Transmission fluid question
John-
John- is offline
PostPosted: Tue Mar 28, 2006 10:18 pm    Post subject: Transmission fluid question Reply with quote
I am changing the fluid in my tranny. I removed both drain plugs. Is there only one fill plug or two? I found the one on the gearset part but I dont see one on the differential part. Am I looking for a fill plug that doesn't exist?
1962 VW beetle-The project
1985 Honda Aero50cc-The bike
1995 Hyundai Accent-The spare
Bruce
Bruce is offline
PostPosted: Tue Mar 28, 2006 10:24 pm    Post subject: Reply with quote
1
yes
John M.
John M. is offline
I believe there is only one fill plug. Two drain plugs.
John-
John- is offline
PostPosted: Wed Mar 29, 2006 12:09 am    Post subject: Reply with quote
Thanks for the help My chilton book says there is 2. That book sucks
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Wed Mar 29, 2006 3:55 am    Post subject: Reply with quote
Throw that Chilton book in the trash. Or put it next to the toilet for emergency toilet paper. Any other manual out there is better - the Bentley being the best, of course, but I'd take a Haynes or Clymer any day over that POS Chilton book.
-Andy
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Mar 29, 2006 3:59 am    Post subject: Reply with quote
There's only one fill and it's on the driver's side.
Glenn
Member #1009
#BlueSquare
turboblue
turboblue is offline
PostPosted: Wed Mar 29, 2006 8:15 am    Post subject: Reply with quote
A tip on changing tranny fluid.
Always be sure you can get the fill plug out before you remove the drain plug or plugs.
If you can't get it out, you can't refill it.
That would suck if the old fluid was already drained....... Shocked
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
bonzai272
bonzai272 is offline
PostPosted: Wed Mar 29, 2006 10:46 am    Post subject: Reply with quote
any pics or diagrams of where these 3 plugs are located? I was under there the other day and noticed a plug right in the middle on the drivers side, is this the fill plug? Then I guess the 2 drains are on the bottom of the case? Thanks guys. oh yeah also, is there a certain type of fluid needed for this? I have a 64type1.
Ragman
The Sambinator
Ragman is offline
PostPosted: Wed Mar 29, 2006 12:00 pm    Post subject: Reply with quote
80/90W gear oil
MedicTed
MedicTed is offline
PostPosted: Wed Mar 29, 2006 3:03 pm    Post subject: Reply with quote
Someone correct me if I'm wrong. VW used the 80/90 oil in the trans/diff because it would not foam. Foam in a trans/diff would greatly reduce the lubrication. I've been told that lighter oil can be used as long as it is a non-foaming formula (i.e. synthetic). Does anyone know for sure?
Ted Wojton
70 VW Bus Westfalia camper
2003 GMC Sierra
Bruce
Bruce is offline
PostPosted: Thu Mar 30, 2006 1:48 am    Post subject: Reply with quote
VW never spec'd multi-grade gear oil because it was more expensive than mono-grade. They spec'd 80wt gear oil for winter use, and 90wt for summer use.
All gear oil has anti foaming additives (same for engine oils), so you don't have to worry about this.
For gearboxes, I recommend synthetic gear oil, 75W-90. It shifts way better than the cheap stuff. Since you leave it in there for 30k miles, it is easy to justify the cost.
John-
John- is offline
PostPosted: Thu Mar 30, 2006 1:58 am    Post subject: Reply with quote
The bad part about it is that the Chilton book even has a picture of where the Diff fill plug is I can see 2 plugs in the picture but only 1 on the Tranny. The book also tells you how to do the timing so its 180 degrees off. I found that out when I advanced my distributor 180 degrees and the engine started running Embarassed . Mostly I keep it around for the notes I wrote in the margins but after this its going to get demoted to shop rag status.
The Android
PostPosted: Thu Mar 30, 2006 7:55 am    Post subject: Reply with quote
The only other lighter lubricant I've ever heard of in regard to the VW transaxle is to use ATF if it is really really cold. Below like -13°F if I remember right, and if it got warmer, they wanted hypoid put back in there ASAP. As for foaming, I don't know about that. However with modern synthetic hypoid, in cold climates I'd go with that. I used it with the original tranny in my 62 for a couple of years and it made a noticable difference in cold weather.
-Andy
Bruce
Bruce is offline
PostPosted: Thu Mar 30, 2006 10:05 pm    Post subject: Reply with quote
John- wrote:
.... the Chilton book even has a picture of where the Diff fill plug is I can see 2 plugs in the picture but only 1 on the Tranny.
From 61-69, all Type 1 gearboxes had 2 drain plugs. This was needed because the forward gear chamber was not connected at the bottom to the diff chamber internally, so you couldn't get all the oil out with just the diff plug. Then in 70 they altered the casting to allow a passage to drain the forward gear chamber into the diff chamber. Thus they only installed one drain plug from then on.
ottobahn
ottobahn is offline
PostPosted: Fri Mar 31, 2006 7:57 pm    Post subject: Reply with quote
75-90 synthetic redline is what I started running,it shifts so much better than it did with conventional oil.
