: |
Just trying to get access to the scans of the Sperrwolf instructions use for the ignition/shifter lock combo got type 1...
The link posted earlier in this thread no longer works. Can anyone provide a working link, upload, or email me a copy of the instructions/installation manual?
[email protected]
Regards & thanks!
Jason |
