MURZI Samba Member
Joined: August 25, 2005 Posts: 3694 Location: Madisonville, La
DSC Samba Member
Joined: March 08, 2005 Posts: 127 Location: Southern Maryland
Posted: Thu Mar 16, 2006 4:14 am Post subject: |
When buffing out a clear use 2000 grit and 3m fill and glaze or 3m rubbing compound. Its easier with a variable speed buffer. If they are just small spots might be better to rub them out by hand.
What no photos? |
SiggyManx#33 Samba Member
Joined: June 13, 2005 Posts: 669 Location: Southeast PA
Posted: Thu Mar 16, 2006 7:47 am Post subject: |
Murz,
What kind of bumps and bruises?
I had a little run in with a dropped screwdriver and my gelcoat this week where the recovery now makes me an expert?
1500 and 2000 grit saved the day. Do you have a buffer? |
MURZI Samba Member
DSC Samba Member
Posted: Thu Mar 16, 2006 3:02 pm Post subject: |
| MURZI wrote: | | Yea, I have a buffer, both orbital and rotary. I have a few scarpes from taking the hood on and off 1000 times. I tried 1500 grit and some 3m "perfect it" rubbing compound with my orbital and a foam bonnet but it still is not a great shine. I may try the roatry buffer with a wool bonnet. |
Perfect It is only the line of product, they come in different grits. You will want machine glaze. Or the Pink fill and glaze or the generically named "Rubbing compound" Plus you get better results trying to buff out 2000 grit and not the 1500. 1500 grit takes extra work to get the same results as you would with the 2000. Also the foam bonnet is less likely to burn the clear as the wool one is. The rotary buffer cranked up to 1800-2000rpm with the right compound will get you there. Keep her moving though.
Anyway have fun. _________________ 1993 RX7 pT-67 .81 a/r
1308cc Two Rotor motor
430rwhp@16psi
Street Buggy currently under construction. |
viperbgy Samba Member
Joined: March 15, 2006 Posts: 199 Location: Spokane,WA
Posted: Thu Mar 16, 2006 3:16 pm Post subject: |
Murzi, if you used perfect it and dont like the shine, this may help you out. If the scratches look to be mostly gone after sanding and hitting it with perfect-it, but the shine is still not great, remember that the perfect it, depending on which one your using still has grit in it for cutting. It may help you to hit it with a finish compound, like 3m's foam pad finishing compound. I have been doing cars and was not real happy with the second cut, but when I hit it with the finishing compound it just came to life. Once your happy with the shine before the show this weekend, buff a hand glaze on with a black foam pad, wipe it off by hand.
Hope this helps, I pm'd you last night about 3:00 in the morning, check your box, Well your pm box !!!  _________________ Mr. B
viper dune buggy
Dune Buggies are unequaled in "smiles per mile" |
dunebuggyjay Samba Member
Joined: March 17, 2005 Posts: 70 Location: Fitchburg, MA
Posted: Thu Mar 16, 2006 4:32 pm Post subject: |
I use meguiers flagship boat wax on my manx (its in a black bottle). Zaino is also pretty awesome, just VERY time consuming.
-Jay |
