Pics of Charcoal Canister Hose to Fan Shroud?
Fusion
Fusion is offline
PostPosted: Sat Mar 25, 2006 10:33 am    Post subject: Pics of Charcoal Canister Hose to Fan Shroud? Reply with quote
Does anyone have any pictures of where the charcoal canister hose connects to the fan shroud? That specific hose on my was duct taped off and I can't find any connection point on the shroud for it. The only thing close is a hole in the upper left corner that's been capped. Would this be the right place and, if so, what type of nipple/connector should be here for the hose to attach to?
1977 Westy -- In process of resurrection
sluggo
sluggo is offline
PostPosted: Sat Mar 25, 2006 10:36 am    Post subject: Reply with quote
That's exactly where it connects. There should already be a nipple built in. Just slide the hose right on and your good to go.
'77 Sunroof Bus.
Itinerant Air-Cooled Forums
http://www.itinerant-air-cooled.com
GreenBrick
GreenBrick is offline
PostPosted: Sat Mar 25, 2006 8:14 pm    Post subject: Reply with quote
There should be a nipple in the cooling tin by number 2 cylinder. the hose connects to that.
Steve
Steve
'78 Westfalia 2.0L FI (Abigail) R.I.P.
BensBlueBus
BensBlueBus is offline
PostPosted: Sat Mar 25, 2006 8:18 pm    Post subject: Reply with quote
http://homepage.mac.com/ratwell/VacuumHoses/13-79VacuumDiagram2.jpg
its not a real pic but kind of gives you the idea
78 Auto FI Westy Deluxe - Newest bus
78 manual FI Westy - Stopped running so sold to some one who said it was going to England.
78 Manual FI transporter - Rarely drive it but starts everytime.
Karl
Karl is offline
PostPosted: Sat Mar 25, 2006 8:38 pm    Post subject: Reply with quote
77 is on the left end of the fan housing [unless someone put a A/C compressor there].
78/79 is on the cylinder tin by #2 cylinder.
renobdarb
renobdarb is offline
PostPosted: Fri Apr 21, 2006 7:48 am    Post subject: Reply with quote
I'd like to resurrect this thread for a little more info... so from the fan shroud, does the hose go into the top or bottom of the charcoal canister?
1978 Campmobile, 2000cc w/hydro lifters, dual Weber 44 IDF carbs (50 idle jets, 115 main jets), SVDA distributor w/Compufire.
1977 Beetle convertible w/Bocar 34pict3 carb
1972 Ford Bronco
VWBusrepairman
VWBusrepairman is offline
PostPosted: Fri Apr 21, 2006 7:53 am    Post subject: Reply with quote
bottom hose if memory serves...top hose to air flow meter box.
renobdarb
PostPosted: Fri Apr 21, 2006 9:14 am    Post subject: Reply with quote
Or, if I don't have FI, top hose to carbs, correct? Would it be a big deal to go to only one carb?
1972 Ford Bronco
