EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
GermanRust52 Samba Member
jwr! Samba Member
Posted: Mon Aug 03, 2015 5:10 pm Post subject: |
That's a great start - yes thank you!
Many Thanks!
Jason |
quik56 Samba Member
Joined: July 27, 2011 Posts: 33 Location: los angeles
Posted: Thu Oct 20, 2016 11:51 am Post subject: Re: Sperrwolf Shifter Locks |
Hello... my son just purchased an early type 1 Sperrwolf shift lock. Trying to take it apart to clean up some of the rust inside. Does anybody know a trick or what I can use to remove the 2 flat head screws inside? They are kinda on there cuz of the rust, and really cant get a large screw driver on them cuz they are inside in an angle. Thanks for any help |
water guy Samba Member
Joined: January 25, 2008 Posts: 463 Location: Puyallup Washington
Posted: Mon Jan 02, 2017 1:43 pm Post subject: Re: Sperrwolf Shifter Locks |
Does anybody know if these locks will work in a 1955 Porsche pre-a? I don't know why they wouldn't, but I do not want to just assume and buy one! _________________ '55 Porsche Continental
'63 Firetruck |
kawik's Samba Member
Posted: Sun Jan 15, 2017 12:35 am Post subject: Re: Sperrwolf Shifter Locks |
Anyone know if the early Sperrwolf Shifter Locks work with the early Volmac Folding Shifter? Does the width of the shifter affect the shifting of gears once installed with the lock on? Does the internal plate in the lock need to be modified? |
6of1 Samba Member
Posted: Mon Jan 30, 2017 8:24 am Post subject: Re: Sperrwolf Shifter Locks |
I trying to wire mine into the ignition system and I have a some questions
Is it a cut out switch? As I thought it was or does it act as the ignition switch when it wired up and you no longer use the normal ignition switch
It tells you in the bulletin posted to disconnect the wires from the ignition switch and connect them up to the lock terminals.
If I just wanted to use it as a cut out switch could I just route wire 30 which is the supply to the ignition switch I think via the gearstick lock in on terminal 30 out on 50 back to terminal 30 on the normal ignition switch?
I'm going to have to play with the switch and see what feeds I get out when it's locked and when unlocked
Thanks
Arthur[/img] |
jwr! Samba Member
Posted: Thu Feb 02, 2017 10:23 pm Post subject: Re: Sperrwolf Shifter Locks |
Hi Arthur,
The Sperrwolf shifter locks as discussed in this thread ARE the actual ignition switch. if for example, you ordered you K'ghia from the factory with this option, you would have no dash ignition at all. My car in its factory delivered format is just this. Sperrwolf ignition on the floor, no hole in the dash for stock ignition.
What you are suggesting is that you could use an ignition switch to electronically bypass your ignition switch. when you consider it like this, it makes no sense and maybe better clarifies the thought process behind why you wouldn't be using both?
Hope this helps,
Jason |
6of1 Samba Member
Posted: Mon Feb 13, 2017 3:52 am Post subject: Re: Sperrwolf Shifter Locks |
Dear Jason,
Thanks for taking the time to answer my question. Yes I figured out it was an ignition switch by playing about with it and you have confirmed it.
Is terminial 30 the feed from the battery?
I think I still maybe able to use it as a cut out switch it I route the feed from the battery via it but only use 2 of the terminals. I going to have a play with it this week. |
volkswouter Samba Member
Joined: March 25, 2003 Posts: 450 Location: The Netherlands
Posted: Sun May 17, 2020 4:14 am Post subject: Re: Sperrwolf Shifter Locks |
I recently purchased a Sperrwolf advertised here on the Samba.
The box is mentioning a VW Type 2 partnumber..
Very cool addition to my 1957 bus. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
